• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » Understanding SPI
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • Understanding SPI
    Understanding SPI
    This question is answered
    Adam Zehavi
    Posted by Adam Zehavi
    on Jul 28 2012 06:37 AM
    Intellectual875 points
    I've been looking at SPI implementations for the last two days, and again, I feel like this is too technical, plus with my limited knowledge about embedded, I just feel lost.
    I've read a couple of posts here, and copy pasted some code, but I have no idea where to start.
    I'm using the MSP430F5438 microprocessor on our prototype, and if I got it right from the datasheet, it has 4 SPIs?
    My situation is such, I have two serial slave components I need to program on initialization, and read data from while the application is running, to be more specific, temperature and accelerometer.
    So I'm wondering, according to this on page 57, it seems that the same SPI can be used for multiple devices, is my understanding correct?
    I've also had trouble with understanding which registers control what from the datasheet, there is a long register list, and it seems that most of these have many functions, how can distinguish what I need from the list?
    Adam.
    Adam Zehavi.
    Java Developer & Architect
    Nu-Art Software
    LinkedIn
    Twitter
    To be a good student, you must first be a good teacher.
    MSP430F5438 SPI
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • BrandonAzbell
      Posted by BrandonAzbell
      on Jul 28 2012 10:40 AM
      Guru54790 points
      Adam Zehavi
      Do you understand the basic premise of SPI operations and how the physical interface is intended to operate?  I don't want to assume anything.
      Adam Zehavi
      The MSP430F5438 has 4 instances of the USCI module, which each module has 2 parts (A and B).  As the datasheet indicates, each part of the USCI module can support SPI operations.  Therefore, technically the MSP430F5438 can support up to 8 unique SPI interfaces if each part of the USCI modules are configured for that mode of operation.
      Adam Zehavi
      Yes, that is true.  The document you reference is suggesting to use 2 I/O pins to act as chip selects, a unique signal for each slave device.  Your software then needs to comprehend which device you are interacting with by controlling the I/O directly.  This means the USCI module does not control the chip select I/O itself, but rather you higher level driver code running on the processor needs to control this.
      Using this method does save on the number of pins consumed for connecting to SPI slaves.  If you assume only 3 signals are used for a specific SPI slave (CLK, SOMI, SIMO) and the chip select is held active on the slave, to support 2 slave with 2 separate SPI interfaces, you would consume 6 signals (ie. 2 * (CLK, SOMI, SIMO)).
      If you use the chip select method, then 2 chip selects and the common CLK, SOMI, SIMO woudl be 5 signals.
      The trade off is some complexity with the software to manage this.
      Adam Zehavi
      You will need to consult the MSP430x5xx Family User's Guide for specifics about the various modules functionality and register definitions.  There are also code examples to help illustrate concepts that you could consult as well.
      Brandon
      Report Abuse
      • Reply
    • Adam Zehavi
      on Jul 28 2012 12:20 PM
      Thank you for your response...
      BrandonAzbell
      Well, I'll go and assume that this is like a Java Input output stream, where data is been queued, and then a flush signals the other side it has content to read, from the proper port, or something similar.
      BrandonAzbell
      I'm using MSP430F5438, and the confusion I'm having reading the datasheet is the fact that each register has multiple functions, for example:
      P3.0/UCB0STE/UCA0CLK 33 35
      General-purpose digital I/O
      Slave transmit enable – USCI_B0 SPI mode
      Clock signal input – USCI_A0 SPI slave mode
      Clock signal output – USCI_A0 SPI master mode
      P3.1/UCB0SIMO/UCB0SDA 34 36
      Slave in, master out – USCI_B0 SPI mode
      I2C data – USCI_B0 I2C mode
      P3.2/UCB0SOMI/UCB0SCL 35 37
      Slave out, master in – USCI_B0 SPI mode
      I2C clock – USCI_B0 I2C mode
      P3.3/UCB0CLK/UCA0STE 36 38
      Clock signal input – USCI_B0 SPI slave mode
      Clock signal output – USCI_B0 SPI master mode
      Slave transmit enable – USCI_A0 SPI mode
      DVSS3 37 39 Digital ground supply
      This is the setup from the datasheet of the micro-controller.
