• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » IAR Workbench (IAR Assembler)- MSP430
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • IAR Workbench (IAR Assembler)- MSP430
    This question is answered
    sunil sharma
    Posted by sunil sharma
    on Aug 29 2011 05:48 AM
    Intellectual495 points
    Hi all,
    I am facing a small problem that whenever I debug my program, the Program Counter goes to 0xFFFE.
    Maybe it is due to some incorrect selection of option.
    I then take the PC to 0x2100 manually for stepwise execution.
    MSP430FG4618 IAR Embedded Workbench msp 430
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • BrandonAzbell
      Posted by BrandonAzbell
      on Aug 29 2011 07:03 AM
      Guru54870 points
      sunil sharma
      Hi all,
      Is this when you first load the program into the target?  And your title suggested you are implementing an assembly only project, correct?
      The address 0xFFFE is the reset vector of the device.  I fully expect the first thing the device to do is go to the reset vector.  In your program, you should load the starting point of your program at this location.  The MSP430 CPU will use the value at the location 0xFFFE as an address and branch to it.
      Perhaps your 0x2100 location?
      Brandon
      Report Abuse
      • Reply
    • Jens-Michael Gross
      Posted by Jens-Michael Gross
      on Aug 29 2011 12:27 PM
      Verified Answer
      Verified by sunil sharma
      Guru140630 points
      sunil sharma
      This is usually an indication that the CPU has fetched a vector to an ISR form teh vector table, but there was no ISR assigned to thsi event. Then the vector table contains 0xffff, which results in a jump to 0xfffe (LSB ignored).
      This includes the reset vector (in case you're writing an assembly program and didn't set the reset vector to the start of your program - for C programs, the compiler and linker include the proper code for the reset vector)
      _____________________________________
      Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
      If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
      Report Abuse
      • Reply
    • sunil sharma
      on Aug 30 2011 07:17 AM
      Hi Michael,
      Thanks for your advice. But can you pls tell me how to rectify it and get the PC to 2100 initially (code placed)
      I am relatively new to MSP430 and IAR workbench
      Using the example code of TI I have written a program for transmitting 2 bytes using SPI between MSP430 and DSP (SS sgl routed via 1:8 multiplexer)
      However the program is not working as expected
      -On reaching the USCIA0TX_ISR by stepwise execution the pgm is continuously running and only one byte reaces TXBUF. Also the TXIFG flag remains set even on transferring one byte in TXBUF.
      -Is it necessary to use FLL/DCO as in example code
      -Is it necessary to reset the slave after every transmission or a delay shall suffice
      #include  <msp430xG46x.h>
                  RSEG    CSTACK                  ; Define stack segment
                  RSEG    CODE                    ; Assemble to Flash memory
                  RSEG    INFO                  ; Assemble to INFORMATION MEMORY
      RESET       mov.w    #SFE(CSTACK),SP    ;#02100h,SP;   ; Initialize stackpointer
      StopWDT     mov.w   #WDTPW+WDTHOLD+WDTNMI+WDTTMSEL+WDTSSEL,&WDTCTL  ; Stop WDT
      setupSVS    mov.b   #018h,&SVSCTL            ;Vth = 1.9V
      setupRTC    mov.b   #30h,&RTCCTL
                  bis.b   #RTCBCD,&RTCCTL
      ;SETUP MSP430 FOR SPI-McBSP INTERFACE
      SetupP7     bis.b   #0Eh,&P7SEL             ; P7.3,2,1 option select
      SetupSPI     bis.b   #UCMST+UCSYNC+UCCKPL+UCMSB,&UCA0CTL0;3-pin, 8-bit SPI master
                  bis.b   #UCSSEL_2,&UCA0CTL1     ; SMCLK
                  mov.b   #02h,&UCA0BR0           ; /2
                  clr.b   &UCA0BR1                ;
                  clr.b   &UCA0MCTL               ; No modulation
                  bic.b   #UCSWRST,&UCA0CTL1      ; **Initialize USCI state machine**
                  bis.b   #UCA0RXIE,&IE2          ; Enable USCI_A0 RX interrupt
                    bis.b   #UCA0TXIE,&IE2          ; Enable USCI_A0 TX interrupt
      ;CONFIGURE PORT8 FOR SELECTING THE SLAVE VIA 1:8 MUX-DEMUX
      SetupP8     mov.b   #070h,&P8DIR            ;CONFIGURE THE PORT FOR S0,S1,S2
                  mov.b   #00h,&P8SEL
                  mov.b   #000h,&P8OUT            ; SELECT DSP1 of 4 DSPs
                  bic.b   #000h,&P7OUT;MAKE SS LOW BY SETTING P7.0 LOW - will require to out 0 from 7.1
      ;SetupP5     mov.b   #04h,&P5OUT             ; P5 setup for LED and slave reset  ;    -Is it necessary to reset the slave after every transmission or a delay shall suffice
                 ;bis.b   #06h,&P5DIR             ;
                  ;bic.b   #04h,&P5OUT             ; Now with SPI signals initialized,
                  ;bis.b   #04h,&P5OUT             ; reset slave
                  ;mov.w   #50,R15                 ; Wait for slave to initialize
      ;waitForSlv dec.w   R15                     ;
                  ;jnz     waitForSlv
                  mov.b   #001h,R6                 ; Initialize Tx data values
      Mainloop   mov.b   R6,&UCA0TXBUF           ; Transmit first character
                 bis.b   #LPM0+GIE,SR            ; CPU off, enable interrupts
                 ;nop                             ; Required for debugger only
      USCIA0TX_ISR;       TRANSMISSION THRU SPI       ;On reaching the USCIA0TX_ISR by stepwise execution the pgm is continuously running and only one byte reaces TXBUF. Also the TXIFG flag remains set even on transferring one byte in TXBUF.
