There are no specific suggestion in the User or Hardware manual for MSP430F47197 for capacitor value for the following AVcc and DVcc : Pin8, Pin64, Pin 92.
Question:
0) We are planning to use a 0.1uF ceramic cap, is this sufficient in design?
1) Does TI have default recommendation of the capacitor value to use on these Vcc pins as a suggestion? (I know it depends on design but all design is always based on suggestion, then improving from the suggestion)
2) How much noise is allowed on the Vcc lines?? (or how much Vpp noise can the power supply take? (typically manufacturers allow 50mVpp but I could not locate any information regarding this)
3) Are there any noise concerns we should be aware of from the Vcc lines when using 16MHz internal CLK?
D.T.
