I am unable to install ti launchpad on windows 7....usb driver error
Prodigy 10 points
kindly provide me solution....how to install usb driver for launchpad FET...
  • Same problem here. Windows 7 does not recognize the Launchpad board. Please help.
  • In reply to Marco Paez:
    Do you guys have any MSP430-supporting IDE (CCS or IAR) installed? the installation usually prepares the Launchpad driver as well. If so, Windows might automatically and somewhat silently installs & configures the driver for your LaunchPad. You can verify this by going into Device Manager and search for the COM port under the name "MSP430 Application UART".
    Alternatively, if you are certain no existing drivers are present on your system, grab the driver files directly from this package. http://www.ti.com/litv/zip/slac489.
    When first connecting the kit to the USB port, Windows should prompt for a driver installation, redirect to the files above.
    Dung
  • In reply to Dung Dang:
    Hi Dung,
    I could not find any driver files in Slac498 as you stated. Can you make sure that is the correct package?
    David
  • In reply to David Rosales:
    Maybe they have been removed from this package during the last 3 months? After all, it is the capsense library package. So it should only contain the capsense library and not a LaunchPad installer.
    _____________________________________
    Time to say goodbye - I don't have the time anymore to read and answer forum posts. See my bio for details.
    Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
    I'm sorry that  I can no longer provide help  in the forum or by private conversation.
  • In reply to Jens-Michael Gross:
    Actually that's the link to the cap touch library.
    Here's the link to the BoosterPack source/driver/doc package:
    http://www.ti.com/litv/zip/slac490
    Here is the product folder of the kit, which contains more links for cap touch specific items.
    http://focus.ti.com/docs/toolsw/folders/print/430boost-sense1.html
    Dung