      TX1     bit.b #UCA0TXIFG,&IFG2    ;TX Buffer ready
         jz TX1
                  mov.w   #30,R15                 ; Add time between transmissions to
      cycleDelay  dec.w   R15                     ; make sure slave can keep up
                 jnz     cycleDelay
      TX2         inc.b   R6                      ; Increment master value
                  mov.b   R6,&UCA0TXBUF           ; Send next value
          reti                            ; Exit ISR
                  COMMON  INTVEC                  ; Interrupt Vectors
                  ORG     USCIAB0TX_VECTOR        ; USCI_A0 I2C Data Int Vector
                  DW      USCIA0TX_ISR
                  ORG     RESET_VECTOR            ; MSP430 RESET Vector
                  DW      RESET                   ;
                  END
      msp 430
      Report Abuse
      • Reply
      on Aug 31 2011 06:28 AM
      Verified Answer
      Guru140630 points
      sunil sharma
      Here you enable RX and TX interrupt
      sunil sharma
                  DW      USCIA0TX_ISR
                  DW      RESET
      And here you define reset and TX vector, but not RX vector. So as soon as something is received, the processor jumps into the void.
      Note that on 5x family devices, the USCIs have a common RX and TX vector for each A or B submodule, but on 2x and 4x devices, RX and TX have a separate vector, shared between A and B module.
      Report Abuse
      • Reply
    • sunil sharma
      on Aug 31 2011 08:59 AM
      Thanks Michael.....for your help and advice.
      Also I would like to ask if -
      -Is it necessary to use FLL/DCO as in example code.
      -Is it necessary to reset the slave after every transmission or a delay shall suffice between transmissions.
      -Also looking at the code, can you please tell why PC is going to 0xFFFE initially instead of 0x2100.
      msp 430
      Report Abuse
      • Reply
    • BrandonAzbell
      on Aug 31 2011 09:43 AM
      Guru54870 points
      sunil sharma
      I believe this was explained.  0xFFFE is the reset vector.  Upon release of reset, the CPU will fetch the contents at this location (ie. 0xFFFE) and use it as a branch address.  Therefore, I would expect the contents of 0xFFFE to be 0x2100.  Is this what you see in the debugger memory window?
      Brandon
      Report Abuse
      • Reply
      on Aug 31 2011 14:28 PM
      Guru140630 points
      sunil sharma
      No. But it provides a mroe or less table frequency. Without the FLL, the DCO frequency can be almost anything in a wider range. However, you can as well set up an external crystal and get your CPU and SMCLK/ACLK frequency from it, Then you don't need the DCO at all.
      sunil sharma
      The hardware does not need a reset. But depending on the high-level protocol between teh two devices, it might be necessary to de-assert and assert a chip-select signal between two independent transmissions. Also, this signal is usually required for synchronization, as the SPI itself doesn't carry any information about when a byte begins. So usually, the hardware is initialized (reset) when a low-going edge on thsi chip select signal is detected.
      Between any CS transition and teh next operation, a small delay might be necessary (to allow the other side to set up for the next communication block).
      sunil sharma
      Because nobody tells the processor to do so.
      When an interrupt is triggered (this includes the reset), the CPU reads an address word from the vector table that is associated with the ISR to execute. The CPU is not jumping to 0xfffe on a reset, it is looking up at 0xfffe where to jump to.
      Same for any interrupt event. You enabled two interrupt events which each have its own vector. Yout you only defined one ISR and wrot eonly one address to the proper locaiton in the vector table. So for the second event (RXIFG), the CPU finds the default flash content of 0xffff in teh ector table, whcih results in a jump to 0xfffe (LSB is always 0 in the program counter).
