Hi ,
I need to modify Linker file in CCS_5.5.0 for msp430f2410 same like IAR linker file(which is working fine).
Below are the IAR Linker file and CCS Linker file..
IAR
// XLINK configuration file for MSP430F2410
// Copyright 1996-2010 IAR Systems AB
// $Revision: 1.1 $
// Description
// Usage:
// xlink [file file ...] -f lnk430f2410.xcl
// Device summary
// Core: MSP430
// Interrupt vectors: 32 (16 unused)
// Peripheral units: 0-01FF
// Information memory (FLASH): 1000-10FF
// Read/write memory (RAM): 1100-20FF
// Read-only memory (FLASH): 2100-FFFF
// -Unused 2100-21FF
// -Interval Data 2200-32FF (Must be on a segment boundary)
// -Security Keys 3300-34FF
// -Code 3500-FFDD (FFC0-FFDD unused interrupt vectors)
// -BSL Security Key FFDE-FFDF
// -Interrupt Vectors FFE0-FFFF
// Segments
// Data read/write segments (RAM)
// segment Usage
// DATA16_Z Data initialized to zero
// DATA16_I Data initialized by copying from DATA16_ID
// DATA16_N Data defined using __no_init
// DATA16_HEAP The heap used by 'malloc' and 'free'
// CSTACK Runtime stack
// TLS16_I Thread-local storage for main thread
// (require custom runtime library)
// Program and data read-only segments (FLASH)
// segment Usage
// DATA16_C Constant data, including string literals
// DATA16_ID initializers for DATA<nn>_I
// INFO Information memory
// INFOA Information memory, bank A
// INFOB Information memory, bank B
// INFOC Information memory, bank C
// INFOD Information memory, bank D
// CSTART Program startup code
// CODE Program code
// ISR_CODE Program code for interrupt service routines
// DIFUNCT Dynamic initialization vector used by C++
// CHECKSUM Checksum byte(s) generated by the -J option
// INTVEC Interrupt vectors
// RESET The reset vector
// TLS16_ID Thread-local initializers for main thread
// Notes:
// * The INFOx and INFO segments overlap, this allows data either to be
// placed in a specific bank or anywhere in the info memory.
// * The INTVEC and RESET segments overlap. This allows an application to
// either use the reset vector provided by the runtime library, or
// provide a reset function by defining an interrupt function associated
// with the reset vector.
// Configuation
// Stack and heap sizes
// Uncomment for command line use
-D_STACK_SIZE=350
-D_DATA16_HEAP_SIZE=0
// Define cpu
-cmsp430
// Placement directives
-Z(CONST)DATA16_P=1100-20FF
-Z(DATA)DATA16_I,DATA16_Z,DATA16_N,DATA16_HEAP+_DATA16_HEAP_SIZE=1100-20FF
-Z(DATA)CSTACK+_STACK_SIZE#
// Read-only memory
-Z(CONST)INFO=1000-10FF
-Z(CONST)INFOA=10C0-10FF
-Z(CONST)INFOB=1080-10BF
-Z(CONST)INFOC=1040-107F
-Z(CONST)INFOD=1000-103F
// Interval Data
-Z(CODE)IDR_SEGS=2200-33FF
// Security Keys
-Z(CODE)SEC_KEY_SEG=3400-35FF
// Constant data
-P(CONST)DATA16_C,DATA16_ID,TLS16_ID,DIFUNCT,CHECKSUM=2100-21FF,3600-FFDD
// Code
-Z(CODE)CSTART,ISR_CODE,CODE_ID=2100-21FF,3600-FFDD
-P(CODE)CODE=2100-21FF,3600-FFDD
// BSL Security Key
-Z(CODE)BSLSKEY=FFDE-FFDF
// Interrupt vectors (FFC0-FFDF not used)
-Z(CODE)INTVEC=FFE0-FFFF
-Z(CODE)RESET=FFFE-FFFF
CCS