      Why does each have multiple names?
      P3.0, and P3.3 confuse me, because of the similarity in their name though 'A' and 'B' are opposite...!?
      Why does each have a few descriptions which seem completely different (for the untrained eye)?
      What do I need to look for, when reading the datasheet of the HW component now connected to the microcontroller?
      Thanks in advance,
      Adam.
      Adam Zehavi.
      Nu-Art Software
      LinkedIn
      Twitter
      Report Abuse
      • Reply
    • Chester Gillon
      Posted by Chester Gillon
      on Jul 28 2012 13:12 PM
      Mastermind6295 points
      Adam Zehavi
      The INPUT/OUTPUT SCHEMATICS section of the MSP430F5438 datasheet SLAS612 show how each device pin may be mapped between either software controlled I/O ports or via peripheral modules.
      In the case of P3.0 and P3.3 Table 44. Port P3 (P3.0 to P3.7) Pin Functions has some notes about UCA0CLK function takeing precedence over UCB0STE function.
      Report Abuse
      • Reply
    • BrandonAzbell
      on Jul 28 2012 15:27 PM
      Guru54790 points
      Adam Zehavi
      For the pins you have listed above, each has multiple possible functions that can be multiplexed out.  As Chester mentioned either Digital I/O (eg. P3.0) or a peripheral functional signal (eg. UCB0STE or UCA0CLK).  Only one of these is available on the pin at any given time and the configuration is description in the Input/Output Schematics section of the datasheet.
      Adam Zehavi
      Recall my comment that each USCI module has 2 parts (or sub-units), the USCI_A and USCI_B sub-modules.  This is described in the MSP430x5xx Family User's Guide.  The A and the B denote which of the subunits is being referenced.
      Adam Zehavi
      Again, each description is related to a particular function which can multiplexed on the pin.  Only 1 of the functions can be active at any given time.
      Adam Zehavi
      Don't know what you are asking here.  You should look at both the datasheet of the microcontroller to get an idea of what functionality is available on the specific device you are using and use the Family User's Guide for details about a module that is instantiated on the device.
      Brandon
      Report Abuse
      • Reply
    • Venkat Ramshankar
      Posted by Venkat Ramshankar
      on Jul 30 2012 06:41 AM
      Prodigy190 points
      Hi Adam Zehavi,
      Basic knowledge of SPI protocol (like what is the functionality of CS, MOSI , MISO , CLK ) and taking a look into the code samples from TI (you will get the library & examples when you install CCS) will be the starting point.
      When reading through the code, you can better understand how a pin is "configured" to work as an SPI pin for eg. Interfacing slaves like accelerometer, temperature sensor etc are posted throughout the forum. A little search would help there.
      ATB,
      -Venkat.
      Report Abuse
      • Reply
    • Jens-Michael Gross
      Posted by Jens-Michael Gross
      on Jul 31 2012 08:29 AM
      Verified Answer
      Verified by Adam Zehavi
      Guru139900 points
      Adam Zehavi
      Well, no. Forget about the high-level stuff operating systems offer.
      Microcontroller design usually requires very low-level thinking.
      An SPI interface is barely more than two shift registers and a shift clock generator and some control circuitry.
      After configuring the baudrate and the port pins, the SPI hardware takes a byte you write to its transmit buffer and shifts it out bit by bit together with a clock signal. At the same time, a second shift register is shifting in data from the opposite direction and when 8 bits have been received, the resulting byte is moved into the receive buffer register.
      However, this is just a one-byte buffer. You have to check whether it is empty. (dedicated interrupt flags will allow you to either read the state or let an interrupt function to be called when the state changes)
      However, you cannot simply put a bunch of bytes into a stream queue - unless you write this queue yourself.
