• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » Is 1.8V sufficient to load program, or must be 2.2V?
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • Is 1.8V sufficient to load program, or must be 2.2V?
    This question is answered
    John Mielke
    Posted by John Mielke
    on Aug 12 2012 08:51 AM
    Prodigy140 points
    We have a custom board on which the regulator supplies stable 1.8V voltage to MPS430G2302. Using MSP-FET430UIF with 2-wire connection as shown in http://processors.wiki.ti.com/index.php/JTAG_(MSP430), we were able to connect to the device.
    We had programs when loading .out file and encountered
    error
    MSP430: Trouble Writing Memory Block at 0xf000 on Page 0 of Length 0x92: Could not erase device memory
    . When this happens we used MSP-FET430UIF JTAG pin 4 (VCC TARGET) to sense the board voltage level.
    We suspected the error might have related to the 1.8V voltage and used external power supply of 2.2V, after that the connection was successful.  If we adjust the external voltage to below 2.2V, say 2.1 or 2.0, the loading error happens again despite successful connection.
    The question is on the voltage. Datasheet SLAS723F MSP430G2x32, MSP430G2x02 Mixed Signal Microcontroller gives VCC [1.8, 3.6V] on p17 “Recommended Operating Conditions”. Though for flash programming/erase the lowest voltage is 2.2V, we were actually not doing any operation on the flash, just loading code and data to the ordinary memory. There are also other parts on the board designed for 1.8V operation and when using the external power supply we have to cut all of them off to avoid damage, so 1.8V is certainly preferred if it can also be to download code and data.
    Could anyone tell us why even if we are not loading anything to flash memory we still need 2.2V voltage?
    John
    msp-fet430uif
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Chester Gillon
      Posted by Chester Gillon
      on Aug 12 2012 10:09 AM
      Verified Answer
      Verified by John Mielke
      Mastermind7225 points
      John Mielke
      Due to the small amount of ram in MSP430 devices, when you create a program the code is placed in flash by the linker, and so when downloading a .out file in CCS the flash has to be erased and programmed to load the program.
      It may be possible to locate some in ram but the reset vector is in flash so don't think there is any way to eliminate the need for the target voltage to support flash operations when downloading from CCS.
      Report Abuse
      • Reply
    • John Mielke
      on Aug 12 2012 10:13 AM
      Prodigy140 points
      Chester,
      Understand it, thanks for the answer.
      John
      Report Abuse
      • Reply
    • Jens-Michael Gross
      Posted by Jens-Michael Gross
      on Aug 13 2012 13:32 PM
      Guru141810 points
      John Mielke
      Well, the code is storeed in flash and runs from flash. Code in ram (the only other memory) would be gone as soon as the power supply fails. So to ahve the MSP doing anything at all, you'll at least once have to write to flash, which needs 2.2V at theis moment.
      John Mielke
      To run a program that's stored on flash, you don't need 2.2V. Reading flash is possible from 1.8V on.
      However, to be able to write the code into the MSP, you'll need 2.2V at least during the programming cycle. So you need some way to provide 2.2V to the MSP while you are putting the code onto it (without frying your other circuitry). Or you program the MSP outside the PCB before soldering it.
      _____________________________________
      Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
      If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
