Hello everybody,
for my project i need a lot of memory pages and a lot of code. At the beginning i reserved 0x180 Byte (FRAM_RESERVED) at the end of my FRAM for later usage .
Now i need FRAM_RESERVED in the front of my code FRAM. But when i swap the 2 pieces i get the error "program will not fit into available memory. placement with alignment fails for section "ALL_FRAM" size 0x3a15".
My .map file says that the FRAM_RESERVED is completly unused and my FRAM has 0x1c unused memory. so why cant i swap that? I Have the feeling that ma FRAM needs more space then my .map says.
(I commented the new version out and let the working example inside.)
/* ============================================================================ */ /* Copyright (c) 2014, Texas Instruments Incorporated */ /* All rights reserved. */ /* */ /* Redistribution and use in source and binary forms, with or without */ /* modification, are permitted provided that the following conditions */ /* are met: */ /* */ /* * Redistributions of source code must retain the above copyright */ /* notice, this list of conditions and the following disclaimer. */ /* */ /* * Redistributions in binary form must reproduce the above copyright */ /* notice, this list of conditions and the following disclaimer in the */ /* documentation and/or other materials provided with the distribution. */ /* */ /* * Neither the name of Texas Instruments Incorporated nor the names of */ /* its contributors may be used to endorse or promote products derived */ /* from this software without specific prior written permission. */ /* */ /* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" */ /* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, */ /* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR */ /* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR */ /* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, */ /* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, */ /* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; */ /* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, */ /* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR */ /* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */ /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* ============================================================================ */ /******************************************************************************/ /* lnk_msp430fr5738.cmd - LINKER COMMAND FILE FOR LINKING MSP430FR5738 PROGRAMS */ /* */ /* Usage: lnk430 <obj files...> -o <out file> -m <map file> lnk.cmd */ /* cl430 <src files...> -z -o <out file> -m <map file> lnk.cmd */ /* */ /*----------------------------------------------------------------------------*/ /* These linker options are for command line linking only. For IDE linking, */ /* you should set your linker options in Project Properties */ /* -c LINK USING C CONVENTIONS */ /* -stack 0x0100 SOFTWARE STACK SIZE */ /* -heap 0x0100 HEAP AREA SIZE */ /* */ /*----------------------------------------------------------------------------*/ /* Version: 1.153 */ /*----------------------------------------------------------------------------*/ /****************************************************************************/ /* Specify the system memory map */ /****************************************************************************/ MEMORY { SFR : origin = 0x0000, length = 0x0010 PERIPHERALS_8BIT : origin = 0x0010, length = 0x00F0 PERIPHERALS_16BIT : origin = 0x0100, length = 0x0100 RAM : origin = 0x1C00, length = 0x0400 INFOA : origin = 0x1880, length = 0x0080 INFOB : origin = 0x1800, length = 0x0080 //2kB FRAM reserved from 0xC200 TXLOWMEM : origin = 0xC200, length = 0x0080 RXLOWMEM : origin = 0xC280, length = 0x0080 TXRXUPPMEM00 : origin = 0xC300, length = 0x0080 TXUPPMEM01 : origin = 0xC380, length = 0x0080 RXUPPMEM01 : origin = 0xC400, length = 0x0080 TXRXUPPMEM02 : origin = 0xC480, length = 0x0080 TXUPPMEM03 : origin = 0xC500, length = 0x0080 RXUPPMEM03 : origin = 0xC580, length = 0x0080 TXUPPMEM05 : origin = 0xC600, length = 0x0080 RXUPPMEM05 : origin = 0xC680, length = 0x0080 TXUPPMEM03_ROM : origin = 0xC700, length = 0x0080 RXUPPMEM03_ROM : origin = 0xC780, length = 0x0080 // FRAM_RESERVED : origin = 0xC800, length = 0x0180 //384B FRAM reserved to 0xC97F // FRAM : origin = 0xC980, length = 0x3600 // FRAM : origin = 0xC800, length = 0x3600 FRAM_RESERVED : origin = 0xFE00, length = 0x0180 JTAGSIGNATURE : origin = 0xFF80, length = 0x0004, fill = 0xFFFF BSLSIGNATURE : origin = 0xFF84, length = 0x0004, fill = 0xFFFF IPESIGNATURE : origin = 0xFF88, length = 0x0008, fill = 0xFFFF INT00 : origin = 0xFF90, length = 0x0002 INT01 : origin = 0xFF92, length = 0x0002 INT02 : origin = 0xFF94, length = 0x0002 INT03 : origin = 0xFF96, length = 0x0002 INT04 : origin = 0xFF98, length = 0x0002 INT05 : origin = 0xFF9A, length = 0x0002 INT06 : origin = 0xFF9C, length = 0x0002 INT07 : origin = 0xFF9E, length = 0x0002 INT08 : origin = 0xFFA0, length = 0x0002 INT09 : origin = 0xFFA2, length = 0x0002 INT10 : origin = 0xFFA4, length = 0x0002 INT11 : origin = 0xFFA6, length = 0x0002 INT12 : origin = 0xFFA8, length = 0x0002 INT13 : origin = 0xFFAA, length = 0x0002 INT14 : origin = 0xFFAC, length = 0x0002 INT15 : origin = 0xFFAE, length = 0x0002 INT16 : origin = 0xFFB0, length = 0x0002 INT17 : origin = 0xFFB2, length = 0x0002 INT18 : origin = 0xFFB4, length = 0x0002 INT19 : origin = 0xFFB6, length = 0x0002 INT20 : origin = 0xFFB8, length = 0x0002 INT21 : origin = 0xFFBA, length = 0x0002 INT22 : origin = 0xFFBC, length = 0x0002 INT23 : origin = 0xFFBE, length = 0x0002 INT24 : origin = 0xFFC0, length = 0x0002 INT25 : origin = 0xFFC2, length = 0x0002 INT26 : origin = 0xFFC4, length = 0x0002 INT27 : origin = 0xFFC6, length = 0x0002 INT28 : origin = 0xFFC8, length = 0x0002 INT29 : origin = 0xFFCA, length = 0x0002 INT30 : origin = 0xFFCC, length = 0x0002 INT31 : origin = 0xFFCE, length = 0x0002 INT32 : origin = 0xFFD0, length = 0x0002 INT33 : origin = 0xFFD2, length = 0x0002 INT34 : origin = 0xFFD4, length = 0x0002 INT35 : origin = 0xFFD6, length = 0x0002 INT36 : origin = 0xFFD8, length = 0x0002 INT37 : origin = 0xFFDA, length = 0x0002 INT38 : origin = 0xFFDC, length = 0x0002 INT39 : origin = 0xFFDE, length = 0x0002 INT40 : origin = 0xFFE0, length = 0x0002 INT41 : origin = 0xFFE2, length = 0x0002 INT42 : origin = 0xFFE4, length = 0x0002 INT43 : origin = 0xFFE6, length = 0x0002 INT44 : origin = 0xFFE8, length = 0x0002 INT45 : origin = 0xFFEA, length = 0x0002 INT46 : origin = 0xFFEC, length = 0x0002 INT47 : origin = 0xFFEE, length = 0x0002 INT48 : origin = 0xFFF0, length = 0x0002 INT49 : origin = 0xFFF2, length = 0x0002 INT50 : origin = 0xFFF4, length = 0x0002 INT51 : origin = 0xFFF6, length = 0x0002 INT52 : origin = 0xFFF8, length = 0x0002 INT53 : origin = 0xFFFA, length = 0x0002 INT54 : origin = 0xFFFC, length = 0x0002 RESET : origin = 0xFFFE, length = 0x0002 } /****************************************************************************/ /* Specify the sections allocation into memory */ /****************************************************************************/ SECTIONS { GROUP(ALL_FRAM) { GROUP(READ_WRITE_MEMORY) { .TI.persistent : {} /* For #pragma persistent */ .cio : {} /* C I/O buffer */ .sysmem : {} /* Dynamic memory allocation area */ } ALIGN(0x0200), RUN_START(fram_rw_start) GROUP(READ_ONLY_MEMORY) { .cinit : {} /* Initialization tables */ .pinit : {} /* C++ constructor tables */ .init_array : {} /* C++ constructor tables */ .mspabi.exidx : {} /* C++ constructor tables */ .mspabi.extab : {} /* C++ constructor tables */ .const : {} /* Constant data */ } ALIGN(0x0200), RUN_START(fram_ro_start) GROUP(EXECUTABLE_MEMORY) { .text : {} /* Code */ } ALIGN(0x0200), RUN_START(fram_rx_start) } > FRAM .jtagsignature : {} > JTAGSIGNATURE /* JTAG Signature */ .bslsignature : {} > BSLSIGNATURE /* BSL Signature */ .jtagpassword /* JTAG Password */ .bss : {} > RAM /* Global & static vars */ .data : {} > RAM /* Global & static vars */ .TI.noinit : {} > RAM /* For #pragma noinit */ .stack : {} > RAM (HIGH) /* Software system stack */ .infoA : {} > INFOA /* MSP430 INFO FRAM Memory segments */ .infoB : {} > INFOB .txlowmem : {} > TXLOWMEM type = NOINIT .rxlowmem : {} > RXLOWMEM type = NOINIT .txrxuppmem00 : {} > TXRXUPPMEM00 type = NOINIT .txuppmem01 : {} > TXUPPMEM01 type = NOINIT .rxuppmem01 : {} > RXUPPMEM01 type = NOINIT .txrxuppmem02 : {} > TXRXUPPMEM02 type = NOINIT .txuppmem03 : {} > TXUPPMEM03 type = NOINIT .rxuppmem03 : {} > RXUPPMEM03 type = NOINIT .txuppmem05 : {} > TXUPPMEM05 type = NOINIT .rxuppmem05 : {} > RXUPPMEM05 type = NOINIT .txuppmem03_rom : {} > TXUPPMEM03_ROM type = NOINIT .rxuppmem03_rom : {} > RXUPPMEM03_ROM type = NOINIT //.txuppmem07 : {} > TXUPPMEM07 type = NOINIT .fram_reserved : {} > FRAM_RESERVED type = NOINIT /* MSP430 Interrupt vectors */ .int00 : {} > INT00 .int01 : {} > INT01 .int02 : {} > INT02 .int03 : {} > INT03 .int04 : {} > INT04 .int05 : {} > INT05 .int06 : {} > INT06 .int07 : {} > INT07 .int08 : {} > INT08 .int09 : {} > INT09 .int10 : {} > INT10 .int11 : {} > INT11 .int12 : {} > INT12 .int13 : {} > INT13 .int14 : {} > INT14 .int15 : {} > INT15 .int16 : {} > INT16 .int17 : {} > INT17 .int18 : {} > INT18 .int19 : {} > INT19 .int20 : {} > INT20 .int21 : {} > INT21 .int22 : {} > INT22 .int23 : {} > INT23 .int24 : {} > INT24 .int25 : {} > INT25 .int26 : {} > INT26 .int27 : {} > INT27 .int28 : {} > INT28 .int29 : {} > INT29 .int30 : {} > INT30 RTC : { * ( .int31 ) } > INT31 type = VECT_INIT .int32 : {} > INT32 .int33 : {} > INT33 .int34 : {} > INT34 .int35 : {} > INT35 PORT2 : { * ( .int36 ) } > INT36 type = VECT_INIT .int37 : {} > INT37 .int38 : {} > INT38 PORT1 : { * ( .int39 ) } > INT39 type = VECT_INIT TIMER1_A1 : { * ( .int40 ) } > INT40 type = VECT_INIT TIMER1_A0 : { * ( .int41 ) } > INT41 type = VECT_INIT DMA : { * ( .int42 ) } > INT42 type = VECT_INIT .int43 : {} > INT43 TIMER0_A1 : { * ( .int44 ) } > INT44 type = VECT_INIT TIMER0_A0 : { * ( .int45 ) } > INT45 type = VECT_INIT ADC10 : { * ( .int46 ) } > INT46 type = VECT_INIT USCI_B0 : { * ( .int47 ) } > INT47 type = VECT_INIT USCI_A0 : { * ( .int48 ) } > INT48 type = VECT_INIT WDT : { * ( .int49 ) } > INT49 type = VECT_INIT TIMER0_B1 : { * ( .int50 ) } > INT50 type = VECT_INIT TIMER0_B0 : { * ( .int51 ) } > INT51 type = VECT_INIT COMP_D : { * ( .int52 ) } > INT52 type = VECT_INIT UNMI : { * ( .int53 ) } > INT53 type = VECT_INIT SYSNMI : { * ( .int54 ) } > INT54 type = VECT_INIT .reset : {} > RESET /* MSP430 Reset vector */ } /****************************************************************************/ /* MPU Specific memory segment definitons */ /****************************************************************************/ #ifdef _MPU_ENABLE #ifdef _MPU_MANUAL mpusb1 = (_MPU_SEGB1 + 0x4000 - 0xFFFF - 1) * 32 / 0x4000 - 1; mpusb2 = (_MPU_SEGB2 + 0x4000 - 0xFFFF - 1) * 32 / 0x4000 - 1; __mpuseg = (mpusb2 << 8) | mpusb1; __mpusam = (_MPU_SAM0 << 12) + (_MPU_SAM3 << 8) + (_MPU_SAM2 << 4) + _MPU_SAM1; #else mpusb1 = (fram_ro_start + 0x4000 - 0xFFFF - 1) * 32 / 0x4000 - 1; mpusb2 = (fram_rx_start + 0x4000 - 0xFFFF - 1) * 32 / 0x4000 - 1; __mpuseg = (mpusb2 << 8) | mpusb1; __mpusam = 0x7513; #endif #endif /****************************************************************************/ /* Include peripherals memory map */ /****************************************************************************/ -l msp430fr5738.cmd
