• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » Low power MSP430F2618 not able to reduce current below 900uA
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • Low power MSP430F2618 not able to reduce current below 900uA
    This question is not answered
    Rakesh Muralidharan
    Posted by Rakesh Muralidharan
    on Aug 01 2012 12:51 PM
    Intellectual720 points
    Hi
    I was using the Evaluation module for MSP430F2618
    My application needs CPU to be active and must have low power. For this purpose i tried out a small program to run uC at a low clock rate
    I modified one example code of MSP430F2618
    #include  <msp430x26x.h>
    void main(void)
      WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
      BCSCTL3 |= LFXT1S1 ;
      BCSCTL2 |= (SELM1+SELM0+SELS);
      ADC12CTL0 = SHT0_2 + ADC12ON;             // Set sampling time, turn on ADC12
      ADC12CTL1 = SHP+ ADC12SSEL1;                          // Use sampling timer
      ADC12IE = 0x01;                           // Enable interrupt
      ADC12CTL0 |= ENC;                         // Conversion enabled
      P6DIR &= 0x01;                            // P6.0, i/p
      P6SEL |= 0x01;                            // P6.0-ADC option select
      //P1DIR |= 0x01;                            // P1.0 output-LED
      for (;;)
        ADC12CTL0 |= ADC12SC;                   // Start convn, software controlled
        _BIS_SR(CPUOFF + GIE);                  // LPM0, ADC12_ISR will force exit
    // ADC12 interrupt service routine
    #pragma vector=ADC12_VECTOR
    __interrupt void ADC12_ISR (void)
        //if (ADC12MEM0 < 0x7FF)
          //P1OUT &= ~0x01;                       // Clear P1.0 LED off
        //else
          //P1OUT |= 0x01;                        // Set P1.0 LED on
        _BIC_SR_IRQ(CPUOFF);                    // Clear CPUOFF bit from 0(SR)
    I am always getting a current consumption of 900uA @ 3V
    This is way above the CPU limits. Also when I put break point in the program the device current reduces to 200uA
    Please let me know how to make CPU work in lower clock rate
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Jens-Michael Gross
      Posted by Jens-Michael Gross
      on Aug 01 2012 15:08 PM
      Guru139900 points
      Rakesh Muralidharan
      No wonder. In your ISR, you do not clear the IFG bit that has caused the interrupt or read the ADC12MEM register that caused the interrupt (which would clear the bit too). So your ISR exits, but then enters the ISR again right away. It never sleeps. It is running on 100% load, trying to handle an interrupt over and over again that simply isn't ever handled by the ISR.
      See the ADC12IFG register description in the users guide.
      (the ADC10 is different: it only has one IFG bit as it has only one result register, and it is auto-cleared when the ISR is entered)
      When you place a breakpoiont, the CPu stops (of course, as this is the intention of a breakpoint) and current drops.
      _____________________________________
      Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
      If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