      One more thing: you asked why the TXIFG bit is always 1: it isn't. But it is when you do single-stepping. because the USCI does double buffering. When writing to TXBUF, the data is immediately moved to the output shift register and TXBUF is free again for a second byte. During single-stepping, you are so slow, that the current byte is send and the one in TXBUF is move to output and sent and TXIFG is set again long before the single step is complete. JTAG access is slooooow and takes many clock cycles during which the normal hardware normally continues to work.
      Report Abuse
      • Reply
    • sunil sharma
      on Sep 02 2011 08:37 AM
      The contents of the location0xFFFE show FFFF(in fact its all FFs from 0xFF00 onwards).
      That is why it is branching to 0xFFFE.
      Do I have to change the content. of this location ......But it shows that it is ROM and some device file will have to be changed for that......
      Report Abuse
      • Reply
    • sunil sharma
      on Sep 02 2011 09:24 AM
      Got the point about DCO & FLL and the reset requirement.
      I disabled RXIFG first, but the pgm still went into a void on reaching UCA0TX_ISR.
      Then I disabled GIE as well . Only Then the program stopped going into a void. However I read in the userguide that a NMI is enabled only when both GIE and individual bit are set.
      The value I watched at the 0xFFFE in memory while debugging is FFFF. Is that why  the pgm is branching to this address on reset .....Do I have to change this....
      Now that there are no enabled interrupts, and also no int without being defined in the IVT, is this happening because of an interrupt?
      And Thanks a ton for your time and patience....
      Report Abuse
      • Reply
      on Sep 05 2011 07:04 AM
      Guru140630 points
      sunil sharma
      Hmmm, it shouldn't. If it is FFFF, it doesn't execute any of your code at all.
      I'm a bit surprised that the jump is taken, as the bootstrap loader should detect this, take it for an empty MSP and send the MSP to sleep instead of trying to jump to 0xfffe.
      This code should normally define the vectors:
      sunil sharma
                  DW      USCIA0TX_ISR
                  DW      RESET                   ;
      However, it seems to not working
      the ORGs should place the following constant to the location of the USCIAB0TX_VECTOR and the RESET_VECTOR in the INTVEC segment.
      But somehow it doesn't seem to place the two values where tehy belong.
      I don't know why. You should consult the compiler/assembler manual or look into working demo code.
      I just checked some other code examples and the interrupt vectors are define dthere exactly as you did.
      You should ocnfigure the linker to put out a map file and check where your INTVEC segment goes to. As well as where your code is placed to.
      One more thing:
      sunil sharma
      Here you define three segments for use with the following code. However, 'last one wins'. So your reset function will be written into INFO memory rather than main flash memory.
      RSEG has to be used immediately before the code that shall go into this segment. So only one is required, and it normally should be 'CODE'.
      Report Abuse
      • Reply
    • sunil sharma
      on Sep 05 2011 08:32 AM
      Hi Michael....checked the things you told
      <<<You should ocnfigure the linker to put out a map file and check where your INTVEC segment goes to. As well as where your code is placed to.
      SEGMENT              SPACE    START ADDRESS
      CSTACK                                 20B0 - 20FF
      <CODE> 1                               2100 - 21AD
      INTVEC                                 FFA0 - FFDF
      The .mapfile also showed the following information
      #                            -Z(DATA)CSTACK+_STACK_SIZE#                       #
      #                            -Z(CODE)INFO=2100-FFBF                            #
      #                            -Z(CODE)CSTART,ISR_CODE=2100-FFBF                 #
      #                            -Z(CONST)DATA16_C,DATA16_ID,DIFUNCT=2100-FFBF     #
      #                            -P(CODE)CODE=2100-FFBF,                           #
      #                            -Z(CONST)DATA20_C,DATA20_ID=2100-FFBF,10000-1FFFF #
      #                            -Z(CODE)INTVEC=FFA0-1FFFF                         #
      #                            -Z(CODE)RESET=FFFE-FFFF) -f
      From what you have said I understand that-
      The INTVEC segment is not starting from FFFF downwards as it is supposed to. So I checked the memory locations FFDF and found 2100 and FFD0 had address of the UCA0-TX ISR.
      But I wanted to know how to overcome this and is the program going into void because it can not find the ISR.
      Will I be able to use interrupts without correcting this problem.