****************************************************************************** MSP430 Linker PC v4.4.3 ****************************************************************************** >> Linked Fri Feb 27 10:26:50 2015 OUTPUT FILE NAME: <PBeta_rev_3_0_0_10_msp430_OBT_live.out> ENTRY POINT SYMBOL: "_c_int00_noargs_noexit" address: 0000fd0a MEMORY CONFIGURATION name origin length used unused attr fill ---------------------- -------- --------- -------- -------- ---- -------- SFR 00000000 00000010 00000000 00000010 RWIX PERIPHERALS_8BIT 00000010 000000f0 00000000 000000f0 RWIX PERIPHERALS_16BIT 00000100 00000100 00000000 00000100 RWIX INFOB 00001800 00000080 00000000 00000080 RWIX INFOA 00001880 00000080 00000000 00000080 RWIX RAM 00001c00 00000400 0000014c 000002b4 RWIX TXLOWMEM 0000c200 00000080 00000080 00000000 RWIX RXLOWMEM 0000c280 00000080 00000080 00000000 RWIX TXRXUPPMEM00 0000c300 00000080 00000080 00000000 RWIX TXUPPMEM01 0000c380 00000080 00000080 00000000 RWIX RXUPPMEM01 0000c400 00000080 00000080 00000000 RWIX TXRXUPPMEM02 0000c480 00000080 00000080 00000000 RWIX TXUPPMEM03 0000c500 00000080 00000080 00000000 RWIX RXUPPMEM03 0000c580 00000080 00000080 00000000 RWIX TXUPPMEM05 0000c600 00000080 00000080 00000000 RWIX RXUPPMEM05 0000c680 00000080 00000080 00000000 RWIX TXUPPMEM03_ROM 0000c700 00000080 00000080 00000000 RWIX RXUPPMEM03_ROM 0000c780 00000080 00000080 00000000 RWIX FRAM 0000c800 00003600 000035e4 0000001c RWIX FRAM_RESERVED 0000fe00 00000180 00000000 00000180 RWIX JTAGSIGNATURE 0000ff80 00000004 00000004 00000000 RWIX ffff BSLSIGNATURE 0000ff84 00000004 00000004 00000000 RWIX ffff IPESIGNATURE 0000ff88 00000008 00000008 00000000 RWIX ffff INT00 0000ff90 00000002 00000000 00000002 RWIX INT01 0000ff92 00000002 00000000 00000002 RWIX INT02 0000ff94 00000002 00000000 00000002 RWIX INT03 0000ff96 00000002 00000000 00000002 RWIX INT04 0000ff98 00000002 00000000 00000002 RWIX INT05 0000ff9a 00000002 00000000 00000002 RWIX INT06 0000ff9c 00000002 00000000 00000002 RWIX INT07 0000ff9e 00000002 00000000 00000002 RWIX INT08 0000ffa0 00000002 00000000 00000002 RWIX INT09 0000ffa2 00000002 00000000 00000002 RWIX INT10 0000ffa4 00000002 00000000 00000002 RWIX INT11 0000ffa6 00000002 00000000 00000002 RWIX INT12 0000ffa8 00000002 00000000 00000002 RWIX INT13 0000ffaa 00000002 00000000 00000002 RWIX INT14 0000ffac 00000002 00000000 00000002 RWIX INT15 0000ffae 00000002 00000000 00000002 RWIX INT16 0000ffb0 00000002 00000000 00000002 RWIX INT17 0000ffb2 00000002 00000000 00000002 RWIX INT18 0000ffb4 00000002 00000000 00000002 RWIX INT19 0000ffb6 00000002 00000000 00000002 RWIX INT20 0000ffb8 00000002 00000000 00000002 RWIX INT21 0000ffba 00000002 00000000 00000002 RWIX INT22 0000ffbc 00000002 00000000 00000002 RWIX INT23 0000ffbe 00000002 00000000 00000002 RWIX INT24 0000ffc0 00000002 00000000 00000002 RWIX INT25 0000ffc2 00000002 00000000 00000002 RWIX INT26 0000ffc4 00000002 00000000 00000002 RWIX INT27 0000ffc6 00000002 00000000 00000002 RWIX INT28 0000ffc8 00000002 00000000 00000002 RWIX INT29 0000ffca 00000002 00000000 00000002 RWIX INT30 0000ffcc 00000002 00000000 00000002 RWIX INT31 0000ffce 00000002 00000002 00000000 RWIX INT32 0000ffd0 00000002 00000000 00000002 RWIX INT33 0000ffd2 00000002 00000000 00000002 RWIX INT34 0000ffd4 00000002 00000000 00000002 RWIX INT35 0000ffd6 00000002 00000000 00000002 RWIX INT36 0000ffd8 00000002 00000002 00000000 RWIX INT37 0000ffda 00000002 00000000 00000002 RWIX INT38 0000ffdc 00000002 00000000 00000002 RWIX INT39 0000ffde 00000002 00000002 00000000 RWIX INT40 0000ffe0 00000002 00000002 00000000 RWIX INT41 0000ffe2 00000002 00000002 00000000 RWIX INT42 0000ffe4 00000002 00000002 00000000 RWIX INT43 0000ffe6 00000002 00000000 00000002 RWIX INT44 0000ffe8 00000002 00000002 00000000 RWIX INT45 0000ffea 00000002 00000002 00000000 RWIX INT46 0000ffec 00000002 00000002 00000000 RWIX INT47 0000ffee 00000002 00000002 00000000 RWIX INT48 0000fff0 00000002 00000002 00000000 RWIX INT49 0000fff2 00000002 00000002 00000000 RWIX INT50 0000fff4 00000002 00000002 00000000 RWIX INT51 0000fff6 00000002 00000002 00000000 RWIX INT52 0000fff8 00000002 00000002 00000000 RWIX INT53 0000fffa 00000002 00000002 00000000 RWIX INT54 0000fffc 00000002 00000002 00000000 RWIX RESET 0000fffe 00000002 00000002 00000000 RWIX SECTION ALLOCATION MAP output attributes/ section page origin length input sections -------- ---- ---------- ---------- ---------------- .data 0 00001c00 00000065 UNINITIALIZED 00001c00 0000002c OBT_ADC.obj (.data) 00001c2c 00000020 OBT_Alarms.obj (.data) 00001c4c 00000016 OBT_I2C_Slave.obj (.data) 00001c62 00000002 OBT_Rx_modify.obj (.data) 00001c64 00000001 OBT_Main.obj (.data) .bss 0 00001c66 00000047 UNINITIALIZED 00001c66 00000020 (.common:ADC_Result) 00001c86 00000020 (.common:DMA_Source) 00001ca6 00000006 (.common:gI2CWriteBuf) 00001cac 00000001 (.common:g_odd) .stack 0 00001f60 000000a0 UNINITIALIZED 00001f60 00000002 rts430x_lc_sd_eabi.lib : boot.obj (.stack) 00001f62 0000009e --HOLE-- .txlowmem * 0 0000c200 00000080 0000c200 00000080 OBT_codemem_init.obj (.txlowmem) .rxlowmem * 0 0000c280 00000080 0000c280 00000080 OBT_codemem_init.obj (.rxlowmem) .txrxuppmem00 * 0 0000c300 00000080 0000c300 00000080 OBT_codemem_init.obj (.txrxuppmem00) .txuppmem01 * 0 0000c380 00000080 0000c380 00000080 OBT_codemem_init.obj (.txuppmem01) .rxuppmem01 * 0 0000c400 00000080 0000c400 00000080 OBT_codemem_init.obj (.rxuppmem01) .txrxuppmem02 * 0 0000c480 00000080 0000c480 00000080 OBT_codemem_init.obj (.txrxuppmem02) .txuppmem03 * 0 0000c500 00000080 0000c500 00000080 OBT_codemem_init.obj (.txuppmem03) .rxuppmem03 * 0 0000c580 00000080 0000c580 00000080 OBT_codemem_init.obj (.rxuppmem03) .txuppmem05 * 0 0000c600 00000080 0000c600 00000080 