• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » MSP430F5341IRGZ thermal pad
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • MSP430F5341IRGZ thermal pad
    This question is not answered
    rodtalicc
    Posted by rodtalicc
    on Jul 31 2012 14:47 PM
    Prodigy170 points
    I am working on a design using MSP430F5341IRGZ and I want to make sure that I terminate the thermal pad on the QFN package correctly. Is this pad to be grounded to the ground plane through vias or should the pad be left floating?
    MSP430F5341
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Jason Work
      Posted by Jason Work
      on Aug 01 2012 14:00 PM
      Expert7565 points
      rodtalicc
      The data sheet is not clear enogh to give an answer, so I have asked for this to be updated.
      I also checked some other MSP430 devices that share the same 48VQFN (RGZ) package:
      MSP430F5510
      MSP430F5310
      MSP430FG4270
      In each case, the data sheet recommends that the power pad (QFN pad) be connected to
      Vss (ground).
      Power Pad QFN pad
      Report Abuse
      • Reply
    • Avi Chami1
      Posted by Avi Chami1
      on Aug 01 2012 14:45 PM
      Mastermind7405 points
      This is actually a problem in many TI datasheets using QFN with thermal PAD. The generic datasheet of the package says to connect the pad to a GND or power plane as recommended in the datasheet. But the datasheet itself, almost always, omits to tell the connection of the thermal PAD.
      If you make a search through the forums, you will see this question popping many times for many devices with thermal pad.
      Report Abuse
      • Reply
    • Jens-Michael Gross
      Posted by Jens-Michael Gross
      on Aug 01 2012 15:16 PM
      Guru140435 points
      A simple multimeter will tell you whether the thermal pad and the VSS/GND pin are directly connected. If so, do it. If not, don't. I bet it is. :)
      Generally, if the generic document tells you a fact, there's no reason to repeat it in the more detailed documents. HTat's why there is a generic document. Else it could/would be included as a whole in the specific documents.
      _____________________________________
      Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
      If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
      Report Abuse
      • Reply
    • Avi Chami1
      on Aug 01 2012 15:35 PM
      The generic document DOESNT tell you to connect to GND. It only tells you to connect it to a power plane (GND OR VCC) according what the datasheet says. And then the datasheet says nothing
      Report Abuse
      • Reply
      on Aug 02 2012 09:18 AM
      Guru140435 points
      Albert_83
      Sorry, I misinterpreted the 'GCC or power plane' (or rather overlooked the 'or power plane') par tin your text.
      However, the multimeter suggeston still jholds. If it needs to be tied to VCC, there will be a noticeable resistance (semiconductor-induced voltage drop) between the pad and any GND pin. If there is a clean shortcut, then it needs to be tied to GND. The generic document excludes any other neccessity (like leaving it floating).
      And you're right, the datasheet then should say something. But even though it doesn't, it's not difficult to figure out yourself. Faster than writing a quesiton in the forum.
      Report Abuse
      • Reply
    • rodtalicc
      Posted by rodtalicc
      on Aug 06 2012 02:55 AM
      Prodigy170 points
      Can you please confirm the proper termination for the thermal pad? Unfortunately, I cant verify the suggestion that Jens-Michael  gave of doing a multimeter test on the part because I am traveling and I dont have access to the part or a multimeter to carry out the test. Please help me confirm this so I can finalize my design for prototyping.
      Report Abuse
      • Reply
    • Jason Work
      on Aug 13 2012 10:44 AM
      Expert7565 points
      rodtalicc
      You are recommended to connect the thermal pad to Vss for the MSP430F5341IRGZ.  The data sheet has been updated to reflect this.
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
