I've been flashing a new serial bootloader on a bunch of custom CC430 boards, in BSL space. The procedure was quite simple. Using a FET MSP430 flash programmer, from Elpotronic's FET-Pro430 software:
1. Erase BSL0-3 flash region
2. Write new bootloader in BSL
After some time working with the new bootloader I decided to do some modifications. However... surprise! I'm not able to access the board via SBW anymore.. I initially thought that there was an issue with the programmer but reading flash contents from blank MCU's works just fine. "Blow security fuse" is disabled in FET-Pro430 so I don't understand where the problem is.
I've read somewhere that powering the target board from the FET programmer may trigger a protection on the programmer so I've tried with an external PSU... but same result.
Anyone with similar experiences?
Can you recommend me a better programmer + software set for production programming?
Thanks.