      Besides this low-level handling (and the even lower-level initialization) you'll have to deal with the higher-level things such as (software-controlled) chip select signals to notify the slave that you want to send it data or receive from it.
      I don't recommend to start with writing an SPI slave. IT requires tight, timing-critical code and is the most demanding of all serial communications tasks.
      There are lots of threads about SPI in this forum. You should take a look at them.
      Adam Zehavi
      Each physical MSp pin can have different modes of operation. Almost always is the default mode plain I/O that can be programmed by software. However, most pins can be switched to secondary functions by selecting their 'module function' (with the PxSEL registers). Depending on which module is available as optional use of this pin, the functionality may be different (even different modules) based on whether the pin is set for input or output. Also, sometimes the module itself can define the actual usage of the pin by its own configuration.
      In case of P3.1, the pin can carry the Port 3 Bit 1 GPIO (P3.1) or USCI B0 module (UCB0) signal. In case of UCB0, this module can operate in I2C mode (then this pin is the serial data signal) or in SPI mode. In SPI mode, it is either slave output (if the mode is in SPI slave mode) or master input (if in SPI master mode). Since USCI B0 can only be in one mode at a time, only one of the different signals is routed to the pin at a time, depending on configuration.
      Adam Zehavi
      The USCI module has two sub-modules, A and B. Each USCI module has six different signal lines. However, both sub-modules can act as SPI. In 4-wire mode, one sub-module requires 4 signals, leaving only two port pins available for the other sub-module. This means that you cannot have one sub-module run in 4-wire SPI when the other one shall be SPI too (requiring at least 3 wires).
      So the functions have been distributed so that the 4th SPI wire, STE, which is only required for multi-master SPI or SPI slave (3-wire SPI is the normal usage in the very most cases, the usually required CS line is not counted here,as it is GPIO) is on a pin that is only needed for the other sub-modules SPI funciton. So 4-wire SPI can coexist with the (2-wire) UART or I2C operations of the other sub-module.
      Adam Zehavi
      Not the datasheet, the users guide. It contains the description of all modules that are in any one of the MSPs if a family. (though your MSP not necessarily has all of them)
      _____________________________________
      Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
      If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
      Report Abuse
      • Reply
    • Adam Zehavi
      on Jul 31 2012 19:09 PM
      First, thank you all for your responses, this is tone of info, and it took a while to process it.
      I've read everything, and tried to make sense of the example SPI master code supplied in a previous link:
      //   MSP430F54x Demo - USCI_A0, SPI 3-Wire Master Incremented Data
      //   Description: SPI master talks to SPI slave using 3-wire mode. Incrementing
      //   data is sent by the master starting at 0x01. Received data is expected to
      //   be same as the previous transmission.  USCI RX ISR is used to handle
      //   communication with the CPU, normally in LPM0. If high, P1.0 indicates
      //   valid data reception.  Because all execution after LPM0 is in ISRs,
      //   initialization waits for DCO to stabilize against ACLK.
      //   ACLK = ~32.768kHz, MCLK = SMCLK = DCO ~ 1048kHz.  BRCLK = SMCLK/2
      //   Use with SPI Slave Data Echo code example.  If slave is in debug mode, P1.1
      //   slave reset signal conflicts with slave's JTAG; to work around, use IAR's
      //   "Release JTAG on Go" on slave device.  If breakpoints are set in
      //   slave RX ISR, master must stopped also to avoid overrunning slave
      //   RXBUF.
      //                   MSP430F5438
      //              --|RST          P1.0|-> LED
      //                |             P3.4|-> Data Out (UCA0SIMO)
      //                |             P3.5|<- Data In (UCA0SOMI)
      //  Slave reset <-|P1.1         P3.0|-> Serial Clock Out (UCA0CLK)
      //   W. Goh
      //   Texas Instruments Inc.