OBT_codemem_init.obj (.txuppmem05) .rxuppmem05 * 0 0000c680 00000080 0000c680 00000080 OBT_codemem_init.obj (.rxuppmem05) .txuppmem03_rom * 0 0000c700 00000080 0000c700 00000080 OBT_codemem_init.obj (.txuppmem03_rom) .rxuppmem03_rom * 0 0000c780 00000080 0000c780 00000080 OBT_codemem_init.obj (.rxuppmem03_rom) .TI.persistent * 0 0000c800 00000000 UNINITIALIZED .cio 0 0000c800 00000000 UNINITIALIZED .sysmem 0 0000c800 00000000 UNINITIALIZED .cinit 0 0000c800 00000034 0000c800 00000012 (.cinit..data.load) [load image, compression = rle] 0000c812 0000000c (__TI_handler_table) 0000c81e 00000006 (.cinit..bss.load) [load image, compression = zero_init] 0000c824 00000010 (__TI_cinit_table) .pinit 0 0000c834 00000000 UNINITIALIZED .init_array * 0 0000c834 00000000 UNINITIALIZED .mspabi.exidx * 0 0000c834 00000000 UNINITIALIZED .mspabi.extab * 0 0000c834 00000000 UNINITIALIZED .const 0 0000c834 00000000 UNINITIALIZED .text 0 0000ca00 000033e4 0000ca00 00000c9a OBT_I2C_Slave.obj (.text:I2CWrite) 0000d69a 00000370 OBT_I2C_Slave.obj (.text:_isr:USCIB0_ISR) 0000da0a 00000368 OBT_Main.obj (.text:main) 0000dd72 000001a0 OBT_Alarms.obj (.text:CheckMonitors) 0000df12 0000013c OBT_Alarms.obj (.text:update_Intl) 0000e04e 00000130 OBT_Page_init.obj (.text:obt_copy_TxUppMem03_to_TxLowMem) 0000e17e 0000012c OBT_Tx_modify.obj (.text:MSP430_TxSetModeSel) 0000e2aa 0000011a OBT_I2C_Slave.obj (.text:UpdatePswdMatchFlags) 0000e3c4 00000116 OBT_Main.obj (.text:TRX_INIT_STATE) 0000e4da 00000106 OBT_Page_init.obj (.text:obt_copy_RxUppMem03_to_RxLowMem) 0000e5e0 000000f8 OBT_Alarms.obj (.text:CheckRxIRQ) 0000e6d8 000000f8 OBT_Rx_modify.obj (.text:MSP430_RxCoarseEval) 0000e7d0 000000f4 OBT_Rx_modify.obj (.text:MSP430_Rx_init) 0000e8c4 000000e0 OBT_Tx_modify.obj (.text:MSP430_Tx_init) 0000e9a4 000000de OBT_ADC.obj (.text:MSP430_DMA_init) 0000ea82 000000d6 rts430x_lc_sd_eabi.lib : copy_decompress_rle.obj (.text:__TI_decompress_rle_core$10) 0000eb58 000000c6 OBT_Tx_modify.obj (.text:MSP430_TxCDREna) 0000ec1e 000000c4 OBT_Tx_modify.obj (.text:MSP430_TxSingleInputOffsetCali) 0000ece2 000000b8 OBT_Tx_modify.obj (.text:MSP430_Tx_setEqLvl) 0000ed9a 000000aa OBT_Rx_modify.obj (.text:MSP430_RxChConfDis) 0000ee44 000000a6 OBT_Rx_modify.obj (.text:MSP430_RxPolFlip) 0000eeea 000000a2 OBT_I2C_Master.obj (.text:MSP430_I2CMST_getRxAddresses) 0000ef8c 000000a2 OBT_I2C_Master.obj (.text:MSP430_I2CMST_getTxAddresses) 0000f02e 000000a2 OBT_Rx_modify.obj (.text:MSP430_RxCDREna) 0000f0d0 0000009c OBT_Rx_modify.obj (.text:MSP430_Rx_setOutLvl) 0000f16c 00000092 OBT_I2C_Master.obj (.text:MSP430_I2CMST_readMoreFromSlave) 0000f1fe 00000092 OBT_Tx_modify.obj (.text:MSP430_TxChConfDis) 0000f290 00000090 OBT_Tx_modify.obj (.text:MSP430_TxSetDefault) 0000f320 0000008e OBT_Tx_modify.obj (.text:MSP430_TxCDR_Init) 0000f3ae 00000086 OBT_Tx_modify.obj (.text:MSP430_TxPolFlip) 0000f434 00000084 OBT_Rx_modify.obj (.text:MSP430_RxCDR_Init) 0000f4b8 00000080 rts430x_lc_sd_eabi.lib : autoinit_wdt.obj (.text:_auto_init_hold_wdt) 0000f538 0000007e OBT_I2C_Master.obj (.text:MSP430_I2CMST_readFromSlave) 0000f5b6 0000007c OBT_ADC.obj (.text:MSP430_ADC_VHI) 0000f632 0000007c OBT_ADC.obj (.text:MSP430_ADC_VRX) 0000f6ae 0000007a OBT_Page_init.obj (.text:obt_init_Rx_LowMem) 0000f728 0000007a OBT_Page_init.obj (.text:obt_init_Tx_LowMem) 0000f7a2 00000078 OBT_I2C_Master.obj (.text:MSP430_I2CMST_writeByte) 0000f81a 00000070 OBT_ADC.obj (.text:MSP430_ADC_VCC) 0000f88a 00000070 OBT_I2C_Master.obj (.text:MSP430_I2CMST_writeMoreOnSlave) 0000f8fa 00000070 OBT_I2C_Slave.obj (.text:init_i2c_slave) 0000f96a 0000006c OBT_I2C_Master.obj (.text:MSP430_I2CMST_readByte) 0000f9d6 00000066 OBT_I2C_Master.obj (.text:MSP430_I2CMST_writeOnSlave) 0000fa3c 00000056 OBT_I2C_Master.obj (.text:MSP430_I2CMST_findSlaves) 0000fa92 00000054 OBT_ADC.obj (.text:MSP430_ADC_Temp) 0000fae6 00000040 rts430x_lc_sd_eabi.lib : cpy_util.obj (.text:__memcpy_far) 0000fb26 0000003e : copy_zero_init.obj (.text:decompress:ZI:__TI_zero_init) 0000fb64 0000003e : asr32.obj (.text:l_asr_const) 0000fba2 0000003e : lsl32.obj (.text:l_lsl_const) 0000fbe0 0000003e : lsr32.obj (.text:l_lsr_const) 0000fc1e 0000003c : copy_decompress_none.obj (.text:decompress:none:__TI_decompress_none) 0000fc5a 00000034 OBT_I2C_Master.obj (.text:INT_I2C_Analyze_NACK) 0000fc8e 0000002e OBT_Main.obj (.text:_isr:ADC10_ISR) 0000fcbc 0000002c rts430x_lc_sd_eabi.lib : div16s.obj (.text) 0000fce8 00000022 : mult32_f5hw.obj (.text) 0000fd0a 0000001a : boot_special.obj (.text:_isr:_c_int00_noargs_noexit) 0000fd24 0000001a OBT_Page_init.obj (.text:obt_init_Tx_UppMem05) 0000fd3e 00000018 OBT_Page_init.obj (.text:obt_init_Rx_UppMem03) 0000fd56 00000018 OBT_Page_init.obj (.text:obt_init_Tx_UppMem03) 0000fd6e 00000016 rts430x_lc_sd_eabi.lib : div16u.obj (.text) 0000fd84 00000016 : mult16_f5hw.obj (.text) 0000fd9a 00000010 OBT_I2C_Slave.obj (.text:write_to_fram) 0000fdaa 0000000e rts430x_lc_sd_eabi.lib : copy_decompress_rle.obj (.text:decompress:rle24:__TI_decompress_rle24) 0000fdb8 0000000a : asr16.obj (.text) 0000fdc2 0000000a : lsl16.obj (.text) 0000fdcc 0000000a : lsr16.obj (.text) 0000fdd6 00000006 : isr_trap.obj (.text:_isr:__TI_ISR_TRAP) 0000fddc 00000004 : pre_init.obj (.text:_system_pre_init) 0000fde0 00000004 : exit.obj (.text:abort) RTC 0 0000ffce 00000002 0000ffce 00000002 rts430x_lc_sd_eabi.lib : int31.obj (.int31) PORT2 0 0000ffd8 00000002 0000ffd8 00000002 rts430x_lc_sd_eabi.lib : int36.obj (.int36) $fill000 0 0000ff80 00000004 0000ff80 00000004 --HOLE-- [fill = ffff] $fill001 0 0000ff84 00000004 0000ff84 00000004 --HOLE-- [fill = ffff] $fill002 0 0000ff88 00000008 0000ff88 00000008 --HOLE-- [fill = ffff] PORT1 0 0000ffde 00000002 0000ffde 00000002 rts430x_lc_sd_eabi.lib : int39.obj (.int39) TIMER1_A1 * 0 0000ffe0 00000002 0000ffe0 00000002 rts430x_lc_sd_eabi.lib : int40.obj (.int40) TIMER1_A0 * 0 0000ffe2 00000002 0000ffe2 00000002 rts430x_lc_sd_eabi.lib : int41.obj (.int41) DMA 0 0000ffe4 00000002 0000ffe4 00000002 rts430x_lc_sd_eabi.lib : int42.obj (.int42) TIMER0_A1 * 0 0000ffe8 00000002 0000ffe8 00000002 rts430x_lc_sd_eabi.lib : int44.obj (.int44) TIMER0_A0 * 0 0000ffea 00000002 0000ffea 00000002 rts430x_lc_sd_eabi.lib : int45.obj (.int45) ADC10 0 0000ffec 00000002 0000ffec 00000002 <whole-program> (.int46) USCI_B0 0 0000ffee 00000002 0000ffee 00000002 <whole-program> (.int47) USCI_A0 0 0000fff0 00000002 0000fff0 00000002 rts430x_lc_sd_eabi.lib : int48.obj (.int48) WDT 0 0000fff2 00000002 0000fff2 00000002 rts430x_lc_sd_eabi.lib : int49.obj (.int49) TIMER0_B1 * 0 0000fff4 00000002 0000fff4 00000002 rts430x_lc_sd_eabi.lib : int50.obj (.int50) TIMER0_B0 * 0 0000fff6 00000002 0000fff6 00000002 rts430x_lc_sd_eabi.lib : int51.obj (.int51) COMP_D 0 0000fff8 00000002 0000fff8 00000002 rts430x_lc_sd_eabi.lib : int52.obj (.int52) UNMI 0 0000fffa 00000002 0000fffa 00000002 rts430x_lc_sd_eabi.lib : int53.obj (.int53) SYSNMI 0 0000fffc 00000002 0000fffc 00000002 rts430x_lc_sd_eabi.lib : int54.obj (.int54) .reset 0 0000fffe 00000002 0000fffe 00000002 rts430x_lc_sd_eabi.lib : boot.obj (.reset) LINKER GENERATED COPY TABLES __TI_cinit_table @ 0000c824 records: 2, size/record: 8, table size: 16 .data: load addr=0000c800, load size=00000012 bytes, run addr=00001c00, run size=00000065 bytes, compression=rle .bss: load addr=0000c81e, load size=00000006 bytes, run addr=00001c66, run size=00000047 bytes, compression=zero_init LINKER GENERATED HANDLER TABLE __TI_handler_table @ 0000c812 records: 3, size/record: 4, table size: 12 index: 0, handler: __TI_zero_init index: 1, handler: __TI_decompress_rle24 index: 2, handler: __TI_decompress_none GLOBAL SYMBOLS: SORTED ALPHABETICALLY BY Name address name ------- ---- 00000700 ADC10CTL0 00000701 ADC10CTL0_H 00000700 ADC10CTL0_L 00000702 ADC10CTL1 00000703 ADC10CTL1_H 00000702 ADC10CTL1_L 00000704 ADC10CTL2 00000705 ADC10CTL2_H 00000704 ADC10CTL2_L 00000708 ADC10HI 00000709 ADC10HI_H 00000708 ADC10HI_L 0000071a ADC10IE 0000071b ADC10IE_H 0000071a ADC10IE_L 0000071c ADC10IFG 0000071d ADC10IFG_H 0000071c ADC10IFG_L 0000071e ADC10IV 0000071f ADC10IV_H 0000071e ADC10IV_L 00000706 ADC10LO 00000707 ADC10LO_H 00000706 ADC10LO_L 0000070a ADC10MCTL0 0000070b ADC10MCTL0_H 0000070a ADC10MCTL0_L 00000712 ADC10MEM0 00000713 ADC10MEM0_H 00000712 ADC10MEM0_L 0000fc8e ADC10_ISR 00001c66 ADC_Result 00001c04 ADC_Temp_Offset 00001c02 ADC_Temp_Slope 00001c08 ADC_VCC_Offset 000004be BCD2BIN 000004bc BIN2BCD 00001c53 BlockIntI2C 0000fde0 C$$EXIT 000008c0 CDCTL0 000008c1 CDCTL0_H 000008c0 CDCTL0_L 000008c2 CDCTL1 000008c3 CDCTL1_H 000008c2 CDCTL1_L 000008c4 CDCTL2 000008c5 CDCTL2_H 000008c4 CDCTL2_L 000008c6 CDCTL3 000008c7 CDCTL3_H 000008c6 CDCTL3_L 000008cc CDINT 000008cd CDINT_H 000008cc CDINT_L 000008ce CDIV 000008cf CDIV_H 000008ce CDIV_L 00000150 CRCDI 00000152 CRCDIRB 00000153 CRCDIRB_H 00000152 CRCDIRB_L 00000151 CRCDI_H 00000150 CRCDI_L 00000154 CRCINIRES 00000155 CRCINIRES_H 00000154 CRCINIRES_L 00000156 CRCRESR 00000157 CRCRESR_H 00000156 CRCRESR_L 00000160 CSCTL0 00000161 CSCTL0_H 00000160 CSCTL0_L 00000162 CSCTL1 00000163 CSCTL1_H 00000162 CSCTL1_L 00000164 CSCTL2 00000165 CSCTL2_H 00000164 CSCTL2_L 00000166 CSCTL3 00000167 CSCTL3_H 00000166 CSCTL3_L 00000168 CSCTL4 00000169 CSCTL4_H 00000168 CSCTL4_L 0000016a CSCTL5 0000016b CSCTL5_H 0000016a CSCTL5_L 0000016c CSCTL6 0000016d CSCTL6_H 0000016c CSCTL6_L 0000dd72 CheckMonitors 0000e5e0 CheckRxIRQ 00000510 DMA0CTL 00000511 DMA0CTL_H 00000510 DMA0CTL_L 00000516 DMA0DA 00000518 DMA0DAH 00000516 DMA0DAL 00000512 DMA0SA 00000514 DMA0SAH 00000512 DMA0SAL 0000051a DMA0SZ 00000520 DMA1CTL 00000521 DMA1CTL_H 00000520 DMA1CTL_L 00000526 DMA1DA 00000528 DMA1DAH 00000526 DMA1DAL 00000522 DMA1SA 00000524 DMA1SAH 00000522 DMA1SAL 0000052a DMA1SZ 00000530 DMA2CTL 00000531 DMA2CTL_H 00000530 DMA2CTL_L 00000536 DMA2DA 00000538 DMA2DAH 00000536 DMA2DAL 00000532 DMA2SA 00000534 DMA2SAH 00000532 DMA2SAL 0000053a DMA2SZ 00000500 DMACTL0 00000501 DMACTL0_H 00000500 DMACTL0_L 00000502 DMACTL1 00000503 DMACTL1_H 00000502 DMACTL1_L 00000504 DMACTL2 00000505 DMACTL2_H 00000504 DMACTL2_L 00000506 DMACTL3 00000507 DMACTL3_H 00000506 DMACTL3_L 00000508 DMACTL4 00000509 DMACTL4_H 00000508 DMACTL4_L 0000050e DMAIV 0000050f DMAIV_H 0000050e DMAIV_L 00001c86 DMA_Source 00000140 FRCTL0 00000141 FRCTL0_H 00000140 FRCTL0_L 00000144 GCCTL0 00000145 GCCTL0_H 00000144 GCCTL0_L 00000146 GCCTL1 00000147 GCCTL1_H 00000146 GCCTL1_L 0000ca00 I2CWrite 0000fc5a INT_I2C_Analyze_NACK 000004c4 MAC 000004da MAC32H 000004db MAC32H_H 000004da MAC32H_L 000004d8 MAC32L 000004d9 MAC32L_H 000004d8 MAC32L_L 000004c6 MACS 000004de MACS32H 000004df MACS32H_H 000004de MACS32H_L 000004dc MACS32L 000004dd MACS32L_H 000004dc MACS32L_L 000004c7 MACS_H 000004c6 MACS_L 000004c5 MAC_H 000004c4 MAC_L 000005a0 MPUCTL0 000005a1 MPUCTL0_H 000005a0 MPUCTL0_L 000005a2 MPUCTL1 000005a3 MPUCTL1_H 000005a2 MPUCTL1_L 000005a6 MPUSAM 000005a7 MPUSAM_H 000005a6 MPUSAM_L 000005a4 MPUSEG 000005a5 MPUSEG_H 000005a4 MPUSEG_L 000004c0 MPY 000004ec MPY32CTL0 000004ed MPY32CTL0_H 000004ec MPY32CTL0_L 000004d2 MPY32H 000004d3 MPY32H_H 000004d2 MPY32H_L 000004d0 MPY32L 000004d1 MPY32L_H 000004d0 MPY32L_L 000004c2 MPYS 000004d6 MPYS32H 000004d7 MPYS32H_H 000004d6 MPYS32H_L 000004d4 MPYS32L 000004d5 MPYS32L_H 000004d4 MPYS32L_L 000004c3 MPYS_H 000004c2 MPYS_L 000004c1 MPY_H 000004c0 MPY_L 0000fa92 MSP430_ADC_Temp 0000f81a MSP430_ADC_VCC 0000f5b6 MSP430_ADC_VHI 0000f632 MSP430_ADC_VRX 0000e9a4 MSP430_DMA_init 0000fa3c