      Report Abuse
      • Reply
    • sunil sharma
      on Sep 05 2011 09:26 AM
      Hi Michael
      tried the tutorials, they were working fine ....
      so just copied there initial declaration onto my pgm and ran... PC came to 2100
              NAME    main                    ; module name
              PUBLIC  main                    ; make the main label vissible      outside this module
              ORG     0FFFEh
              DC16    init                    ; set reset vector to 'init' label
              RSEG    CSTACK                  ; pre-declaration of segment
              RSEG    CODE                    ; place program in 'CODE' segment
      init:   MOV     #SFE(CSTACK), SP        ; set up stack-Initialize stackpointer
      main nop
      But still having the problem with the ISR even though its correct address is in the Int Vector table. The pgm goes into void on enabling GIE not the TX int
      --Secondly, Iam not able to get clock on oscilloscope on P7.3  .    Also saw SMCLK on P1.4 (after configuring P1SEL & P1DIR)  and  but it was not available.
      Thanks a lot for your help....
      Report Abuse
      • Reply
    • sunil sharma
      on Sep 05 2011 10:14 AM
      Hi Michael
      After changing the initial declarations Iam getting this error-
      The stack pointer for stack 'Stack' (currently Memory:0x65A84) is outside the stack range (Memory:0x20B0 to Memory:0x2100)
      Maybe as a result of this when Iam sigle-stepping
      my UCA0_TXBUF-SPI is not outputting the correct values from a stored location(0x01,2,3...) which it was doing earlier correctly.
      Instead it is showing 0x82,0x02,0xB2,0xA6 etc.
      Also I can now see the SMCLK on both the pins(7.3 and 1.4) only when I press GO. On single stepping there is no clock seen on the scope. Is the ok?
      Iam working on MSP communication with DSPC55 on mcBSP.
      Also when I run the pgm it goes in a loop and I have to break the operation. Any idea why this happens (interrupts?).
      The DSP side is not configured and running yet.
      Report Abuse
      • Reply
      on Sep 05 2011 12:04 PM
      Guru140630 points
      sunil sharma
      Actually, all segments have a start address and a size. They are not 'top-down'. However, INTVEC should end at 0xffff. I checked the datasheet, and it tells that the interrupt section begines at 0xFFC0. In your case, it is linked to 0xFFA0, and it therefore ends 32 bytes too early.
      I don't know where this (wrong) FFA0 start address for INTVEC comes from. Maybe a bug in the linker command script, or the wrong linker command script is loaded (wrong project config)?
      The addresses your source code did put into INTVEC are correct, relative to the (unfortunately wrong) start address of INTVEC.
      I'm sorry, but since I don't use IAR, I cannot help you further.
      You shoudl post the version of your compiler suite and maybe a screenshot of your project settings. perhaps someone else can give you some further advice.
      By just checking the device datasheets and the code and map file you posted, I doN't see a problem with your code itself. Only with what is created from this code.
      sunil sharma
      Yes. because the address of your ISR and your programdoesn't end up where it should, the processor does not know where to find them. It's like a PC when you remove the BIOS chip - it cannot boot even if the OS is properly installed on the HD.
      sunil sharma
      YOu won't be able to run a program at all without correcting this, as hte program applies to the start address of your main code as well as to the ISRs.
      There could be a quick and dirty hack that might work:
      add a '+32' at the end of the two ORG instructions. This should move th eentries 32 bytes further up in the address space, so they will land where the should be despite of the wrong start address of INTVEC. But that's a dirty hack (the cause of the problem still exists) and I'm not sure whether it will work at all. But it's surely worth a try while you wait for a 'real' solution.
      Report Abuse
      • Reply
      on Sep 05 2011 12:50 PM
      Verified Answer
      Guru140630 points
      sunil sharma
      ORG     0FFFEh
      This places the following word (which is teh address of your main code) explicitely at address 0xfffe, relative to the current segment. Hwoever, there is no current segment, so it ends up to be the absolute position.
      Many examples are done this way, which is, well, sufficient for a few code lines but absolutely inadequate or any project, even small size.
      Or it is a quick, dirty, and - worse - undocumented hack around a defective linker command script.
      Once again: your code was fine, it was the linker that was not acting as it should.
      sunil sharma
      There is a clock only if something was written to TXBUF. Adn onlywhile the content of TXBUF is being sent. It is nto a continuous clock. Only 8 pulses per byte and only while the byte is transmitted. Sicn eyour ISR is not called, nothing is written to TXBUF and nothing sent and therefore no clock signal. Also, during single-stepping, teh clocks are frozen as well as MCLK is. You'll oly see an occasional blip on the scope in the moment you do a single step.
      Perhaps you should repost your code in its current form again. You made several changes, so we cannot be sure that we talk about the same anymore.
      And, please, remove the double-linefeeds between the source code (shift-return instead of a normal return). It is very lengthy otherwise and difficult to read,
      Report Abuse
      • Reply
    12
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