      //   November 2008
      //   Built with CCE Version: 3.2.2 and IAR Embedded Workbench Version: 4.11B
      #include "msp430F5438.h"
      unsigned char MST_Data,SLV_Data;
      void main(void)
        WDTCTL = WDTPW+WDTHOLD;                   // Stop watchdog timer
        P1OUT |= 0x02;                            // Set P1.0 for LED
                                                  // Set P1.1 for slave reset
        P1DIR |= 0x03;                            // Set P1.0-2 to output direction
        P3SEL |= 0x31;                            // P3.5,4,0 option select
        UCA0CTL1 |= UCSWRST;                      // **Put state machine in reset**
        UCA0CTL0 |= UCMST+UCSYNC+UCCKPL+UCMSB;    // 3-pin, 8-bit SPI master
                                                  // Clock polarity high, MSB
        UCA0CTL1 |= UCSSEL_2;                     // SMCLK
        UCA0BR0 = 0x02;                           // /2
        UCA0BR1 = 0;                              //
        UCA0MCTL = 0;                             // No modulation
        UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
        UCA0IE |= UCRXIE;                         // Enable USCI_A0 RX interrupt
        P1OUT &= ~0x02;                           // Now with SPI signals initialized,
        P1OUT |= 0x02;                            // reset slave
        __delay_cycles(100);                      // Wait for slave to initialize
        MST_Data = 0x01;                          // Initialize data values
        SLV_Data = 0x00;                          //
        while (!(UCA0IFG&UCTXIFG));               // USCI_A0 TX buffer ready?
        UCA0TXBUF = MST_Data;                     // Transmit first character
        __bis_SR_register(LPM0_bits + GIE);       // CPU off, enable interrupts
        while(1);
      #pragma vector=USCI_A0_VECTOR
      __interrupt void USCI_A0_ISR(void)
        switch(__even_in_range(UCA0IV,4))
          case 0: break;                          // Vector 0 - no interrupt
          case 2:                                 // Vector 2 - RXIFG
            if (UCA0RXBUF==SLV_Data)              // Test for correct character RX'd
              P1OUT |= 0x01;                      // If correct, light LED
            else
              P1OUT &= ~0x01;                     // If incorrect, clear LED
            MST_Data++;                           // Increment data
            SLV_Data++;
            UCA0TXBUF = MST_Data;                 // Send next value
            __delay_cycles(10);                   // Add time between transmissions to
                                                  // make sure slave can process information
            break;
          case 4: break;                          // Vector 4 - TXIFG
          default: break;
      (WOW took me forever to find a good code converter - I'm fixing it... it didn't look like this on the editor!!!)
      So if I understand this example correctly, then I was off by a mile with the impression I had of SPI when I started.
      • Do I only need to write the byte to the proper TX, and the system would execute the bit by bit transaction?
      • And in order to write a 16 bit data to the SPI, I would have to add a:
        CA0TXBUF = nextValue; // Send next value
        __delay_cycles(40);
        After the  __delay_cycles(40); in the original code, or something like that?
      • If I need to write some parameters to the component and program it, then I need an SPI Master, but later I need to get data back, so do I need also an SPI slave?
      I'm making some assumption... again...
      Thanks in advance,
      Adam.
      Adam Zehavi.
      Nu-Art Software
      LinkedIn
      Twitter
      Report Abuse
      • Reply
    • Adam Zehavi
      on Jul 31 2012 19:26 PM
      There think there might be a bug in the forum posting editor... if I've copied the text, and changed the font to (in my case) courier new, it gets messed up, and if I don't set any font, then I guess you can see the result...
      Adam Zehavi.
      Nu-Art Software
      LinkedIn
      Twitter
      Report Abuse
      • Reply
      on Aug 01 2012 13:54 PM
      Verified Answer
      Guru139900 points
      Adam Zehavi
      Yes. The write action starts the clock signal generation and the transfer (in both directions).
