• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » msp430f5438 watchdog timer too short
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • msp430f5438 watchdog timer too short
    This question is answered
    ephraim oved
    Posted by ephraim oved
    on Aug 02 2012 05:53 AM
    Intellectual940 points
    Hi.
    Is there a way to get wdt time greater then 10 seconds.
    I use 32768 oscillator to get 8 mHz clock.
    Please Advise.
    Ephraim Oved
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Arturs Elksnis
      Posted by Arturs Elksnis
      on Aug 02 2012 06:32 AM
      Intellectual655 points
      Right, seriously I don't mean to be abusive and please don't take it personal BUT:
      1. 8mHz ??? Is that 8 milli Herz??? So 8 oscillations in thousand seconds??? Really??? I don't think that you can divide 32kHz that far with an MSP430 clock system;
      2. Ok, I bet you meant 8MHz -- that's 8 MEGA herz or 8 million oscillations in a second. Still, you can't get that from a 32kHz crystal so you're probably using DCO clock;
        • ephraim oved
        Yes, trigger every so often and count the trigger times and when you've counted far enough (well more than 10 seconds in your case) then do whatever you need to do.
      Unfortunately the quality of information you've given doesn't lend itself to any better advise.
      Report Abuse
      • Reply
    • Jens-Michael Gross
      Posted by Jens-Michael Gross
      on Aug 02 2012 12:13 PM
      Guru140135 points
      Arturs Elksnis
      It's one timer interrupt every 125 seconds. The watchdog timer can be programmed to produce one interrupt every 32kHz/2G = 29536 seconds = 18:12:16.
      Other possible intervals with 32kHz source are 1:08:16, 4:16, 16 or 1s. Or 250, 15,6 or 1,95ms.
      About three times as much when using the VLO clock. (but then the outcome is somewhat uncertain as VLOclock has a large drift and tolerance.
      _____________________________________
      Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
      If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
      Report Abuse
      • Reply
    • Arturs Elksnis
      on Aug 02 2012 15:20 PM
      Verified Answer
      Verified by ephraim oved
      Ok, point taken. I've got lots to learn myself. :)
      Report Abuse
      • Reply
      on Aug 03 2012 06:47 AM
      Guru140135 points
      Arturs Elksnis
      Well, these large spans are new on the 5x family. On the other families, the WDT was way more limited. Especially on teh 1x family, wher eon the devices with more ram the WDT could expire before the variables were initialized and our code started executing at all.
      That's IMHO why CCS does not clear uninitialized variables/arrays on startup, which is not necessary by the C standard but done by almost all other C compilers.
      Report Abuse
      • Reply
    • Peter Bigot
      Posted by Peter Bigot
      on Aug 03 2012 09:16 AM
      Expert1360 points
      Jens-Michael Gross
      All documented arguments I've seen note that, since C90, this is required by the C standard.  See http://lwip.wikia.com/wiki/Why_are_global_variables_not_initialized_to_zero%3F and http://stackoverflow.com/questions/2617196/c-static-variables-and-intialization
      Section 4.9 "Initialization" in the 1978 edition of "The C Programming Language" by Kernighan and Ritchie also states that initialization to zero is done at compile time.  So CCS may have had a reason for failing to do so, but it's never been consistent with the contemporaneous C standard (unless that was broken somewhere between K&R and the first ANSI  standard, which I'm willing to assume didn't happen).
      I don't think the reason is good either; CCS could very well have reset the watchdog as necessary while initializing memory.
      Report Abuse
      • Reply
      on Aug 03 2012 09:42 AM
      Guru140135 points
      Peter Bigot
      But CCS never states compliance with C90 standard. 'C' doesn't necessarily mean 'newer standard than the original'. The compiler manual explicitly lists where the compiler follows K&R, but this doesn't mean it does so for the other topics too.
      Peter Bigot
      The described reason was only a guess. MSPGCC originally simply turned the watchdog off without notice (a really big issue).
      If someone wants a variable to be initialized as zero, he shall do so. Uninitialized variables are uninitialized. That's at least understandable. But a watchdog that's off while all datasheets tell it is on after power-up is much less understandable.
      I once, I wrote my own start-up code for MSPGCC that indeed triggers the WDT during initialization. However, when start-up time is an issue, the added execution time (about twice the original time for the zeroing loop) is definitely something to consider.
      Also, this 'feature' is well documented in the CCS compiler manual. It's only that nobody reads manuals these days - It is assume that things are as one expects them, and if not, a forum post is thrown out.
      Peter Bigot
      This means that variables explicitely initialized to zero (by adding "=0" to the definition) are put into initialized data segment and have their zero value stored in flash like any other initialization value.
      However, carrying a copy of an uninitialized 2k array as 2k of zeroes in flash memory is definitely a waste of space. PC programs tend to not care for their own executable size, carrying MB-sized empty segments around. But on systems with limited resources this is simply a no-go. Standard or not. Standards have ben 'improved' all the tiem for various reasons, including pure convenience or even less understandable reasons. Not following such an 'improvement' for hard resource constraints is IMHO more than valid.
