• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » Series resistor with spy-bi-wire
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • Series resistor with spy-bi-wire
    This question is answered
    Armando Barbedo
    Posted by Armando Barbedo
    on May 04 2012 09:02 AM
    Prodigy240 points
    Can I add series resistors to the two spy-bi-wire lines SBWTDIO and SBWTCK so to improve ESD protection? If so, what would be the maximum value before it interferes with the programming? What document contains that kind of information?
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Jens-Michael Gross
      Posted by Jens-Michael Gross
      on May 04 2012 09:51 AM
      Guru139900 points
      A series resistor between SBWTCk and RST would increase the negative (low-pass) effect of an attached startup capacitor.
      However, the FET may already have a series resistor on its output, to prevent FET damage by a damaged target.
      _____________________________________
      Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
      If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
      Report Abuse
      • Reply
    • Armando Barbedo
      on May 06 2012 19:52 PM
      Prodigy240 points
      My intent is not to protect the programmer, but the target. I do not want to expose JTAG pins without any protection against transients. The question is: how big of a SERIES resistor can I use without compromising programming and debugging.
      Report Abuse
      • Reply
      on May 07 2012 13:57 PM
      Guru139900 points
      Armando Barbedo
      Yes, I understand. But I don't have an answer for you, It depends on capacitance behind the resistor.
      JTAG uses a signal frequency in the MHz range. So even 1k can make a difference.
      I really connot give you an advice here. But I never burnt a JTAG port by ESD/transients over the last years. And we had a lot of field updates in industrial environments.
      All MSP port pins have internal clamp diodes with a rated maximum current of 2mA. There must be really fast transients to get past them. Or high energy to overload them.
      The only series transistors I ever applied to MSP pins were to protect the input pins from overcurrent caused by accidental (or sometimes even intentional) 5V signal input.
      However, if you want to make own experiments (just put a resistor there and then try how big it can be without disturbing JTAG/SBW) you can paste your results here. (and it will probably give faster results than waiting for an answer here) :)
      Hint: if you found the value big enough to stop JTAG, then use at max 1/2 of it, just to be on the safe side.
      Report Abuse
      • Reply
    • Lenio Cacula
      Posted by Lenio Cacula
      on May 29 2012 14:31 PM
      Verified Answer
      Verified by Armando Barbedo
      Intellectual1920 points
      Hi, Armando,
      SBWTDIO/RESET should be <22 Ω and the SBWTCK/TEST should be <100Ω. The programmer already has some resistance in series and the combination of resistance in the board would prevent reliable operation.
      Report Abuse
      • Reply
    • old_cow_yellow
      Posted by old_cow_yellow
      on May 29 2012 18:38 PM
      Guru25715 points
      It also depends on what are on the "tool" side of those two signal lines. On the Launchpad, TI is using the MSP430F1611 GPIO pins directly (without any resistor). In rev 1.4 and earlier, they also had a 2nF on the SBTDIO/RSET signal. The SBW works but without much margin. In rev 1.5, TI decided not to load that 2 nF. SBW is still marginal.
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
