• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » eZ430 battery board test pins
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • eZ430 battery board test pins
    This question is not answered
    Chris Kocuba
    Posted by Chris Kocuba
    on Apr 06 2012 09:12 AM
    Prodigy120 points
    On the battery board for the eZ430 there are two points labeled 3.4 and 3.5 that come from the connector breakout. I assume that this means that those pins are connnect to the msp430BT5190; 3.4 to Port 3 bit 4 and 3.5 to Port 3 bit 5. So, I wrote a little program to test this but I did not get any results. Since these two pins can be used for general I/O, I assume that you SHOULD be able to put a logic "1" on either of these pins and read the voltage from the test pin to ground. Below is the code I wrote:
    #include "msp430.h"
    int main(void)
    WDTCTL = WDTPW + WDTHOLD; ///stop watch dog timer
    for (;;)
    P3SEL = 0x30;
    P3DIR = 0X30; //set port 3 bits4 and 5 direction to output
    P3OUT = 0X30; //set bits 4 and 5 high
    P1DIR = 0x02; // Set P1.0 to output direction
    P1OUT = 0x02; // Turn blue LED on
    I also tried setting the pins to logic 0 in case they were active low but that didn't produce the result I was looking for either. Am I approaching this the right way?
    battery board ez430 i/o
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Chester Gillon
      Posted by Chester Gillon
      on Apr 06 2012 18:01 PM
      Mastermind7335 points
      If you want use to use P3.4 and P3.5 for general I/O the following line should be removed:
      Chris Kocuba
      P3SEL = 0x30;
      The reason is setting P3SEL bits 4 and 5 selects P3.4 and P3.5 as module functions, rather than general I/O. See the Table 45. Port P3 (P3.0 to P3.7) Pin Functions in the MSP430BT5190 datasheet SLAS703
      Report Abuse
      • Reply
    • Chris Kocuba
      on Apr 09 2012 14:10 PM
      Prodigy120 points
      Thanks for the reply, Chester. However, upon removing that line or using P3SEL=0x00; to force all the pins to I/O, I still am not able to read a voltage at the test point on the battery board. Any further suggestions?
      Report Abuse
      • Reply
    • Chester Gillon
      on Apr 09 2012 15:28 PM
      Based upon EZ430U USB Debugging I/F Connector Pinout I guess that:
      a) What is labeled as "P3.4" on the battery board is connected to P10.4 on the MSP430BT5190
      b) What is labeled as "P3.5" on the battery board is connected to P10.5 on the MSP430BT5190
      (looks like the silkscreen on the battery board was originally for a different MSP)
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