MSP430_I2CMST_findSlaves 0000eeea MSP430_I2CMST_getRxAddresses 0000ef8c MSP430_I2CMST_getTxAddresses 0000f96a MSP430_I2CMST_readByte 0000f538 MSP430_I2CMST_readFromSlave 0000f16c MSP430_I2CMST_readMoreFromSlave 0000f7a2 MSP430_I2CMST_writeByte 0000f88a MSP430_I2CMST_writeMoreOnSlave 0000f9d6 MSP430_I2CMST_writeOnSlave 0000f02e MSP430_RxCDREna 0000f434 MSP430_RxCDR_Init 0000ed9a MSP430_RxChConfDis 0000e6d8 MSP430_RxCoarseEval 0000ee44 MSP430_RxPolFlip 0000e7d0 MSP430_Rx_init 0000f0d0 MSP430_Rx_setOutLvl 0000eb58 MSP430_TxCDREna 0000f320 MSP430_TxCDR_Init 0000f1fe MSP430_TxChConfDis 0000f3ae MSP430_TxPolFlip 0000f290 MSP430_TxSetDefault 0000e17e MSP430_TxSetModeSel 0000ec1e MSP430_TxSingleInputOffsetCali 0000e8c4 MSP430_Tx_init 0000ece2 MSP430_Tx_setEqLvl 000004c8 OP2 000004e2 OP2H 000004e3 OP2H_H 000004e2 OP2H_L 000004e0 OP2L 000004e1 OP2L_H 000004e0 OP2L_L 000004c9 OP2_H 000004c8 OP2_L 0000020e P1IV 0000021e P2IV 00000204 PADIR 00000205 PADIR_H 00000204 PADIR_L 0000021a PAIE 00000218 PAIES 00000219 PAIES_H 00000218 PAIES_L 0000021b PAIE_H 0000021a PAIE_L 0000021c PAIFG 0000021d PAIFG_H 0000021c PAIFG_L 00000200 PAIN 00000201 PAIN_H 00000200 PAIN_L 00000202 PAOUT 00000203 PAOUT_H 00000202 PAOUT_L 00000206 PAREN 00000207 PAREN_H 00000206 PAREN_L 0000020a PASEL0 0000020b PASEL0_H 0000020a PASEL0_L 0000020c PASEL1 0000020d PASEL1_H 0000020c PASEL1_L 00000216 PASELC 00000217 PASELC_H 00000216 PASELC_L 00000324 PJDIR 00000325 PJDIR_H 00000324 PJDIR_L 00000320 PJIN 00000321 PJIN_H 00000320 PJIN_L 00000322 PJOUT 00000323 PJOUT_H 00000322 PJOUT_L 00000326 PJREN 00000327 PJREN_H 00000326 PJREN_L 0000032a PJSEL0 0000032b PJSEL0_H 0000032a PJSEL0_L 0000032c PJSEL1 0000032d PJSEL1_H 0000032c PJSEL1_L 00000336 PJSELC 00000337 PJSELC_H 00000336 PJSELC_L 00000130 PM5CTL0 00000131 PM5CTL0_H 00000130 PM5CTL0_L 00000120 PMMCTL0 00000121 PMMCTL0_H 00000120 PMMCTL0_L 0000012a PMMIFG 0000012b PMMIFG_H 0000012a PMMIFG_L 000001b0 REFCTL0 000001b1 REFCTL0_H 000001b0 REFCTL0_L 000004e4 RES0 000004e5 RES0_H 000004e4 RES0_L 000004e6 RES1 000004e7 RES1_H 000004e6 RES1_L 000004e8 RES2 000004e9 RES2_H 000004e8 RES2_L 000004ea RES3 000004eb RES3_H 000004ea RES3_L 000004cc RESHI 000004cd RESHI_H 000004cc RESHI_L 000004ca RESLO 000004cb RESLO_H 000004ca RESLO_L 000004ba RTCADOWDAY 000004bb RTCADOWDAY_H 000004ba RTCADOWDAY_L 000004b8 RTCAMINHR 000004b9 RTCAMINHR_H 000004b8 RTCAMINHR_L 000004a0 RTCCTL01 000004a1 RTCCTL01_H 000004a0 RTCCTL01_L 000004a2 RTCCTL23 000004a3 RTCCTL23_H 000004a2 RTCCTL23_L 000004b4 RTCDATE 000004b5 RTCDATE_H 000004b4 RTCDATE_L 000004ae RTCIV 000004ac RTCPS 000004a8 RTCPS0CTL 000004a9 RTCPS0CTL_H 000004a8 RTCPS0CTL_L 000004aa RTCPS1CTL 000004ab RTCPS1CTL_H 000004aa RTCPS1CTL_L 000004ad RTCPS_H 000004ac RTCPS_L 000004b0 RTCTIM0 000004b1 RTCTIM0_H 000004b0 RTCTIM0_L 000004b2 RTCTIM1 000004b3 RTCTIM1_H 000004b2 RTCTIM1_L 000004b6 RTCYEAR 000004b7 RTCYEAR_H 000004b6 RTCYEAR_L 00001c5e RX_ADDR 00001c56 RX_CDR_Quick_Mod 0000c280 Rx_LowMem 00001c62 Rx_Thr_Coarse_status 0000c400 Rx_UppMem01 0000c580 Rx_UppMem03 0000c780 Rx_UppMem03_ROM 0000c680 Rx_UppMem05 00000100 SFRIE1 00000101 SFRIE1_H 00000100 SFRIE1_L 00000102 SFRIFG1 00000103 SFRIFG1_H 00000102 SFRIFG1_L 00000104 SFRRPCR 00000105 SFRRPCR_H 00000104 SFRRPCR_L 00001c64 STATE 000004ce SUMEXT 000004cf SUMEXT_H 000004ce SUMEXT_L 00000198 SYSBERRIV 00000199 SYSBERRIV_H 00000198 SYSBERRIV_L 00000182 SYSBSLC 00000183 SYSBSLC_H 00000182 SYSBSLC_L 00000180 SYSCTL 00000181 SYSCTL_H 00000180 SYSCTL_L 00000186 SYSJMBC 00000187 SYSJMBC_H 00000186 SYSJMBC_L 00000188 SYSJMBI0 00000189 SYSJMBI0_H 00000188 SYSJMBI0_L 0000018a SYSJMBI1 0000018b SYSJMBI1_H 0000018a SYSJMBI1_L 0000018c SYSJMBO0 0000018d SYSJMBO0_H 0000018c SYSJMBO0_L 0000018e SYSJMBO1 0000018f SYSJMBO1_H 0000018e SYSJMBO1_L 0000019e SYSRSTIV 0000019f SYSRSTIV_H 0000019e SYSRSTIV_L 0000019c SYSSNIV 0000019d SYSSNIV_H 0000019c SYSSNIV_L 0000019a SYSUNIV 0000019b SYSUNIV_H 0000019a SYSUNIV_L 00000352 TA0CCR0 00000354 TA0CCR1 00000356 TA0CCR2 00000342 TA0CCTL0 00000344 TA0CCTL1 00000346 TA0CCTL2 00000340 TA0CTL 00000360 TA0EX0 0000036e TA0IV 00000350 TA0R 00000392 TA1CCR0 00000394 TA1CCR1 00000396 TA1CCR2 00000382 TA1CCTL0 00000384 TA1CCTL1 00000386 TA1CCTL2 00000380 TA1CTL 000003a0 TA1EX0 000003ae TA1IV 00000390 TA1R 000003d2 TB0CCR0 000003d4 TB0CCR1 000003d6 TB0CCR2 000003c2 TB0CCTL0 000003c4 TB0CCTL1 000003c6 TB0CCTL2 000003c0 TB0CTL 000003e0 TB0EX0 000003ee TB0IV 000003d0 TB0R 0000e3c4 TRX_INIT_STATE 00001c5d TX_ADDR 00001c54 TX_CDR_Quick_Mod 0000c300 TxRx_UppMem00 0000c480 TxRx_UppMem02 0000c200 Tx_LowMem 0000c380 Tx_UppMem01 0000c500 Tx_UppMem03 0000c700 Tx_UppMem03_ROM 0000c600 Tx_UppMem05 000005d0 UCA0ABCTL 000005c6 UCA0BRW 000005c7 UCA0BRW_H 000005c6 UCA0BRW_L 000005c0 UCA0CTLW0 000005c1 UCA0CTLW0_H 000005c0 UCA0CTLW0_L 000005c2 UCA0CTLW1 000005c3 UCA0CTLW1_H 000005c2 UCA0CTLW1_L 000005da UCA0IE 000005db UCA0IE_H 000005da UCA0IE_L 000005dc UCA0IFG 000005dd UCA0IFG_H 000005dc UCA0IFG_L 000005d2 UCA0IRCTL 000005d3 UCA0IRCTL_H 000005d2 UCA0IRCTL_L 000005de UCA0IV 000005c8 UCA0MCTLW 000005c9 UCA0MCTLW_H 000005c8 UCA0MCTLW_L 000005cc UCA0RXBUF 000005cd UCA0RXBUF_H 000005cc UCA0RXBUF_L 000005ca UCA0STATW 000005ce UCA0TXBUF 000005cf UCA0TXBUF_H 000005ce UCA0TXBUF_L 0000065e UCB0ADDMASK 0000065f UCB0ADDMASK_H 0000065e UCB0ADDMASK_L 0000065c UCB0ADDRX 00001c60 UCB0ADDRX_BACKUP 0000065d UCB0ADDRX_H 0000065c UCB0ADDRX_L 00000646 UCB0BRW 00000647 UCB0BRW_H 00000646 UCB0BRW_L 00000640 UCB0CTLW0 00000641 UCB0CTLW0_H 00000640 UCB0CTLW0_L 00000642 UCB0CTLW1 00000643 UCB0CTLW1_H 00000642 UCB0CTLW1_L 00000654 UCB0I2COA0 00000655 UCB0I2COA0_H 00000654 UCB0I2COA0_L 00000656 UCB0I2COA1 00000657 UCB0I2COA1_H 00000656 UCB0I2COA1_L 00000658 UCB0I2COA2 00000659 UCB0I2COA2_H 