We are using MSP430F6659 controller in our project.
In our project we are using ADC12_A internal ADC for reading input
pressure sensor1 on P6.0 ADC Pin
Pressure sensor 2 on P6.1 ADC pin
Pressure sensor 3 on P6.2 ADC Pin
Pressure sensor 4 on P6.3 ADC Pin
current on P6.4 ADC Pin
feedback on P6.5 ADC Pin
and internal Temperature sensor.
But we are not getting proper sample counts on P6.0 to P6.3, only on P6.4 and P6.5 pins getting proper counts with 10 sample floating.
Actually without connecting pressure input also we are getting some sample counts on these ADC pins(P6.0,P6.1,P6.3,P6.4).
We are not getting default counts when there is no input connection.
Find the attached code we are using, for your reference.
#include <msp430.h>
#define Num_of_Results 8
volatile unsigned int A0results[Num_of_Results];
volatile unsigned int A1results[Num_of_Results];
volatile unsigned int A2results[Num_of_Results];
volatile unsigned int A3results[Num_of_Results];
volatile unsigned int A4results[Num_of_Results];
volatile unsigned int A5results[Num_of_Results];
volatile unsigned int A6results[Num_of_Results];
main()
Init_ADC12();
while(1)
CollectADCsamples();
void Init_ADC12(void)
P6SEL = 0x3F; // Enable A/D channel inputs
REFCTL0 &= ~REFMSTR;
ADC12CTL0 &= ~ADC12ENC;
ADC12CTL0 = ADC12ON+ADC12MSC+ADC12SHT0_15+ADC12REFON; // Turn on ADC12, extend sampling time
// to avoid overflow of results
ADC12CTL1 = ADC12SHP+ADC12CONSEQ_1+ADC12CSTARTADD_0; // Use sampling timer, sequence of channels
ADC12MCTL0 = ADC12INCH_0 + ADC12SREF_2;
ADC12MCTL1 = ADC12INCH_1 + ADC12SREF_2;
ADC12MCTL2 = ADC12INCH_2 + ADC12SREF_2;
ADC12MCTL3 = ADC12INCH_3 + ADC12SREF_2;
ADC12MCTL4 = ADC12INCH_4 + ADC12SREF_2;
ADC12MCTL5 = ADC12INCH_5 + ADC12SREF_2;
ADC12MCTL6 = ADC12INCH_10+ ADC12SREF_2+ADC12EOS;
ADC12IE = 0x40; // Enable ADC12IFG.3
ADC12CTL0 |= ADC12ENC; // Enable conversions
ADC12CTL0 |= ADC12SC; // Start convn - software trigger
//__bis_SR_register(LPM0_bits + GIE); // Enter LPM0, Enable interrupts
__no_operation(); // For debugger
#pragma vector=ADC12_VECTOR
__interrupt void ADC12ISR (void)
static unsigned int index = 0;
switch(__even_in_range(ADC12IV,34))
case 0: break; // Vector 0: No interrupt
case 2: break; // Vector 2: ADC overflow
case 4: break; // Vector 4: ADC timing overflow
case 6: break; // Vector 6: ADC12IFG0
case 8: break; // Vector 8: ADC12IFG1
case 10: break; // Vector 10: ADC12IFG2
case 12: break; // Vector 12: ADC12IFG3
case 14: break; // Vector 14: ADC12IFG4
case 16: break; // Vector 16: ADC12IFG5
case 18:
A0results[index] = ADC12MEM0; // Move A0 results, IFG is cleared
A1results[index] = ADC12MEM1; // Move A1 results, IFG is cleared
A2results[index] = ADC12MEM2; // Move A2 results, IFG is cleared
A3results[index] = ADC12MEM3; // Move A3 results, IFG is clearedA2results[index] = ADC12MEM2; // Move A2 results, IFG is cleared
A4results[index] = ADC12MEM4; // Move A3 results, IFG is cleared
A5results[index] = ADC12MEM5; // Move A3 results, IFG is clearedA2results[index] = ADC12MEM2; // Move A2 results, IFG is cleared
l_Input_Sensor1_U16 = A0results[index];
l_output_Sensor1_U16 = A1results[index];
l_output_Sensor2_U16 = A2results[index];
l_Spool_Sensor4_U16 = A3results[index];
l_PVCount_U16 = A4results[index];
l_SVCount_U16 = A5results[index];
fl_temp_f = A6results[index];
index++; // Increment results index, modulo; Set Breakpoint1 here
if (index == 8)
(index = 0);
break; // Vector 18: ADC12IFG6
case 20: break; // Vector 20: ADC12IFG7
case 22: break; // Vector 22: ADC12IFG8
case 24: break; // Vector 24: ADC12IFG9
case 26: break; // Vector 26: ADC12IFG10
case 28: break; // Vector 28: ADC12IFG11
case 30: break; // Vector 30: ADC12IFG12
case 32: break; // Vector 32: ADC12IFG13
case 34: break; // Vector 34: ADC12IFG14
default: break;
void CollectADCsamples(void)
static float fl_PrevAverageSV_f=CLEAR;
static float fl_PrevAveragePV_f=CLEAR;
static float fl_PrevAverageinputsensor1_f=CLEAR;
static float fl_PrevAverageoutputsensor1_f=CLEAR;
static float fl_PrevAverageoutputsensor2_f=CLEAR;
static float PrevAverageSpool_Sensor4=CLEAR;
fl_temp_f = (float)(((long)fl_temp_f - CALADC12_15V_30C) * (85 - 30)) /
(CALADC12_15V_85C - CALADC12_15V_30C) + 30.0f;
f1_temp_value_f = fl_temp_f;
l_AverageSV_f = (fl_PrevAverageSV_f+((l_SVCount_U16-fl_PrevAverageSV_f)/1));
l_AveragePV_f = (fl_PrevAveragePV_f+((l_PVCount_U16-fl_PrevAveragePV_f)/1));
l_Averageinputsensor1_f = (fl_PrevAverageinputsensor1_f+((l_Input_Sensor1_U16-fl_PrevAverageinputsensor1_f)/1));
l_Averageoututsensor1_f = (fl_PrevAverageoutputsensor1_f+((l_output_Sensor1_U16-fl_PrevAverageoutputsensor1_f)/1));
l_Averageoutputsensor2_f = (fl_PrevAverageoutputsensor2_f+((l_output_Sensor2_U16-fl_PrevAverageoutputsensor2_f)/1));
l_AverageSpool_Sensor4 = (PrevAverageSpool_Sensor4+((l_Spool_Sensor4_U16-PrevAverageSpool_Sensor4)/3));
fl_temp_f1=fl_temp_f;
fl_PrevAverageSV_f = l_AverageSV_f;
fl_PrevAveragePV_f = l_AveragePV_f;
fl_PrevAverageinputsensor1_f=l_Averageinputsensor1_f;
fl_PrevAverageoutputsensor1_f=l_Averageoututsensor1_f;
fl_PrevAverageoutputsensor2_f=l_Averageoutputsensor2_f;
PrevAverageSpool_Sensor4 = l_AverageSpool_Sensor4;
Awaiting for your valuable response.
