• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » MSP430F5324 XT2 ESD Issue
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • MSP430F5324 XT2 ESD Issue
    This question is answered
    Jordan Zhou
    Posted by Jordan Zhou
    on Jul 10 2012 05:05 AM
    Intellectual820 points
    F5324 faced one problem from customer site, when XT2 12MHz (passive) is used for MCLK, the system can not pass ESD 8KV, group pulse 2KV. Reset and crash always happen.
    But in these cases, F5324 can pass:
    1) Internal DCO instead of XT2;
    2) XT1 32K;
    3) XT2 active 12MHz.
    Note: XT2 is the only solution for customer funtion request. The PCB is small size.
    Hope to get your support.
    Jordan
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Jens-Michael Gross
      Posted by Jens-Michael Gross
      on Jul 11 2012 15:35 PM
      Verified Answer
      Verified by Jordan Zhou
      Guru141810 points
      I don't think there is a solution.
      In all cases where the device passes the 8kV test, MCLK is either driven by internal DCO or by a stable external clock signal.
      In case of the 12MHz passive XT2 (a crystal), the ESD causes the crystal to turn into an e.g. 48MHz crystal for one cycle. Which will of course crash the MSP.
      A possible solution would be to use a 24MHz crystal isntead and use a /2 divider for MCLK. THen MCLK will be the averaged result of two crystal cycles (4 would be even better, but I don't knwo whether an 48MHz crystal can be used at all) and the result will likely be still in the allowed operating range.
      BTW: the same problem can happen when you switch teh RSEL value for the DCO: one erroneously short clock cycle that may crash the MSP. Solution is the same: use a MCLK divider during the switch)
      _____________________________________
      Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
      If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
      Report Abuse
      • Reply
    • Roberto Romano
      Posted by Roberto Romano
      on Jul 11 2012 15:45 PM
      Mastermind7695 points
      Jordan Zhou
      Hi Jordan, ESD failure can result from a set of different path, if all part of circuits are ok I can think about ungrounded XTAL case or bad layout around xtal pins coupling EMF to oscillator tracks. To be of some help the layout of ground and oscillator tracks are needed to inspect for weak ESD/EMF screening.
       Roberto
       Please login & click    Verify Answer    if this post answered your question.
      Report Abuse
      • Reply
    • Jordan Zhou
      on Jul 12 2012 09:08 AM
      Thanks for your reply. I'll try with 24MHz and 2 divider.
      Jordan
      Report Abuse
      • Reply
    • Jordan Zhou
      on Aug 07 2012 03:32 AM
      Can you help to provide some info about MSP430F5xx and MSP430F2xx XT2 difference.
      As I know, the voltage amplitude on F247 XT2 is over 1V; while F5324 is lower than 0.5V. Why is the difference?
      Thanks.
      Jordan
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
