• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » Interfacing mspf5438 with microcontroller
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • Interfacing mspf5438 with microcontroller
    This question is not answered
    ATHULYA K
    Posted by ATHULYA K
    on Apr 13 2012 06:25 AM
    Prodigy50 points
    Is it possible to send  data from mspf5438a to any microcontroller(8051)? Can any one suggest some solution??
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Jan
      Posted by Jan
      on Apr 13 2012 07:03 AM
      Expert1425 points
      The most basic way is via serial communication. You can use SPI, I2C if there is a "master" or normal RS-232/UART if you prefer or need bidirectional communication. Any of these can be realized with you MSP. One thing to remember is, that your system had equal supply voltage levels or that you need to take care of level translation when interfacing for example a 5V system.
      "Full" RS-232 would have level shifters as MAX232 or MAX3232 to bring logic levels to RS232 levels (and invert them) of +/- 15V - but one can easy omit them, if both systems use the same levels.
      Jan
      Oxfam Trailwalker 2012 - Runner
      Found any horribly english mistakes? - Drop me a note as private conversation via my profile if you like ;-)
      Report Abuse
      • Reply
    • ATHULYA K
      Posted by ATHULYA K
      on Apr 13 2012 08:34 AM
      Prodigy50 points
      Can 89C51 directly read from the memory of  MSPF5438??
      Report Abuse
      • Reply
    • Jan
      Posted by Jan
      on Apr 13 2012 08:52 AM
      Expert1425 points
      No, as an MSP does not have an outside memory bus where you could attach. So you need to go via some interface somehow. Of course you could build an memory bus interface with the port pins - but that's a waste of pins.
      Jan
      Report Abuse
      • Reply
    • Andy Neil
      Posted by Andy Neil
      on Apr 13 2012 13:45 PM
      Guru31775 points
      Think about it: the MSP430 neither knows nor cares what is attached to its interfaces; it just sends stuff to them, and receives stuff from them - it is irrelevant where the sent stuff goes to, and where the received stuff comes from.
      So you can use any interface you like - so long as both devices can support it.
      As already noted, the async serial link is probably the commonest; but there's also SPI, I2C, etc, etc,...
      Or you can devise your own bit-bashed serial or parallel interface...
      Report Abuse
      • Reply
    • TonyKao
      Posted by TonyKao
      on Apr 13 2012 14:25 PM
      Genius3770 points
      Andy Neil
      As matter of fact, there's an interesting implementation of MCU-to-MCU DMA transfer between two MSP430s that mimics a parallel bits strobe interface using TimerA and GPIOs. If you can sync your MCU with the MSP430 (eg clock both with MCLK) then theoretically you can get a byte transfer every two cycles (from the MSP430).
      Of course this does not include any protocol/sync overhead, error correction and detection, IO and DMA capability of the other controller, Endian-ness, etc etc...
      See Peters, D et al. 2009. "An Energy Efficient Parallel Embedded System for Small Satellite Applications". ISAST Transactions on Computers and Intelligent Systems. 2(1):8-16.
      http://www.isastorganization.org/ISAST_CIS0101.pdf
      Tony
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
