• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » MSP430 USB Debug Interface MSP FET430 UIF driver is not detecting in windows 7 32bit
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • MSP430 USB Debug Interface MSP FET430 UIF driver is not detecting in windows 7 32bit
    This question is not answered
    Periyasamy Iyyamperumal
    Posted by Periyasamy Iyyamperumal
    on Aug 09 2012 05:53 AM
    Prodigy30 points
    Dear Experts,
                           Recently we bought MSP430 USB Debug Interface MSP FET430 UIF with IAR software and FET Software, today we are facing issues that driver is not detecting  in my machine, its detected on other devices, and when i use FET pro 430, MSP430 is not detected and its saying driver is not installed and MSP430.dll file is missing, but i have installed FET pro 430 as per read me file in the software, and I have also installed latest version on MSP430.DLL file for that device, but its not taking that dll file, please help me any one out of this as soon as possible.
    Periysamy
    periysamy.i@lnties.com
    MSP430
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Mo.
      Posted by Mo.
      on Aug 09 2012 07:18 AM
      Genius10085 points
      Are you able to see the FET debugger in the Device Manager?
      Basically when the drivers are correctly installed then it should appear under Ports section either as CDC or VCP device.
      Can you check this?
      Do you mean that is works correctly on other PC's but not on the one you are using?
      Which IAR version do you have?
      BR,
      Mo.
      Make The Switch to TI MCUs
      Report Abuse
      • Reply
    • Periyasamy Iyyamperumal
      on Aug 09 2012 08:33 AM
      Prodigy30 points
      Dear BR,
                      I think this will explain u more, let me put this way, we are using MSP430 USB Debug Interface MSP FET430 UIF device for FET Software, I have installed the software as per the guide given by read me file, but after the installation my device should be detected on PORTS tab but its detected in Other Ports, but if I used other MSP430 devices in my machine it was working(Other Devices) fine and those devices are detected in PORTS tab, only my device is not detected on PORT's tab, I have also installed latest version of MSP430.DLL file for my device one which am using, but its not taking that dll file, even this device is not detected when we use IAR tool, I think I am getting this issues only on my device(Which one am using for FET), My Machine is windows7 32bit.  so kindly help me on this as soon as possible.
      Periyasamy I
      +91-7411763976
      Report Abuse
      • Reply
    • Mo.
      Posted by Mo.
      on Aug 09 2012 09:58 AM
      Genius10085 points
      Which Software? Where did you get it? Basically all the required FET drivers will be installed automatically with the IAR installation.
      1) Can you please provide a screen shot of your device manager when the not working FET is connected to the PC?
      2) In the device Manager, when you right click on properties --> Details of the not detected FET, what is the Device Instance Id?
      3) Which IAR version do you have?
      4) When you plug the FET tool to the USB port of your PC, do you see the Power LED or the Mode LED lighting or blinking?
      This is the High-Level Debugger Driver. What you need to install is the Low-Level Debugger driver which is included in IAR. Alternatively, the driver can be downloaded and installed from here: http://processors.wiki.ti.com/index.php/MSP430_JTAG_Interface_USB_Driver
      BR,
      Mo.
      Report Abuse
      • Reply
      on Aug 09 2012 23:19 PM
      Prodigy30 points
      Dear BR,
                     When i plugged the MSP430 device into my system, Power LED is ON and RED LED was blinking for some times, after that  getting off. I got this software from the Installation CD only, Please share with me ur mail id, i can send some screen shots, here i tried to attach the picture but i coudnt able to attached, also please directly send me mail so that i can send my system screen shots, i am using software version 3.0-6, and FET-Pro430
      My EMail ID is: periyasamy.i@lnties.com
      Periyasamy
      Report Abuse
      • Reply
    • Mo.
      Posted by Mo.
      on Aug 10 2012 03:35 AM
      Genius10085 points
      This indicates that you have a V2 Firmware version on the FET.V2 Firmware uses the Virtual Com Port (VCP) protocol.
      The Low-Level VCP drivers can be downloaded from here:
      VCP (for legacy DLLv2 support)
      Windows: XP32 \ XP64 \ Vista32 \ Vista64 \ Win7-32 \ Win7-64
      Hope this helps,
      Mo.
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
