• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » MSP430F2370 Timer CCIFG not resetting
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • MSP430F2370 Timer CCIFG not resetting
    This question is not answered
    James Yu
    Posted by James Yu
    on Apr 10 2012 23:03 PM
    Prodigy130 points
    I am using TimerA to implement a software UART but when CCIFG is set to 1 in TACCTL0 I assume that it has entered that interrupt, however during the interrupt I do TACCTL0 &= ~CCIFG to reset it back to 0, but it does not reset so I'm not sure if its actually entering the interrupt even though the flag is set. Can anyone help?
    Here is the code:
    * Copyright (C) 2006-2007 Texas Instruments, Inc.
    *ShreHarsha Rao - RFID Systems
    * All software and related documentation is provided "AS IS" and
    * without warranty or support of any kind and Texas Instruments
    * expressly disclaims all other warranties, express or implied,
    * including, but not limited to, the implied warranties of
    * merchantability and fitness for a particular purpose. Under no
    * circumstances shall Texas Instruments be liable for any
    * incidental, special or consequential damages that result from
    * the use or inability to use the software or related
    * documentation, even if Texas Instruments has been advised of
    * the liability.
    * Unless otherwise stated, software written and copyrighted by
    * Texas Instruments is distributed as "freeware". You may use
    * and modify this software without any charge or restriction.
    * You may distribute to others, as long as the original author
    * is acknowledged.
    //Program with hardware USART and
    //paralel communication interface
    //with TIR reader chip.
    //PORT 4.0-4.7 - (IO0-IO7) for parallel interface with reader chip
    //PORT3.4 - PORT3.5 - USCI_A0 ---> USB/UART control signals
    //PORT2.1 - IRQ
    //PORT3.3 - DATA_CLK
    //PORT1.7 - PORT1.3 - signaling LEDs
    #define DBG        0
    #include <MSP430x23x0.h>
    #include <stdlib.h>        //Processor specific definitions
    #include <stdio.h>
    #include "hardware.h"
    #include "parallel.h"
    #include "anticollision.h"
    #include "globals.h"
    #include "tiris.h"
    #include "14443.h"
    #include "host.h"
    #include "epc.h"
    #include "automatic.h"
    char rxdata;            //RS232 RX data byte
    unsigned char buf[BUF_LENGTH];
    signed char RXTXstate;    //used for transmit recieve byte count
    unsigned char flags;    //stores the mask value (used in anticollision)
    unsigned char RXErrorFlag;
    unsigned char RXflag;        //indicates that data is in buffer
    unsigned char i_reg;    //interrupt register
    unsigned char counter;
    unsigned char CollPoss;
    #include "msp430g2231.h"
    #include "stdbool.h"
    #define TXD BIT1 // TXD on P1.1
    #define RXD BIT2 // RXD on P1.2
    #define Bit_time 104 // 9600 Baud, SMCLK=1MHz (1MHz/9600)=104
    #define Bit_time_5 52 // Time for half a bit.
    unsigned char BitCnt; // Bit count, used when transmitting byte
    unsigned int TXByte = 1; // Value sent over UART when Transmit() is called
    unsigned int RXByte = 1; // Value recieved once hasRecieved is set
    bool isReceiving; // Status for when the device is receiving
    bool hasReceived; // Lets the program know when a byte is received
    // Main function with init and an endless loop
    void Transmit(void);
      void main(void) {
        // initialize peripherals
        WDTCTL = WDTPW + WDTHOLD;             // Stop WDT
        UARTset();
        EnableSet;
        TRFDisable;
        delay_ms(1);
        TRFEnable;
        delay_ms(1);
        BCSCTL1 = CALBC1_1MHZ; // Set range
    DCOCTL = CALDCO_1MHZ; // SMCLK = DCO = 1MHz
    P4SEL |= BIT4;
    P4DIR |= BIT4;
    P1IES |= RXD; // RXD Hi/lo edge interrupt
    P1IFG &= ~RXD; // Clear RXD (flag) before enabling interrupt
    P1IE |= RXD; // Enable RXD interrupt
    isReceiving = false; // Set initial values
    hasReceived = false;
    while(1)
    {Transmit();}
    __bis_SR_register(GIE); // interrupts enabled
    while(1)
    if (hasReceived) // If the device has recieved a value
    hasReceived = false; // Clear the flag
    TXByte = RXByte; // Load the recieved byte into the byte to be transmitted
    Transmit();
    if (~hasReceived) // Loop again if another value has been received
         __bis_SR_register(CPUOFF + GIE);
    // LPM0, the ADC interrupt will wake the processor up. This is so that it does not
    // endlessly loop when no value has been Received.
        //Add logic for SPI/parallel selection.
