Hi e2e,
We have a customer using the MSP430FR5969. They have the following questions:
If the internal ADC is not used (they are usig the clock multiplier) can AVSS be connected directly to DVSS without any filtering that would have been required if the ADC were? The concern is that even if the ADC isnot being used that there may be other blocks such as the clock mulitplier that are being used that would require a cleaner power supply than the DVSS would be.
On page 7 of hte data sheet it states "QFN package pad connection to VSS recommended.". In the OrCad component geometry provided by TI there are about 20 vias to the package pad connection. Is that many vias required or can some be removed? What is the minimum recommended number of vias?
Thanks for your help!
John Wiemeyer