00000658 UCB0I2COA2_L 0000065a UCB0I2COA3 0000065b UCB0I2COA3_H 0000065a UCB0I2COA3_L 00000660 UCB0I2CSA 00000661 UCB0I2CSA_H 00000660 UCB0I2CSA_L 0000066a UCB0IE 0000066b UCB0IE_H 0000066a UCB0IE_L 0000066c UCB0IFG 0000066d UCB0IFG_H 0000066c UCB0IFG_L 0000066e UCB0IV 0000064c UCB0RXBUF 0000064d UCB0RXBUF_H 0000064c UCB0RXBUF_L 00000648 UCB0STATW 00000649 UCB0STATW_H 00000648 UCB0STATW_L 0000064a UCB0TBCNT 0000064b UCB0TBCNT_H 0000064a UCB0TBCNT_L 0000064e UCB0TXBUF 0000064f UCB0TXBUF_H 0000064e UCB0TXBUF_L 0000d69a USCIB0_ISR 00001c3b UnLatched_RxFlags 00001c2c UnLatched_TxFlags 00001c4a Unlatched_RxAVGLIM 0000e2aa UpdatePswdMatchFlags 0000015c WDTCTL 0000015d WDTCTL_H 0000015c WDTCTL_L 00002000 __STACK_END 000000a0 __STACK_SIZE 0000c824 __TI_CINIT_Base 0000c834 __TI_CINIT_Limit 0000c812 __TI_Handler_Table_Base 0000c81e __TI_Handler_Table_Limit UNDEFED __TI_INITARRAY_Base UNDEFED __TI_INITARRAY_Limit 0000fdd6 __TI_ISR_TRAP 0000fc1e __TI_decompress_none 0000fdaa __TI_decompress_rle24 0000ffce __TI_int31 0000ffd8 __TI_int36 0000ffde __TI_int39 0000ffe0 __TI_int40 0000ffe2 __TI_int41 0000ffe4 __TI_int42 0000ffe8 __TI_int44 0000ffea __TI_int45 0000ffec __TI_int46 0000ffee __TI_int47 0000fff0 __TI_int48 0000fff2 __TI_int49 0000fff4 __TI_int50 0000fff6 __TI_int51 0000fff8 __TI_int52 0000fffa __TI_int53 0000fffc __TI_int54 0000fb26 __TI_zero_init ffffffff __binit__ ffffffff __c_args__ 0000fae6 __memcpy_far 0000fcbc __mspabi_divi 0000fd6e __mspabi_divu 0000fd84 __mspabi_mpyi_f5hw 0000fce8 __mspabi_mpyl_f5hw 0000fcbc __mspabi_remi 0000fd6e __mspabi_remu 0000fdc2 __mspabi_slli 0000fbda __mspabi_slll_1 0000fbb6 __mspabi_slll_10 0000fbb2 __mspabi_slll_11 0000fbae __mspabi_slll_12 0000fbaa __mspabi_slll_13 0000fba6 __mspabi_slll_14 0000fba2 __mspabi_slll_15 0000fbd6 __mspabi_slll_2 0000fbd2 __mspabi_slll_3 0000fbce __mspabi_slll_4 0000fbca __mspabi_slll_5 0000fbc6 __mspabi_slll_6 0000fbc2 __mspabi_slll_7 0000fbbe __mspabi_slll_8 0000fbba __mspabi_slll_9 0000fdb8 __mspabi_srai 0000fb9c __mspabi_sral_1 0000fb78 __mspabi_sral_10 0000fb74 __mspabi_sral_11 0000fb70 __mspabi_sral_12 0000fb6c __mspabi_sral_13 0000fb68 __mspabi_sral_14 0000fb64 __mspabi_sral_15 0000fb98 __mspabi_sral_2 0000fb94 __mspabi_sral_3 0000fb90 __mspabi_sral_4 0000fb8c __mspabi_sral_5 0000fb88 __mspabi_sral_6 0000fb84 __mspabi_sral_7 0000fb80 __mspabi_sral_8 0000fb7c __mspabi_sral_9 0000fdcc __mspabi_srli 0000fc18 __mspabi_srll_1 0000fbf4 __mspabi_srll_10 0000fbf0 __mspabi_srll_11 0000fbec __mspabi_srll_12 0000fbe8 __mspabi_srll_13 0000fbe4 __mspabi_srll_14 0000fbe0 __mspabi_srll_15 0000fc14 __mspabi_srll_2 0000fc10 __mspabi_srll_3 0000fc0c __mspabi_srll_4 0000fc08 __mspabi_srll_5 0000fc04 __mspabi_srll_6 0000fc00 __mspabi_srll_7 0000fbfc __mspabi_srll_8 0000fbf8 __mspabi_srll_9 0000f4b8 _auto_init_hold_wdt 0000fd0a _c_int00_noargs_noexit 0000fffe _reset_vector 00001f60 _stack 0000fddc _system_pre_init 0000fde0 abort ffffffff binit 0000c800 fram_ro_start 0000c800 fram_rw_start 0000ca00 fram_rx_start 00001c50 gHostPasswdChk 00001ca6 gI2CWriteBuf 00001c4e gI2CWriteCnt 00001c4c gI2CWriteRdy 00001c52 gModLPagePWChk 00001c51 gModPasswdChk 00001cac g_odd 0000f8fa init_i2c_slave 0000da0a main 0000e4da obt_copy_RxUppMem03_to_RxLowMem 0000e04e obt_copy_TxUppMem03_to_TxLowMem 0000f6ae obt_init_Rx_LowMem 0000fd3e obt_init_Rx_UppMem03 0000f728 obt_init_Tx_LowMem 0000fd56 obt_init_Tx_UppMem03 0000fd24 obt_init_Tx_UppMem05 00001c58 sI2CMemAdrBuf_A0 00001c5a sI2CMemAdrBuf_A8 00001c5c sI2C_Start_Detected 00001c00 temp 0000df12 update_Intl 0000fd9a write_to_fram GLOBAL SYMBOLS: SORTED BY Symbol Address address name ------- ---- 000000a0 __STACK_SIZE 00000100 SFRIE1 00000100 SFRIE1_L 00000101 SFRIE1_H 00000102 SFRIFG1 00000102 SFRIFG1_L 00000103 SFRIFG1_H 00000104 SFRRPCR 00000104 SFRRPCR_L 00000105 SFRRPCR_H 00000120 PMMCTL0 00000120 PMMCTL0_L 00000121 PMMCTL0_H 0000012a PMMIFG 0000012a PMMIFG_L 0000012b PMMIFG_H 00000130 PM5CTL0 00000130 PM5CTL0_L 00000131 PM5CTL0_H 00000140 FRCTL0 00000140 FRCTL0_L 00000141 FRCTL0_H 00000144 GCCTL0 00000144 GCCTL0_L 00000145 GCCTL0_H 00000146 GCCTL1 00000146 GCCTL1_L 00000147 GCCTL1_H 00000150 CRCDI 00000150 CRCDI_L 00000151 CRCDI_H 00000152 CRCDIRB 00000152 CRCDIRB_L 00000153 CRCDIRB_H 00000154 CRCINIRES 00000154 CRCINIRES_L 00000155 CRCINIRES_H 00000156 CRCRESR 00000156 CRCRESR_L 00000157 CRCRESR_H 0000015c WDTCTL 0000015c WDTCTL_L 0000015d WDTCTL_H 00000160 CSCTL0 00000160 CSCTL0_L 00000161 CSCTL0_H 00000162 CSCTL1 00000162 CSCTL1_L 00000163 CSCTL1_H 00000164 CSCTL2 00000164 CSCTL2_L 00000165 CSCTL2_H 00000166 CSCTL3 00000166 CSCTL3_L 00000167 CSCTL3_H 00000168 CSCTL4 00000168 CSCTL4_L 00000169 CSCTL4_H 0000016a CSCTL5 0000016a CSCTL5_L 0000016b CSCTL5_H 0000016c CSCTL6 0000016c CSCTL6_L 0000016d CSCTL6_H 00000180 SYSCTL 00000180 SYSCTL_L 00000181 SYSCTL_H 00000182 SYSBSLC 00000182 SYSBSLC_L 00000183 SYSBSLC_H 00000186 SYSJMBC 00000186 SYSJMBC_L 00000187 SYSJMBC_H 00000188 SYSJMBI0 00000188 SYSJMBI0_L 00000189 SYSJMBI0_H 0000018a SYSJMBI1 0000018a SYSJMBI1_L 0000018b SYSJMBI1_H 0000018c SYSJMBO0 0000018c SYSJMBO0_L 0000018d SYSJMBO0_H 0000018e SYSJMBO1 0000018e SYSJMBO1_L 0000018f SYSJMBO1_H 00000198 SYSBERRIV 00000198 SYSBERRIV_L 00000199 SYSBERRIV_H 0000019a SYSUNIV 0000019a SYSUNIV_L 0000019b SYSUNIV_H 0000019c SYSSNIV 0000019c SYSSNIV_L 0000019d SYSSNIV_H 0000019e SYSRSTIV 0000019e SYSRSTIV_L 0000019f SYSRSTIV_H 000001b0 REFCTL0 000001b0 REFCTL0_L 000001b1 REFCTL0_H 00000200 PAIN 00000200 PAIN_L 00000201 PAIN_H 00000202 PAOUT 00000202 PAOUT_L 00000203 PAOUT_H 00000204 PADIR 00000204 PADIR_L 00000205 PADIR_H 00000206 PAREN 00000206 PAREN_L 00000207 PAREN_H 0000020a PASEL0 0000020a PASEL0_L 0000020b PASEL0_H 0000020c PASEL1 0000020c PASEL1_L 0000020d