• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » current capability of I/O ports?
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • current capability of I/O ports?
    This question is answered
    assaf laufer
    Posted by assaf laufer
    on May 22 2012 03:57 AM
    Intellectual270 points
    How much current can i drive from one of the pins of the i/o ports of MSP430FR5739?
    I couldnt find it in the datasheet
    I need at least 30mA from one pin
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Jens-Michael Gross
      Posted by Jens-Michael Gross
      on May 22 2012 08:58 AM
      Verified Answer
      Verified by assaf laufer
      Guru140435 points
      assaf laufer
      What about the 'Typical characteristics - Outputs' diagrams?
      It tells, that with VCC=3V and an output current of 30mA on 25°C temperature, the output voltage drops down to 0.9V.
      _____________________________________
      Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
      If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
      Report Abuse
      • Reply
    • Leo Hendrawan
      Posted by Leo Hendrawan
      on May 22 2012 10:20 AM
      Verified Answer
      Mastermind27500 points
      JMG is right. There is basically almost "no limit" on the maximum current sourced out/sinked in from/zo MSP430 pin. The only limitation is the voltage output drop/rise on the output pin which might effect your digital logic. This is discussed in the following wiki entry:
      http://processors.wiki.ti.com/index.php/Digital_I/O_%28MSP430%29#For_Outputs
      Leo Hendrawan
      GPIO current maximum maximum I/O current
      Report Abuse
      • Reply
    • Chester Gillon
      Posted by Chester Gillon
      on May 22 2012 15:15 PM
      Verified Answer
      Verified by Leo Hendrawan
      Mastermind6315 points
      lhend
      What about absolute maximum current through the MSP430 supply pins or absolute maximum junction temperature?
      While the MSP430FR5739 datasheet SLAS639A doesn't define the absolute maximum supply current it does define an absolute maximum junction temperature. An increase in the voltage drop/rise on an output means the internal power consumption is increasing which raises the junction temperature. It should be possible to determine the absolute maximum power consumption based upon the thermal resistance of the package and maximum ambient temperature.
      Report Abuse
      • Reply
    • Leo Hendrawan
      on May 23 2012 02:14 AM
      Hi Chester,
      nice point you got here. Yes i forgot to mention the limitation of the junction temperature caused by the high current. This should be the other important thing to be noticed.
      Leo Hendrawan
      Report Abuse
      • Reply
    • Avi Chami1
      Posted by Avi Chami1
      on May 23 2012 07:11 AM
      Mastermind7405 points
      Another five cents on this issue, according John Davies excellent book about the MSP430, "the product information center recommends that the current should be limited to 4 or 5mA per pin and 25mA per port". There is a section in his book addressing the issue of driving heavier loads with the MSP.
      Report Abuse
      • Reply
      on May 24 2012 06:28 AM
      Guru140435 points
      Albert_83
      This once was true for the 1x devices. The 5x family even has a 'drive strength' setting and the port pins are specified for much higher currents. IIRC, the total current on one port shouldn't exceed 48mA then to keep the specified voltage drop.
      Also, there are current/voltage diagrams available in the datasheets which allow you to calculate everything needed (including power: voltage drop*current. Simple math).
      If everything were explicitely written in the datasheet, one wouldn't need engineers to do microcontroller development. You could pick any child that can read from the street and let it do the job :)
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
