• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » msp430f6726 XT1
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • msp430f6726 XT1
    msp430f6726 XT1
    This question is not answered
    xiang ji
    Posted by xiang ji
    on Jun 28 2012 00:22 AM
    Prodigy70 points
    Hello everybody!
    I have a problem with starting XT1 crystal oscillator in 32.768 KHz mode on MSP430F6726. It just does not start. The scope attached to the ACLK monitoring pin shows No frequency .
    I use none external caps on both XT1 pins.
    I tried the code below on msp430f6726.
    void main(void)
        WDTCTL = WDTPW | WDTHOLD;               // Stop WDT
      __delay_cycles(0x600);
      UCSCTL6 &= ~(XT1OFF);
      UCSCTL6 &=~ (XTS);// enalbe XT1 and set XT1Drive
      UCSCTL6 |= (XT1DRIVE_3);  // enalbe XT1
      while (SFRIFG1 & OFIFG) {   // check OFIFG fault flag
        UCSCTL7 &= ~XT1LFOFFG;  // Clear OSC flaut Flags  (DCOFFG+XT1LFOFFG+XT2OFFG)
        UCSCTL7 &= ~DCOFFG;
        SFRIFG1 &= ~OFIFG;        // Clear OFIFG fault flag
      }                                          ; wait for crystal osc. to start
    I would appreciate any advise for a direction to follow. The problem drives me crazy,
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • xiang ji
      Posted by xiang ji
      on Jun 28 2012 00:27 AM
      Prodigy70 points
      Report Abuse
      • Reply
    • Argail
      Posted by Argail
      on Jun 28 2012 02:10 AM
      Expert1510 points
      I think you simply forget to enable the ACLK ouput on pin, you have to set the correspondig PxSEL register.
      Report Abuse
      • Reply
    • xiang ji
      Posted by xiang ji
      on Jun 28 2012 02:18 AM
      Prodigy70 points
      thanks
      I have enable the ACLK ouput on pin,  The scope attached to the ACLK monitoring pin shows 10kHz frequency in VLO  .
      Report Abuse
      • Reply
    • Argail
      Posted by Argail
      on Jun 28 2012 06:24 AM
      Expert1510 points
      Try to set the load capacitance to XCAP_3 (or to match load with crystal)
      Report Abuse
      • Reply
    • xiang ji
      Posted by xiang ji
      on Jun 28 2012 09:02 AM
      Prodigy70 points
      thanks!
      I have trying to set the load capacitance from XCAP_0 to XCAP_3  .
      I will try again.
      Report Abuse
      • Reply
    • xiang ji
      Posted by xiang ji
      on Jun 28 2012 22:09 PM
      Prodigy70 points
      I have try to set the load capacitance from XCAP_0 to XCAP_3  again. XT1  does not start.
      Report Abuse
      • Reply
    • Jens-Michael Gross
      Posted by Jens-Michael Gross
      on Jun 29 2012 07:22 AM
      Guru140135 points
      xiang ji
      Sometimes it's a hardware problem :)
      Shortcuts between adjacent pins, flux remains under the MSP, bad soldering of the MSP pin - all this has happened in th epast and can cause the crystal to fail.
      Layout of the PCB is also a factor. Short traces, no GND layer directly below these traces (because this adds stray capacitance)
      _____________________________________
      Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
      If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
      Report Abuse
      • Reply
    • Metin Gunsay
      Posted by Metin Gunsay
      on Aug 06 2012 13:18 PM
      Prodigy10 points
      I'm having this same problem.  Under no circumstances can I get the XT1 to oscillate on the MSP430F6723.  I've tried every combination of XCAP and XDRIVE.  I've tried different crystals, including the one recommended in the data sheet.  I've tried external caps.   I've also tried building multiple boards.  Nothing works.
      I'm not new to the MSP family, and have never had these sorts of problems with XT1.
      It also appears that the oscilator fault flags do not work.
      I'm curious if anyone out there - including TI -  has gotten the XT1 to work in LF mode?
      I'd just like to know if it's possible or not, or if this is some sort of hardware bug.
      MSP430F6723
      Report Abuse
      • Reply
    • xiang ji
      Posted by xiang ji
      on Aug 06 2012 21:03 PM
      Prodigy70 points
      I has solved this problem. AUXVCC3 must be connected to Vcc. XT1 power is supplied by AUXVCC3. Wish this help you.
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