/* Copyright (c) 2013, Texas Instruments Incorporated */
/* All rights reserved. */
/* Redistribution and use in source and binary forms, with or without */
/* modification, are permitted provided that the following conditions */
/* are met: */
/* * Redistributions of source code must retain the above copyright */
/* notice, this list of conditions and the following disclaimer. */
/* * Redistributions in binary form must reproduce the above copyright */
/* notice, this list of conditions and the following disclaimer in the */
/* documentation and/or other materials provided with the distribution. */
/* * Neither the name of Texas Instruments Incorporated nor the names of */
/* its contributors may be used to endorse or promote products derived */
/* from this software without specific prior written permission. */
/* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" */
/* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, */
/* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR */
/* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR */
/* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, */
/* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, */
/* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; */
/* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, */
/* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR */
/* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
/* lnk_msp430f2410.cmd - LINKER COMMAND FILE FOR LINKING MSP430F2410 PROGRAMS */
/* Usage: lnk430 <obj files...> -o <out file> -m <map file> lnk.cmd */
/* cl430 <src files...> -z -o <out file> -m <map file> lnk.cmd */
/* These linker options are for command line linking only. For IDE linking, */
/* you should set your linker options in Project Properties */
/* -c LINK USING C CONVENTIONS */
/* -stack 0x0100 SOFTWARE STACK SIZE */
/* -heap 0x0100 HEAP AREA SIZE */
/* SPECIFY THE SYSTEM MEMORY MAP */
MEMORY
SFR : origin = 0x0000, length = 0x0010
PERIPHERALS_8BIT : origin = 0x0010, length = 0x00F0
PERIPHERALS_16BIT : origin = 0x0100, length = 0x0100
RAM : origin = 0x1100, length = 0x1000
INFOA : origin = 0x10C0, length = 0x0040
INFOB : origin = 0x1080, length = 0x0040
INFOC : origin = 0x1040, length = 0x0040
INFOD : origin = 0x1000, length = 0x0040
FLASH : origin = 0x2100, length = 0xDEBE
INT00 : origin = 0xFFC0, length = 0x0002
INT01 : origin = 0xFFC2, length = 0x0002
INT02 : origin = 0xFFC4, length = 0x0002
INT03 : origin = 0xFFC6, length = 0x0002
INT04 : origin = 0xFFC8, length = 0x0002
INT05 : origin = 0xFFCA, length = 0x0002
INT06 : origin = 0xFFCC, length = 0x0002
INT07 : origin = 0xFFCE, length = 0x0002
INT08 : origin = 0xFFD0, length = 0x0002
INT09 : origin = 0xFFD2, length = 0x0002
INT10 : origin = 0xFFD4, length = 0x0002
INT11 : origin = 0xFFD6, length = 0x0002
INT12 : origin = 0xFFD8, length = 0x0002
INT13 : origin = 0xFFDA, length = 0x0002
INT14 : origin = 0xFFDC, length = 0x0002
INT15 : origin = 0xFFDE, length = 0x0002
INT16 : origin = 0xFFE0, length = 0x0002
INT17 : origin = 0xFFE2, length = 0x0002
INT18 : origin = 0xFFE4, length = 0x0002