      However, this code uses soem implicit mechanism: When you sent a byte, you already received a byte, which causes an interrupt. (case 2). So an initial write to TXBUF is necessary.
      However, the 'usual' way would be enabling the interupt for TX (case 4) and when it comes wither write to TXBUF inside the ISR (since you got the interrupt, you know that TXBUF is ready for the next byte, no need to do busy-waiting inside an ISR) or (if no more bytes to be sent) clear the TXIE bit so no more interrupts come. The default case in the ISR is superfluous too: since the switch was wrtten with '__even_in_range(xxx,4)' there will be case 0,2,4 only, by definition. No need for a default.
      Adam Zehavi
      And in order to write a 16 bit data to the SPI, I would have to add a:...
      Almost, but no. A 16 bit value is just two 8 bit values. So depending on endianess, just split the 16 bit int two as if they were a sequence of 8 bit values. The slave will have them to be joined together again.
      However, a while loop for a hardware event is a very bad idea inside an ISR. Th eidea of an ISR is that it automatically gets called on an event, does the necessary stuff to handle it as fast as possible and then returns control back to the main code.
      If you do busy-waiting of some sort inside an ISR, you could as well move all the ISR code into main() and execute it sequentially.
      Adam Zehavi
      Well, it depends. It depends on who is controllign the timing.
      The master is the peer who decides when and how fast to transfer data. The transfer itself is bi-directional. If you e.g. want to write to an external memory, the MSP is the master and the memory is the slave.
      To write, the master sends a write command, the address to write to, the number of bytes to write, and the data. At the same time, the memory is sending dummy values back. After the last data byte has been written, the master may continue sending dummy bytes while the slave responds with a 'busy' response, until the slave sends a 'done' or 'failure' byte.
      When reading data, the MSP is still the master. It sends a read command, an address and (maybe, as this is superfluous) how many bytes to read. Then it continues sending dummy bytes and the slave will return one data byte for each. Once the last byte has been received, the master will simply stop sending bytes and deselect the slave.
      In both cases, the MSP has controlled when to do a transfer and at which speed (by controlling the SPi clock signal). However, the slave in this example did have a way to tell the master that it is not done yet (writing to flash memory takes some time).
      Don't forget that the answer to data sent can arrive soonest after the next byte sent (possibily a dummy byte). This, and the double-buffering of the USCI (one byte currently being sent in the output shift register, and one byte waiting in TXBUF), can make complex protocols a challenge.
      Report Abuse
      • Reply
    • Adam Zehavi
      on Aug 01 2012 15:50 PM
      Jens-Michael, thank you for your help, and your time.
      Things are much clearer now regarding the SPI communication protocol implementation, but some things are still a miss, so I would try to be more accurate.
      As for transferring 8*x bit, if I understand correct, I would have to know the x byte final values I want to send, and write them to the TX, one by one, on the SPI mater ISR iterations, and since the interrupt is defined to be invoked on RX completion, I can safely assume that the buffer is ready for the next TX byte, is this correct?
      Jens-Michael Gross
      I guessed that while configuring an SPI component, I would require some sort of a feedback from it, and sending dummy bytes, until an ending response is received seems like a nice technic.
      Jens-Michael Gross
      When reading data, the MSP is still the slave.
      I'm assuming you mean "MSP is still the master"?
      Jens-Michael Gross
      Adam Zehavi
      Due to my previous question in this post, I think I need to rephrase, I need to configure an Accelerometer, and later while the application is running (once a remote BT peer connects) I want the Accelerometer to start output its values and aggregate these to the application, and later send the acceleration data via Bluetooth to a remote BT peer.
      So upon startup I configure the Accelerometer, supply parameters, and set the component activation to "pause".
      Later when the application is running, and a BT peer is connected to the MSP, I set the component activation to "resume", how can I then define a sampling rate to  read the acceleration values? Should I setup a timer to start reading the acceleration values from the component, at whatever rate allowed/supported by the component?
      Adam.
      Adam Zehavi.
