• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » It is possible to compute a 1024 points of FFT in msp430??
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • It is possible to compute a 1024 points of FFT in msp430??
    This question is not answered
    karthik raja
    Posted by karthik raja
    on Apr 11 2012 06:47 AM
    Intellectual840 points
    hi all..
        i need to know it is possible to compute a 1024 points FFT in msp430 controller or else what kind of controller will suit for my application ??
    what will be the approximate time required to compute 1024 point FFT.. ??
    where can i get the efficient source code for computing FFT??
    MSP430 Code Examples MSP430 microcontroller
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Jens-Michael Gross
      Posted by Jens-Michael Gross
      on Apr 11 2012 10:47 AM
      Guru139970 points
      Why not?
      For FFT computation there are two limits: size and speed.
      There are MSPs with up to 16k ram, so unless you need 80bit floatign poitn calculations, those will have sufficient ram for the calculation. Speed, however, may be an issue. If oyu use plain standard C code and expect it to do a realtime FFT for HF signals, then you're better off with a supercomputer. However, the calculation itself can be done by the MSP. It just takes some time. Less, if you use integer of fixed point arithmetics instead of floating point calculations. Handcoded assembly code that makes use of the multiply-accumulate features of teh hardware multiplier wouldn't be a bad idea too :)
      _____________________________________
      Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
      If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
      Report Abuse
      • Reply
    • karthik raja
      on Apr 11 2012 22:50 PM
      thanks for your reply jens.. what will be the approximatime in msp 430 to  compute a1024 size FFT
      Report Abuse
      • Reply
      on Apr 12 2012 07:04 AM
      Guru139970 points
      The ram requirements depend on algorithm and precision.
      The 'biggest' MSPs, ram-wise, are the 54xx devices with 16k. (well, the ones with internal USB have another 2k which can be also used for data when USB is not used).
      The 5438A has also 256k flash (which you can use to store lots of tables to speed up the calculations), and operates with up to 25MHz. It has a 32bit hardware multiplier and lots of peripherlas for data transfer (e.g. up to 4 serial ports, SPI, I2C, and enough GPIO pins to even simulate a parallel bus for external mass storage)
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
