• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » MSP430F5510 and ADC10 ramdom data errors
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • MSP430F5510 and ADC10 ramdom data errors
    This question is not answered
    Richard Bissen
    Posted by Richard Bissen
    on Aug 03 2012 15:55 PM
    Prodigy20 points
    I had developed code that samples ADC data using timer trigger and the DMA controller writing data to a buffer. This all works great with one exception; I will get incorrect data (0x0FF or 0x300). I setup the trigger to sample every 8ms in the pulse sample mode. I would have never noticed the issue except we should never get this value with the input we are supplying. When it fails it is always the same data pattern (0x0FF or 0x300). I also tried 8bit conversion but the data is 0x3F or 0xC0.
    I am using MODOSC at 5MHz and the ADC10SHT_2 and ADC10DIV_0. I have also checked for other errors (ADC10TOVIFG and ADC10OVIFG) but this never occurs. The failure rate is only ~8 in a 24 hour period but this data is used for ECG and is unacceptable.
    Any input would be appreciated.
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Jens-Michael Gross
      Posted by Jens-Michael Gross
      on Aug 06 2012 07:31 AM
      Guru140435 points
      So you're getting a value of 1/4 Vref or 3/4 Vref once in a while. That's strange.
      It's possible that the input data is just that way sometimes (spikes). The ADC10/12 takes 'snapshots' from the input signal. And if there are spikes, chances are that it will capture at the moment of a spike. However, scanning a 3h log of independently sampled analog data (digital scope stream) for a single short anomaly is next to impossible.
      It's also possible that you have a problem in your code (but unlikely, considering the failure rate of 1:1.350.000)
      Of course there is always a chance for a yet undetected silcon bug too.
      Since it is always the same pattern, the pragmatic approach would be to just look for this pattern and repeat the conversion. I guess anything else is beyond this forum and requires one of the TI engineers to look at it.
      _____________________________________
      Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
      If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
      Report Abuse
      • Reply
    • Richard Bissen
      on Aug 21 2012 11:47 AM
      Prodigy20 points
      I have done some testing with the ADC10 conversion and have determined the problem occurs when the input voltage results in the boundary between 0x200 and 0x1FF. I setup a test with the input voltage of 1.25v (our VREF is 2.5v). I did back-to-back reads and I got a 25% failure rate when reading the value from ADC10MEM0. The value would be 0x300 or 0x0FF. If I added a delay (1ms) between reads the failure rate drop way down (was more like the previous errors I was getting before). I raised or lowered the input voltage and the data conversion was never in error of the expected value. So at this point I am concluding the issue is in doing a conversion where the transition results in a value between the lower and upper (data bit 9) sections.
      Report Abuse
      • Reply
      on Aug 21 2012 12:16 PM
      Guru140435 points
      Richard Bissen
      From the workings of the ADC, as far as I know them, this gives me two possible reasons. Either the voltage on the sampling capacitor drops during the conversion, which will make the conversion process enter the "wrong branch of the digital tree", or the reference voltage changes, with the same effect but inverted result.
      The first will happen if the conversion frequency is too low, the second if it is too fast.
      In the second case, it might be necessary to enable the reference output adn externally buffer the reference voltage with a 100nF ceramic/10µF tantalum capacitor. Maybe it also helps to enable the reference buffer etc. In the first case, the solution is obvious.
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