      Nu-Art Software
      LinkedIn
      Twitter
      Report Abuse
      • Reply
    • Adam Zehavi
      on Aug 01 2012 18:57 PM
      I've failed to understand the meaning of the following lines:
      P1OUT |= 0x02; // Set P1.1 for slave reset
      .... USCI (SPI)  configuration ....
      What is the reason for toggling the bit?
      Thanks in advance,
      Adam.
      Adam Zehavi.
      Nu-Art Software
      LinkedIn
      Twitter
      Report Abuse
      • Reply
      on Aug 02 2012 10:05 AM
      Verified Answer
      Guru139900 points
      Adam Zehavi
      You're not the first one asking :)
      This line seems to be connected to the slaves RESET pin in this specific demo setup. It is poorly documented for an example code. Also, the following code makes some implicit assumptions about slave startup time. Not a good habit for demo code too, as any change in the code may break the timing.
      Normally, a master won't reset the slave. it will only select it and communicate. However, some slaves might need a reset. Not because of the SPI, but because of their main function. E.g. if it is a display controller and the communication protocol does not cover a (software) reset command.
      Adam Zehavi
      Yes. I already corrected this typo.
      Adam Zehavi
      That's how the code works. (in this case, the values are generated by incrementing their source after each send). However, this approach has the drawback that you only write the next byte after the first has been sent, the answer has been received (1/2 SPi clock cycle later than sendign the last bit) and the ISR has been called. During this time, the SPI is idle. Not a big issue if the SPI speed is slow compared to MCLK. But when you want to send with maximum speed, you're wasting much bandwidth here. And for SPICLK = MCLK, the use of an ISR is a terrible idea. Here hand-crafted inline code or even the use of DMA is required to get maximum throughput. On SPICLK == MCLK, you only have 8 MCLK cycles per byte. Much less than the required cycles jsut for entering and exiting an ISR (with no code in it at all).
      Well, getting that tight to the max is the 'high art' of embedded programming :)
      Adam Zehavi
      That's the usual approach. Start a tiemr which does a data read. The timer interrupt frequency is the component sampling rate. Once the data has been read, flag that there i s new data available and let it send.
      I tis possible that the component provides a 'ready' signal that can be used to trigger a port pin interrupt on the master. Then you won't need a timer. You just wait for the por tpininterrupt ISR being called, and hten read teh values. Or you jsu tdo a busy waiting for the ready signal in main loop. No ISRs neededn then at all (but you can't go into low power mode then while waiting).
      Report Abuse
      • Reply
    • Adam Zehavi
      on Aug 02 2012 16:04 PM
      Thank you.
      I can now say, that together with your expert help and the demo app, I'm able to wrap my mine around the entire concept. My next goal is to write a mechanizem that would accomplish this, and communicate to multiple components, to start with, each component with different USCI.
      Jens-Michael Gross
      How could a code change break the timing?
      Assuming that the code was meant as a demo application for a strip MSP, checking the MSP P1.1 states:
      • General-purpose digital I/O with port interrupt
      • TA0 CCR0 capture: CCI0A input, compare: Out0 output
      • BSL transmit output
      Why was this port chosen for reset?
      Adam.
      FYI, the link at the bottom is broken...
      Adam Zehavi.
      Nu-Art Software
      LinkedIn
      Twitter
      Report Abuse
      • Reply
      on Aug 03 2012 06:54 AM
      Verified Answer
      Guru139900 points
      Adam Zehavi
      Teh master code assumes that after releasing the slave, the slave will be ready to respond when the master is starts the communication.
      However, if you add some functionality to the slave, or reorder the master code, without taking this relation into account, the amster wills tart querying the slave when the slave isn't ready to answer. Since there is no error handling (or even error-detection) in the demo code, this will make th ewhole applicaiton to no longer work. And you don't know why, as this is not really documented.
