• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » Serial return from an ISR question
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • Serial return from an ISR question
    This question is not answered
    areben
    Posted by areben
    on Apr 07 2012 15:31 PM
    Prodigy40 points
    Hello
    I'm sure this is obvious, but I used the example code for hardware serial for the MSP430
    My problem is:
    The code never runs my while(1)
    The code returns "Hello World" when I send u
    The code does not toggle the pin when I send c
    Tips appreciated :D
    [code]
    #include "msp430g2553.h"
    #define BEEP_PIN BIT0
    const char string1[] = { "Hello World\r\n" };
    unsigned int charLoop;
    void main(void)
    WDTCTL = WDTPW + WDTHOLD; // Stop WDT
    BCSCTL1 = CALBC1_1MHZ; // Set DCO
    DCOCTL = CALDCO_1MHZ;
    P1SEL = BIT1 + BIT2 ; // P1.1 = RXD, P1.2=TXD
    P1SEL2 = BIT1 + BIT2 ; // P1.1 = RXD, P1.2=TXD
    UCA0CTL1 |= UCSSEL_2; // SMCLK
    UCA0BR0 = 104; // 1MHz 9600
    UCA0BR1 = 0; // 1MHz 9600
    UCA0MCTL = UCBRS0; // Modulation UCBRSx = 1
    UCA0CTL1 &= ~UCSWRST; // **Initialize USCI state machine**
    IE2 |= UCA0RXIE; // Enable USCI_A0 RX interrupt
    //set outputs
    P1DIR |= BEEP_PIN;
    P1OUT = 0x00; //clear port 1
    __bis_SR_register(LPM0_bits + GIE); // Enter LPM0, interrupts enabled
    while (1) {
    P1OUT ^= BEEP_PIN; // Toggle LED on P1.0
    __delay_cycles(1000000); // Wait ~100ms at default DCO of ~1MHz
    #pragma vector=USCIAB0TX_VECTOR
    __interrupt void USCI0TX_ISR(void)
    UCA0TXBUF = string1[charLoop++]; // TX next character
    if (charLoop == sizeof string1 - 1) // TX over?
    IE2 &= ~UCA0TXIE; // Disable USCI_A0 TX interrupt
    #pragma vector=USCIAB0RX_VECTOR
    __interrupt void USCI0RX_ISR(void)
    if (UCA0RXBUF == 'u') // 'u' received?
    charLoop = 0;
    IE2 |= UCA0TXIE; // Enable USCI_A0 TX interrupt
    else if (UCA0RXBUF == 'c')
    P1OUT &= BEEP_PIN;
    __delay_cycles(100000);
    P1OUT &= ~BEEP_PIN;
    [/code]
    ISR Serial Communication
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • areben
      Posted by areben
      on Apr 07 2012 15:50 PM
      Prodigy40 points
      Ok,
      Solved my own problem
      in the example code
      puts the CPU to sleep
      changing it to
      __bis_SR_register(GIE);
      worked
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
