• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » Using the MSP-FET430UIF
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • Using the MSP-FET430UIF
    This question is not answered
    Francois Ingelrest
    Posted by Francois Ingelrest
    on Apr 30 2012 07:17 AM
    Prodigy150 points
    Dear all,
    Although we've been using MSP430 devices for some time, we've just started to use TI tools to do so. We've installed CCS 5 successfully and are able to compile code and generate TI-TXT files that we upload with Softbaugh JTAG.
    We would like to get rid of Softbaugh devices, so we would need to be able to upload compiled images to the MSP430 using the MSP-FET430UIF. Is that even possible? The only way we've found to upload code with that device is to start debug mode in CCS. There is no menu dedicated to the device, and actually we're even unable to upload code in release mode.
    Also, it's impracticable for us to ask our subcontractor to install CCS in order to flash the MSP430 embedded in the boards they produce for us. Isn't there a simple application, independent from CCS, to do this? We don't want to give them our source code, we want to give them only the compiled image.
    Thanks in advance for any help about this issue.
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Jens-Michael Gross
      Posted by Jens-Michael Gross
      on Apr 30 2012 11:45 AM
      Guru141810 points
      TI doesn't provide an offline-programming tool for the FET430UIF. I think this functionality is limited to their GANG programmer (which is the designated production tool). The upload through the FET430UIF is only done within the development chain (compiler-linker-debugger).
      However, the free Elpotronic lite FET-pro430 software does the job.
      _____________________________________
      Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
      If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
      Report Abuse
      • Reply
    • Katie Enderle
      Posted by Katie Enderle
      on Apr 30 2012 16:06 PM
      Genius13415 points
      You may want to reference this wiki page for how to generate binary files in CCS and then load them using the FET tool (this uses the Elprotronic software like Jens-Michael suggests): http://processors.wiki.ti.com/index.php/Generating_and_Loading_MSP430_Binary_Files
      You can also take a look at the MSP430 Flasher command line utility here, which can be used with the MSP-FET430UIF to load .txt/.hex files (these can be generated from CCS): http://processors.wiki.ti.com/index.php/MSP430_Flasher_-_Command_Line_Programmer
      For a factory setting with mass production, however, you may want to consider the MSP-GANG programmer instead of the MSP-FET430UIF - this can very quickly program up to 8 devices at a time.
      Katie
      Please click the Verify Answer button on this post if it answers your question.
      Report Abuse
      • Reply
    • Francois Ingelrest
      on May 01 2012 02:16 AM
      Prodigy150 points
      Thanks for your answers.
      We've tried using the Elprotronic software but it somehow requires a different firmware for the MSP-FET430UIF. If we refuse to do the firmware upgrade, programming fails. If we accept, programming works but then CCS complains that the firmware must be updated before entering a debugging session.
      Is that normal? Does this mean that the firmware for "simply programming" is different from the firmware for debugging?
      Report Abuse
      • Reply
      on May 06 2012 02:48 AM
      Prodigy150 points
      Any information about this? Flashing a new firmware each time is kind of painful.
      Report Abuse
      • Reply
      on May 07 2012 13:25 PM
      Guru141810 points
      Fran��ois Ingelrest
      Not exactly. But the features of the FET have been improved/updated more than once in the last years. And different software may be written to support a different version of the FET firmware. Especially the step to the new V3 MSP430Lib was an incompatible one.
      If you have an older compiler but the laterst version of the Elprotronic tool, this might be the source of your problems.
      But you should write a mail to Elprotronic. The guys there are very helpful and may provide an older version of the tool or other info how to solve this. i remember that you're not the first one with this problem. There is an older thread in this forum about the same situationand also a solution. Maybe the search function can dig it out for you. ('elprotronic' should be a good keyword to search for, maybe combined with 'update'
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
