Other Parts Discussed in Thread: HALCOGEN
When I enable/disable peripherals by Halcogen and re-generate the corresponding code, those files are not used are still in the project folder of CCS even if they are already removed by Halcogen. Usign the "Refresh" command in CCS does not solve the problem.
Can I avoid to remove the unused files in CCS manually?
Thanks.
Regards.
