where can i find an example code for ( EZ_430 + RF2500 ) that transmit and recive data between the two units ?
can anybody help ?
thank in advance .
doron .
can anybody help ?
thank in advance .
doron .
You can find example software in the software section of the eZ430-RF2500 Product Folder.
Hi Brandon,
Thanks for your quick replay!
I download the sw & program the end device unit & the access point unit but when i run the sensor monitor sw i see nothing happened...
I need a simple application to send & recieve data from one unit to another
Thanks in advance!
Doron
doron bs said:I need a simple application to send & recieve data from one unit to another
Hi, in first you have to specify if you want to use simpliciTIor not, if you need a point to point or multipoint communication. When this is fixed then search the example more closer to your application and try tailor to your need.
Is not working the sensor demo application where one device collect data from remote sensors and then send packet to pc?