INT19 : origin = 0xFFE6, length = 0x0002
INT20 : origin = 0xFFE8, length = 0x0002
INT21 : origin = 0xFFEA, length = 0x0002
INT22 : origin = 0xFFEC, length = 0x0002
INT23 : origin = 0xFFEE, length = 0x0002
INT24 : origin = 0xFFF0, length = 0x0002
INT25 : origin = 0xFFF2, length = 0x0002
INT26 : origin = 0xFFF4, length = 0x0002
INT27 : origin = 0xFFF6, length = 0x0002
INT28 : origin = 0xFFF8, length = 0x0002
INT29 : origin = 0xFFFA, length = 0x0002
INT30 : origin = 0xFFFC, length = 0x0002
RESET : origin = 0xFFFE, length = 0x0002
/* SPECIFY THE SECTIONS ALLOCATION INTO MEMORY */
SECTIONS
.bss : {} > RAM /* GLOBAL & STATIC VARS */
.data : {} > RAM /* GLOBAL & STATIC VARS */
.sysmem : {} > RAM /* DYNAMIC MEMORY ALLOCATION AREA */
.stack : {} > RAM (HIGH) /* SOFTWARE SYSTEM STACK */
.text : {} > FLASH /* CODE */
.cinit : {} > FLASH /* INITIALIZATION TABLES */
.const : {} > FLASH /* CONSTANT DATA */
.cio : {} > RAM /* C I/O BUFFER */
.pinit : {} > FLASH /* C++ CONSTRUCTOR TABLES */
.init_array : {} > FLASH
.mspabi.exidx : {} > FLASH
.mspabi.extab : {} > FLASH
.infoA : {} > INFOA
/* MSP430 INFO FLASH MEMORY SEGMENTS */
.infoB : {} > INFOB
.infoC : {} > INFOC
.infoD : {} > INFOD
/* MSP430 INTERRUPT VECTORS */
RESERVED0 : { * ( .int00 ) } > INT00 type = VECT_INIT
RESERVED1 : { * ( .int01 ) } > INT01 type = VECT_INIT
RESERVED2 : { * ( .int02 ) } > INT02 type = VECT_INIT
RESERVED3 : { * ( .int03 ) } > INT03 type = VECT_INIT
RESERVED4 : { * ( .int04 ) } > INT04 type = VECT_INIT
RESERVED5 : { * ( .int05 ) } > INT05 type = VECT_INIT
RESERVED6 : { * ( .int06 ) } > INT06 type = VECT_INIT
RESERVED7 : { * ( .int07 ) } > INT07 type = VECT_INIT
RESERVED8 : { * ( .int08 ) } > INT08 type = VECT_INIT
RESERVED9 : { * ( .int09 ) } > INT09 type = VECT_INIT
RESERVED10 : { * ( .int10 ) } > INT10 type = VECT_INIT
RESERVED11 : { * ( .int11 ) } > INT11 type = VECT_INIT
RESERVED12 : { * ( .int12 ) } > INT12 type = VECT_INIT
RESERVED13 : { * ( .int13 ) } > INT13 type = VECT_INIT
RESERVED14 : { * ( .int14 ) } > INT14 type = VECT_INIT
RESERVED15 : { * ( .int15 ) } > INT15 type = VECT_INIT
USCIAB1TX : { * ( .int16 ) } > INT16 type = VECT_INIT
USCIAB1RX : { * ( .int17 ) } > INT17 type = VECT_INIT
PORT1 : { * ( .int18 ) } > INT18 type = VECT_INIT
PORT2 : { * ( .int19 ) } > INT19 type = VECT_INIT
RESERVED20 : { * ( .int20 ) } > INT20 type = VECT_INIT
ADC12 : { * ( .int21 ) } > INT21 type = VECT_INIT
USCIAB0TX : { * ( .int22 ) } > INT22 type = VECT_INIT
USCIAB0RX : { * ( .int23 ) } > INT23 type = VECT_INIT
TIMERA1 : { * ( .int24 ) } > INT24 type = VECT_INIT
TIMERA0 : { * ( .int25 ) } > INT25 type = VECT_INIT
WDT : { * ( .int26 ) } > INT26 type = VECT_INIT
COMPARATORA : { * ( .int27 ) } > INT27 type = VECT_INIT
TIMERB1 : { * ( .int28 ) } > INT28 type = VECT_INIT
TIMERB0 : { * ( .int29 ) } > INT29 type = VECT_INIT
NMI : { * ( .int30 ) } > INT30 type = VECT_INIT
.reset : {} > RESET
/* MSP430 RESET VECTOR */
/* INCLUDE PERIPHERALS MEMORY MAP */
-l msp430f2410.cmd
I need to know how i can make the IAR linker code compatible with CCS.
