• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » MSP430F5xx USB - UART max frequency 1 MBAUD?
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • MSP430F5xx USB - UART max frequency 1 MBAUD?
    This question is not answered
    Todd Anderson78572
    Posted by Todd Anderson78572
    on Apr 17 2012 14:43 PM
    Expert2800 points
    All:
    The UART spec is 1 MBAUD. I have an application where the ideal BAUD rate is 1.024 MBAUD - how flexible is the spec in this regard?
    If we cannot get to t 1.024  MBAUD, then, we would have to back off to 512 KBAUD.
    All of this is because of the processor being connected to the MSP430, and the inflexibility of the clocking that it can use.
    Todd Anderson
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • TonyKao
      Posted by TonyKao
      on Apr 17 2012 15:43 PM
      Genius3770 points
      Hi Todd,
      If you're sourcing the UART with an accurate clock source (eg crystal and preferably one that divides nicely into 1.024MHz) then I don't see why you cannot do 1.024Mbaud.
      However, you should test the transmit-receive error rates at both 1.024MBaud and 512KBaud and see if they are acceptable, and make your decision that way.
      Tony
      Report Abuse
      • Reply
    • Jeff Tenney
      Posted by Jeff Tenney
      on Apr 18 2012 11:08 AM
      Guru10795 points
      Todd,
      My guess is that nobody (not even TI engineers who visit this forum) will officially sanction the use of UART above 1MBaud.
      But you are so close that it should work.  Keep in mind that baud rates that high can fail with poor line transceivers, so hopefully you're not using transceivers and you are instead dealing with a TTL or logic-level interface.
      One sticky point is the deglitch logic, which requires the bit to be at least 600ns.  At 1.024MBaud, each bit is 976ns, so you just need to make sure the edges are clean and sharp.
      And for receiving that data rate on MSP430, I'm guessing you plan on making friends with the DMA controller.
      Jeff
      Report Abuse
      • Reply
    • Jens-Michael Gross
      Posted by Jens-Michael Gross
      on Apr 18 2012 11:26 AM
      Guru140610 points
      Todd Anderson78572
      The spec isn't flexible. This is why it is a spec. However, the UART may or may not work with a higher clock. There is no reason why it should work up to 1MBd, but at 1000001Bd it stops working.
      However, up to 1MBd you can blame TI if it doesn't work. Above you're on your own. And the further you stray from the spec limit, the higher the chance that one or another (or all) MSPs will cease to function.
      1.024MBd isn't that far, so chances are you'll never have problems with it. But be prepared that perhaps every now and then one MSP will refuse to do it. Mostly on the receiving direction, as this is the more fragile one.
      _____________________________________
      Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
      If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