      Adam Zehavi
      It is used as plain GPIO port pin. So it was maybe chosen for layout considerations. I don't see any particular reason. Maybe in an existing PCB, this pin was routed to a breakout pin (because it is the BSL output in BSL mode) and wiring it to the slave was easier than with e.g. P1.0
      The application contains no info abput it, so it will remain a mystery unless the author give sus a comment :)
      Report Abuse
      • Reply
    • Adam Zehavi
      on Aug 03 2012 18:39 PM
      I've completed a simple setup for the accelerometer SPI.
      I've taken the demo application and integrated to it some infrastructure, carefully changing the code while verifying the original application behavior remains!
      /** * Modules Configuration. */
      USCI_Configuration accelerometerUSCI_Configuration = { UCSWRST, UCSYNC + UCMST + UCMSB + UCCKPL + UCCKPH, UCSSEL__SMCLK, 0x02, 0, 0} ;
      USCI_Module usciA3_Module = { &UCA3TXBUF, &UCA3RXBUF, &UCA3CTL1, &UCA3CTL0, &UCA3BR0, &UCA3BR1, &UCA3MCTL };
      Interrupt usciA3_Interrupt = { &UCA3IE, &UCA3IFG, &UCA3IV };
      /** * Acceleroemter definition. */
      SPI_Component spiAccelerometer = {
      		{ &port10, BIT0, PORT_OUT }, { &port10, BIT3, PORT_OUT }, { &port10, BIT4, PORT_OUT },
      		{ &port10, BIT5, PORT_IN } };
      Accelerometer accelerometer = { &spiAccelerometer, &usciA3_Module, &accelerometerUSCI_Configuration, {
      		&port1, BIT5, PORT_IN }, { &port1, BIT6, PORT_IN } };
      UCHAR packet[6];
      int index = 0;
      volatile UCHAR received[100];
      int receivedIndex = 0;
      void sendNextPacket(void) {
      //	*(usciA3_Module.outputBuffer) = MST_Data; // Send next value
      	if (index < 6) {
      		*(usciA3_Module.outputBuffer) = packet[index++]; // Send next value
      void main(void) {
      	packet[0] = XL346_DATA_FORMAT;
      	packet[0] |= 0x40;
      	packet[1] = XL346_RANGE_8G;
      	packet[2] = XL346_POWER_CTL;
      	packet[2] |= 0x40;
      	packet[3] = XL346_MEASURE;
      	packet[4] = XL346_INT_ENABLE;
      	packet[4] |= 0x40;
      	packet[5] = XL346_DATAREADY;
      	WDTCTL = WDTPW + WDTHOLD;
      	setupRegister(redIndicationLed);
      	setupRegister(greenIndicationLed);
      	writeValueToRegister(greenIndicationLed, PORT_OFF);
      	initializeAccelerometer(accelerometer);
      	*(usciA3_Interrupt.controller) |= usciInterruptControls.receiver; // Enable USCI_A0 RX interrupt
      	while (!(*(usciA3_Interrupt.flags) & usciInterruptFlags.transmiter))
      	sendNextPacket();
      	while (1)
      #pragma vector=TIMER0_A1_VECTOR
      __interrupt void AccelerometerISR(void) {
      	if (TA0IV & TA0CCR4 != TA0CCR4) {
      		return;
      #pragma vector=USCI_A3_VECTOR
      __interrupt void USCI_A3_ISR(void) {
      	switch (__even_in_range(*(usciA3_Interrupt.vector), 4)) {
      	case 0:
      		received[receivedIndex++] = *(usciA3_Module.inputBuffer);
      		sendNextPacket();
      		break;
      	case 4:
      I'm pretty positive I've configured the component, and its SPI registers properly, and also the RXIFG event arrives, but the data received is always empty, and the interrupt that is supposed to be invoked by the component does not occur, am I sending the data wrong, and therefore I get no feedback?
      Adam.
      Adam Zehavi.
      Nu-Art Software
      LinkedIn
      Twitter
      Report Abuse
      • Reply
    123
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