      Report Abuse
      • Reply
    • Peter Bigot
      on Aug 03 2012 10:07 AM
      Expert1360 points
      Jens-Michael Gross
      Jens-Michael Gross
      The proposed explanation of CCS behavior was stated as an opinion; the statement that its failure to present global variables as though they had been initialized to zero was not required by the C standard was presented as fact.  It is false.
      Jens-Michael Gross
      Peter Bigot
      I apologize; I mis-summarized.  The actual source document states:
      K&R1e sect 4.9
      In the absence of explicit initialization, external and static variables are guaranteed to be initialized to zero; automatic and register variables have undefined (i.e., garbage) values. ... For external and static variables, the initialization is done once, conceptually at compile time.
      Thus a run-time initialization prior to transferring control to main() is perfectly acceptable.
      There is no "improvement" here; CCS' behavior is strictly contrary to the language as it has existed since 1978.  It's good that the improper behavior is documented in the manual, but there's no reason to suggest that developers should be blamed for assuming that the default behavior of a language implementation conforms to the language specification, especially in something so fundamental.
      Report Abuse
      • Reply
    • TonyKao
      Posted by TonyKao
      on Aug 03 2012 17:13 PM
      Genius3770 points
      AFAIK if you compile to EABI using CCS5 the toolchain does clear BSS segment by default; I recall that it caused quite a bit of grief for ppl upgrading from previous versions relying on the non-standard behaviour, since it caused the watchdog to reset indefinitely during initialization. Not sure if this was solved or not, but yeah I could understand why they made the non-standard behaviour the default.
      Tony
      Report Abuse
      • Reply
      on Aug 06 2012 08:44 AM
      Guru140135 points
      Peter Bigot
      I know that you're usually quite firm regarding the standards (I'm not - I'm an engineer and I take things as they come and not as they should be). But your citation made me fetch my own copy of K&R (yes, I have one) from the shelf. it is in German, but I don't think this makes much of a difference.
      Your citation is correct, yet I doubt it applies at all to this case.
      According to K&R, "int data;" is an incomplete definition. As such, if done on global scope, it has to be initialized to default value, which is 0 for this data type.
      However, since it is a definition, it may only appear once in a project. You cannot e.g. include it by a header file into several compilation units. Doing so would lead to a linker error since the same variable is defined multiple times in the project.
      So if 'data' has been defined in one compilation unit, it may only be declared in others by using 'extern' declaration.
      Now current compilers are smart neough to allow multiple incomplete definitions wihtout throwing an error, creating the storage location only once. This behavior effectively turns the incomplete global definition into an auto storage type. Whose initial value is undefined.
      This is logical too. Since the global variable defined with an incomplete definition is not associated wiht a specific compilation unit, it's initial value is equally undefined for any compilation unit that uses it.
      Peter Bigot
      Well, K&R is dated '78. C itself is older. It was developed between '69 and '73 at Bell labs. The book form '78 was just the first major publication 'for the masses'.
      However, the non-initialization of variables with incomplete definition is surprising for those who are accustomed to have them initialized. But if someones code relies on a variable being zero at the beginning, he should invest those additional two bytes in the source code and explicitely initialize them.
      BTW: some compilers produce debug compilations without, and only release compilations with auto-zeroing of incompletely defined variables.
      Report Abuse
      • Reply
    • Peter Bigot
      on Aug 06 2012 09:32 AM
      Expert1360 points
      "Faced with the choice between changing one's mind and proving there is no need to do so, almost everyone gets busy on the proof."
        --  John Kenneth Galbraith
      Report Abuse
      • Reply
      on Aug 06 2012 12:07 PM
      Guru140135 points
      Peter Bigot
      Well, he was a politician and advisor to several presidents. For a president, changing his mind means he agrees that he was wrong before. Which is unthinkable for a president.
      But for normal people, this citation is wrong. Most people will change their mind easily if someone just offers a different opinion with at least a minimum of persuasion. In the face of a different opinion, checking the own one (or its source) against independent sources, rather than to obliterate without questioning, is the only reason why whe don't still think the earth is flat.
      However, I did the checking and came up with the conclusion that here is no right or wrong but that this case is simply not covered in the original K&R due to other differences. And CSS never stated to be fully compliant to K&R or any other standard.
      I totally agree to your opinion that clearing uninitialized variables at startup should be done (as long as there isa way to intentionally leave some dataspace uninitialized, which is vital for some microcontroller applications). I just disagreed that it is a neccessity by a standard the compiler never claims to comply to. (And I figured out that it is not truly the case anyway)
      If following a standard for its own sake is such a high goal, why are there ever multiple, not even always backwards compatible standards for a single topic? Or with Microsofts words: why should we follow our own yesterday standard if a different way seems more profitable today?
      At the end, this whole discussion is pointless. CCS works as it works, it is documented how it works and if you don't like it you can use a different compiler. (Well, I guess you're using MSPGCC anyway :) )
      The most important information form this thread is that seemingly CCS has changed its former behavior with the switch to ELF (EABI) output format. I wonder whether this is documented. It already caused havoc for many people whose old projects suddenly stop working. Operation successful, patient dead.
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
