• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » MSP430™ Microcontrollers » MSP430 Ultra-Low Power 16-bit Microcontroller Forum » MSP430 for detecting if 3.5mm jack has plug inserted into it?
Share
  • Forum
  • Announcements
  • E2E Wiki
Options
  • Subscribe via RSS
MSP430 Resources
  • MSP430 Product Folder
  • MSP-EXP430G2 - MSP430 LaunchPad Value Line Development kit
  • MSP430 Getting Started Guide
  • MSP430 Microcontroller Projects
  • More Resources >
  • MSP430 for detecting if 3.5mm jack has plug inserted into it?
    This question is answered
    Ken Yee
    Posted by Ken Yee
    on Dec 27 2012 11:33 AM
    Prodigy100 points
    Anyone know of any MSP430 code/schematics for this?
    I've been digging in Google w/o any luck...
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Jens-Michael Gross
      Posted by Jens-Michael Gross
      on Dec 28 2012 10:25 AM
      Guru141810 points
      There are different approaces. Some jacks do have a separate switch which can be checked by the MSP. Or you put a pullup on the signal line and detect whether input voltage is VCC or below (indicating that some signal, but not an empty plug has been inserted). It depends on your hardware and the signal source. There's no generic answer.
      _____________________________________
      Before posting bug reports or ask for help, do at least quick scan over this article. It applies to any kind of problem reporting. On any forum. And/or look here.
      If you cannot discuss your problem in the public, feel free to start a private conversation: click on my name and then 'start conversation'. But please do so only if you really cannot do it in a public thread, as I usually read all threads. And I prefer to answer where others can profit from it (or contribute to it) too.
      Report Abuse
      • Reply
    • Ken Yee
      Posted by Ken Yee
      on Dec 28 2012 13:45 PM
      Prodigy100 points
      Thanks, Jens.
      Do you have an example on how it would work w/ the 5 contact 3.5mm plugs like this one?
      I'm using 1/2/4 already but can't figure out what to do w/ 3/5 to sense a plug has been inserted.  They're normally used to switch between headphones vs. speakers from what I've dug up, so 3/5 normally would go to the speakers if you have them, but I just want to use them to sense that a plug is in.
      Report Abuse
      • Reply
    • sri-sri
      Posted by sri-sri
      on Dec 28 2012 21:39 PM
      Expert1320 points
                  there is some some cool stuff here, hope helpfull!
      http://electronics.stackexchange.com/questions/1647/how-does-an-audio-jack-detect-when-a-speaker-is-plugged-in
      regards,
      sri.
      Sri.
      Please check verify answer if this post answers your question
      Report Abuse
      • Reply
      on Dec 29 2012 13:27 PM
      Verified Answer
      Verified by Ken Yee
      Guru141810 points
      You can put a pullup resistor on 3/5. E.g. 50k each to VCC. The input on 4/2 is then VCC if no plug is inserted and breaks down to whatever if yu plug something in. You can go even further and use 5k pullup on 3/5 and 47k pulldown on 4 and 2. This will again have the signal on VCC if no plug is inserted, but ensure 0V if a plug without signal is inserted (in the first case without pulldown, an unconnected plug would lead to an open input and therefore an indeterminate state). If you use an audio line signal, a 47k load is expected anyway.
      Or you connect 3/5 to two port pins and periodically toggle their output state and check for a change in the input state on 2/4. This too will let you detect whether the socket is empty or not.
      Of cource you can only check on one of the two channels.
      Report Abuse
      • Reply
    • Ken Yee
      Posted by Ken Yee
      on Dec 29 2012 22:33 PM
      Prodigy100 points
      Sri: That stackexchange article was pretty useless...I found that w/ Google already and it essentially doesn't say much useful except to say someone else did it.
      Thanks, Jens.
      I was experimenting w/ the pullup technique you mentioned before and making some progress.  This post added a lot more clarity :-)
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
