Where in the documentation or in which file can I find all the vector calls for my part? For example
#pragma vector = USCI_A0_VECTOR__interrupt void USCI_A0_ISR(void)
I found this because it was an example in the manual but what about a full list of them? I have a reset occuring when I get an interrupt from one of my capture compare registers because I am obviously not using the correct vector pragma call. Please advise.
TB0CCTL1 |= CCIE; followed by an interrupt is going off to a vector address but I don't know where and to what.
You will find the definition in the msp430.h file you include in the c source file. You may be using a specific header file for the part number you ate targeting.
The interrupt vectors implemented on the device will be defined there and in the device datasheet.
Brandon
Robert Scaccia what about a full list of them
However, this list doesn't contain the exact symbol names as provided by the msp430xXXX.h header files. But the two together tell you the "whole story". :)
Robert ScacciaUSCI_A0_ISR
_____________________________________Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