        if (SPIMODE)
        { //Set Port Functions for Serial Mode
            EnableSet;
        irqPINset;
        irqEDGEset;            /* rising edge interrupt */
        LEDallOFF;
        LEDportSET;
        else
          PARset();     //Set Port Functions for Parallel Mode
        /* Use the DCO to program the SPI first*/
         if (SPIMODE)
          #ifndef SPI_BITBANG
                USARTset();       //Set the USART */
          #else
                SlaveSelectPortSet  // P3.0 - Slave Select
                SlaveSelectHIGH     // Slave Select - inactive ( high)
                SIMOSet
                clkPOUTset;
         #endif
    //test code
         TRFDisable;
         TRFEnable;
         delay_ms(1);
    //end test code
        InitialSettings();                  // Set MCU Clock Frequency to 13.56 MHz and OOK Modulation
        /*Now switch from DCO to external 13.56 MHz clock*/
        OSCsel(0x00);       //set the oscilator
        delay_ms(10);
        /*Re-configure the USART with this external clock*/
         if (SPIMODE)
           #ifndef SPI_BITBANG
                USARTEXTCLKset();       //Set the USART */
           #endif
        EnableInterrupts;                    // General enable interrupts
        delay_ms(10);
        LEDpowerON;
        OOKdirIN;            //set OOK port tristate
        ENABLE = 1;
        POLLING = 1;
        FindTags(0x00);
    void Transmit()
       while(isReceiving); // Wait for RX completion
       CCTL0 = OUT; // TXD Idle as Mark
       TACTL = TASSEL_2 + MC_2; // SMCLK, continuous mode
       BitCnt = 0xA; // Load Bit counter, 8 bits + ST/SP
       CCR0 = TAR; // Initialize compare register
       CCR0 += Bit_time; // Set time till first bit
       TXByte |= 0x100; // Add stop bit to TXByte (which is logical 1)
       TXByte = TXByte << 1; // Add start bit (which is logical 0)
       CCTL0 = CCIS0 + OUTMOD0 + CCIE; // Set signal, intial value, enable interrupts
       while ( CCTL0 & CCIE ); // Wait for previous TX completion
    // === end of main =====================================================
    #pragma vector=PORT1_VECTOR
    __interrupt void Port_1(void)
    isReceiving = true;
    P1IE &= ~RXD; // Disable RXD interrupt
    P1IFG &= ~RXD; // Clear RXD IFG (interrupt flag)
       CCR0 += Bit_time_5; // Set time till first bit
    CCTL0 = OUTMOD1 + CCIE; // Dissable TX and enable interrupts
    RXByte = 1; // Initialize RXByte
    BitCnt = 0x9; // Load Bit counter, 8 bits + ST
    // Timer A0 interrupt service routine
    #pragma vector=TIMERA0_VECTOR
    __interrupt void Timer_A (void)
      CCTL0 &= ~CCIFG;
    if(!isReceiving)
    CCR0 += Bit_time; // Add Offset to CCR0
    if ( BitCnt == 0) // If all bits TXed
       TACTL = TASSEL_2; // SMCLK, timer off (for power consumption)
    CCTL0 &= ~ CCIE ; // Disable interrupt
    else
    CCTL0 |= OUTMOD2; // Set TX bit to 0
    if (TXByte & 0x01)
    CCTL0 &= ~ OUTMOD2; // If it should be 1, set it to 1
    TXByte = TXByte >> 1;
    BitCnt --;
    else
    if ( BitCnt == 0)
    P1IFG &= ~RXD; // clear RXD IFG (interrupt flag)
    P1IE |= RXD; // enabled RXD interrupt
    if ( (RXByte & 0x201) == 0x200) // Validate the start and stop bits are correct
    RXByte = RXByte >> 1; // Remove start bit
    RXByte &= 0xFF; // Remove stop bit
    hasReceived = true;
       __bic_SR_register_on_exit(CPUOFF); // Enable CPU so the main while loop continues
    else
    if ( (P1IN & RXD) == RXD) // If bit is set?
    RXByte |= 0x400; // Set the value in the RXByte
    RXByte = RXByte >> 1; // Shift the bits down
    BitCnt --;
    James
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Jens-Michael Gross
      Posted by Jens-Michael Gross
      on Apr 11 2012 10:26 AM
      Guru140135 points
      I'm not sure what your problem/quesiton is.
      Where do you look at CCIFG? How do ou know it is set?
      Doe syour code not work? If so what doesn't work?
      If you set a breakpoint inside the TIMERA0 _VECTOR, teh CCIF Gbit in TACCR0 is automatically cleared when teh ISR is entered. However, at the moment the debugger has fetched all data to present it to you, chances are that another interrupt has been already triggered in the meantime. The world doesn't stop turning just because the debugger hit a breakpoint.
      Even in main it is possible that an 'if (CCR=&CCIFG)' block in main is entered even though any possible interrupt should be handled by the ISR.
      It may be that the check was performed the very moment the IFG bit was set. So the ISR will be triggered and executed right after the check - however, the check was positive, even if only for one MCLK cycle.
      And as long as GIE is clear (and it is always clear implicitely while an ISR is executed) no interrupts are executed at all (else an ISR would infinitely interrupt itself)
      _____________________________________
      Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
      If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
      Report Abuse
      • Reply
    • James Yu
      Posted by James Yu
      on Apr 11 2012 11:53 AM
      Prodigy130 points
      I'm using IAR to watch the registers and it shows that once CCIFG gets set it doesn't clear, furthermore the last line of my code in the Transmit() function waits for CCIE to be cleared in the ISR, but when I step through my code it doesn't get past that line which suggests the ISR was never executed.
      Report Abuse
      • Reply
      on Apr 11 2012 13:47 PM
      Guru140135 points
      James Yu
      while(1)
      {Transmit();}
      Your code gets stuck in the while before it reaches the line that sets GIE and enables interrupts. If GIE is clear, interrupts are globally disabled, which is the power-on default.
      I didn't read further, so maybe there is more, but my office hours are over now :)
      Report Abuse
      • Reply
    • James Yu
      Posted by James Yu
      on Apr 11 2012 13:50 PM
      Prodigy130 points
      Ah I see! Can't believe I missed that, thanks!
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