PASEL1_H 0000020e P1IV 00000216 PASELC 00000216 PASELC_L 00000217 PASELC_H 00000218 PAIES 00000218 PAIES_L 00000219 PAIES_H 0000021a PAIE 0000021a PAIE_L 0000021b PAIE_H 0000021c PAIFG 0000021c PAIFG_L 0000021d PAIFG_H 0000021e P2IV 00000320 PJIN 00000320 PJIN_L 00000321 PJIN_H 00000322 PJOUT 00000322 PJOUT_L 00000323 PJOUT_H 00000324 PJDIR 00000324 PJDIR_L 00000325 PJDIR_H 00000326 PJREN 00000326 PJREN_L 00000327 PJREN_H 0000032a PJSEL0 0000032a PJSEL0_L 0000032b PJSEL0_H 0000032c PJSEL1 0000032c PJSEL1_L 0000032d PJSEL1_H 00000336 PJSELC 00000336 PJSELC_L 00000337 PJSELC_H 00000340 TA0CTL 00000342 TA0CCTL0 00000344 TA0CCTL1 00000346 TA0CCTL2 00000350 TA0R 00000352 TA0CCR0 00000354 TA0CCR1 00000356 TA0CCR2 00000360 TA0EX0 0000036e TA0IV 00000380 TA1CTL 00000382 TA1CCTL0 00000384 TA1CCTL1 00000386 TA1CCTL2 00000390 TA1R 00000392 TA1CCR0 00000394 TA1CCR1 00000396 TA1CCR2 000003a0 TA1EX0 000003ae TA1IV 000003c0 TB0CTL 000003c2 TB0CCTL0 000003c4 TB0CCTL1 000003c6 TB0CCTL2 000003d0 TB0R 000003d2 TB0CCR0 000003d4 TB0CCR1 000003d6 TB0CCR2 000003e0 TB0EX0 000003ee TB0IV 000004a0 RTCCTL01 000004a0 RTCCTL01_L 000004a1 RTCCTL01_H 000004a2 RTCCTL23 000004a2 RTCCTL23_L 000004a3 RTCCTL23_H 000004a8 RTCPS0CTL 000004a8 RTCPS0CTL_L 000004a9 RTCPS0CTL_H 000004aa RTCPS1CTL 000004aa RTCPS1CTL_L 000004ab RTCPS1CTL_H 000004ac RTCPS 000004ac RTCPS_L 000004ad RTCPS_H 000004ae RTCIV 000004b0 RTCTIM0 000004b0 RTCTIM0_L 000004b1 RTCTIM0_H 000004b2 RTCTIM1 000004b2 RTCTIM1_L 000004b3 RTCTIM1_H 000004b4 RTCDATE 000004b4 RTCDATE_L 000004b5 RTCDATE_H 000004b6 RTCYEAR 000004b6 RTCYEAR_L 000004b7 RTCYEAR_H 000004b8 RTCAMINHR 000004b8 RTCAMINHR_L 000004b9 RTCAMINHR_H 000004ba RTCADOWDAY 000004ba RTCADOWDAY_L 000004bb RTCADOWDAY_H 000004bc BIN2BCD 000004be BCD2BIN 000004c0 MPY 000004c0 MPY_L 000004c1 MPY_H 000004c2 MPYS 000004c2 MPYS_L 000004c3 MPYS_H 000004c4 MAC 000004c4 MAC_L 000004c5 MAC_H 000004c6 MACS 000004c6 MACS_L 000004c7 MACS_H 000004c8 OP2 000004c8 OP2_L 000004c9 OP2_H 000004ca RESLO 000004ca RESLO_L 000004cb RESLO_H 000004cc RESHI 000004cc RESHI_L 000004cd RESHI_H 000004ce SUMEXT 000004ce SUMEXT_L 000004cf SUMEXT_H 000004d0 MPY32L 000004d0 MPY32L_L 000004d1 MPY32L_H 000004d2 MPY32H 000004d2 MPY32H_L 000004d3 MPY32H_H 000004d4 MPYS32L 000004d4 MPYS32L_L 000004d5 MPYS32L_H 000004d6 MPYS32H 000004d6 MPYS32H_L 000004d7 MPYS32H_H 000004d8 MAC32L 000004d8 MAC32L_L 000004d9 MAC32L_H 000004da MAC32H 000004da MAC32H_L 000004db MAC32H_H 000004dc MACS32L 000004dc MACS32L_L 000004dd MACS32L_H 000004de MACS32H 000004de MACS32H_L 000004df MACS32H_H 000004e0 OP2L 000004e0 OP2L_L 000004e1 OP2L_H 000004e2 OP2H 000004e2 OP2H_L 000004e3 OP2H_H 000004e4 RES0 000004e4 RES0_L 000004e5 RES0_H 000004e6 RES1 000004e6 RES1_L 000004e7 RES1_H 000004e8 RES2 000004e8 RES2_L 000004e9 RES2_H 000004ea RES3 000004ea RES3_L 000004eb RES3_H 000004ec MPY32CTL0 000004ec MPY32CTL0_L 000004ed MPY32CTL0_H 00000500 DMACTL0 00000500 DMACTL0_L 00000501 DMACTL0_H 00000502 DMACTL1 00000502 DMACTL1_L 00000503 DMACTL1_H 00000504 DMACTL2 00000504 DMACTL2_L 00000505 DMACTL2_H 00000506 DMACTL3 00000506 DMACTL3_L 00000507 DMACTL3_H 00000508 DMACTL4 00000508 DMACTL4_L 00000509 DMACTL4_H 0000050e DMAIV 0000050e DMAIV_L 0000050f DMAIV_H 00000510 DMA0CTL 00000510 DMA0CTL_L 00000511 DMA0CTL_H 00000512 DMA0SA 00000512 DMA0SAL 00000514 DMA0SAH 00000516 DMA0DA 00000516 DMA0DAL 00000518 DMA0DAH 0000051a DMA0SZ 00000520 DMA1CTL 00000520 DMA1CTL_L 00000521 DMA1CTL_H 00000522 DMA1SA 00000522 DMA1SAL 00000524 DMA1SAH 00000526 DMA1DA 00000526 DMA1DAL 00000528 DMA1DAH 0000052a DMA1SZ 00000530 DMA2CTL 00000530 DMA2CTL_L 00000531 DMA2CTL_H 00000532 DMA2SA 00000532 DMA2SAL 00000534 DMA2SAH 00000536 DMA2DA 00000536 DMA2DAL 00000538 DMA2DAH 0000053a DMA2SZ 000005a0 MPUCTL0 000005a0 MPUCTL0_L 000005a1 MPUCTL0_H 000005a2 MPUCTL1 000005a2 MPUCTL1_L 000005a3 MPUCTL1_H 000005a4 MPUSEG 000005a4 MPUSEG_L 000005a5 MPUSEG_H 000005a6 MPUSAM 000005a6 MPUSAM_L 000005a7 MPUSAM_H 000005c0 UCA0CTLW0 000005c0 UCA0CTLW0_L 000005c1 UCA0CTLW0_H 000005c2 UCA0CTLW1 000005c2 UCA0CTLW1_L 000005c3 UCA0CTLW1_H 000005c6 UCA0BRW 000005c6 UCA0BRW_L 000005c7 UCA0BRW_H 000005c8 UCA0MCTLW 000005c8 UCA0MCTLW_L 000005c9 UCA0MCTLW_H 000005ca UCA0STATW 000005cc UCA0RXBUF 000005cc UCA0RXBUF_L 000005cd UCA0RXBUF_H 000005ce UCA0TXBUF 000005ce UCA0TXBUF_L 000005cf UCA0TXBUF_H 000005d0 UCA0ABCTL 000005d2 UCA0IRCTL 000005d2 UCA0IRCTL_L 000005d3 UCA0IRCTL_H 000005da UCA0IE 000005da UCA0IE_L 000005db UCA0IE_H 000005dc UCA0IFG 000005dc UCA0IFG_L 000005dd UCA0IFG_H 000005de UCA0IV 00000640 UCB0CTLW0 00000640 UCB0CTLW0_L 00000641 UCB0CTLW0_H 00000642 UCB0CTLW1 00000642 UCB0CTLW1_L 00000643 UCB0CTLW1_H 00000646 UCB0BRW 00000646 UCB0BRW_L 00000647 UCB0BRW_H 00000648 UCB0STATW 00000648 UCB0STATW_L 00000649 UCB0STATW_H 0000064a UCB0TBCNT 0000064a UCB0TBCNT_L 0000064b UCB0TBCNT_H 0000064c UCB0RXBUF 0000064c UCB0RXBUF_L 0000064d UCB0RXBUF_H 0000064e UCB0TXBUF 0000064e UCB0TXBUF_L 0000064f UCB0TXBUF_H 00000654 UCB0I2COA0 00000654 UCB0I2COA0_L 00000655 UCB0I2COA0_H 00000656 UCB0I2COA1 00000656 UCB0I2COA1_L 00000657 UCB0I2COA1_H 00000658 UCB0I2COA2 00000658 UCB0I2COA2_L 00000659 UCB0I2COA2_H 0000065a UCB0I2COA3 0000065a UCB0I2COA3_L 0000065b UCB0I2COA3_H 0000065c UCB0ADDRX 0000065c UCB0ADDRX_L 0000065d UCB0ADDRX_H 0000065e UCB0ADDMASK 0000065e UCB0ADDMASK_L 0000065f UCB0ADDMASK_H 00000660 UCB0I2CSA 00000660 UCB0I2CSA_L 00000661 UCB0I2CSA_H 0000066a UCB0IE 0000066a UCB0IE_L 0000066b UCB0IE_H 0000066c UCB0IFG 0000066c UCB0IFG_L 0000066d UCB0IFG_H 0000066e UCB0IV 00000700 ADC10CTL0 00000700 ADC10CTL0_L 00000701 ADC10CTL0_H 00000702 ADC10CTL1 00000702 ADC10CTL1_L 00000703 ADC10CTL1_H 00000704 ADC10CTL2 00000704 ADC10CTL2_L 00000705 ADC10CTL2_H 00000706 ADC10LO 00000706 ADC10LO_L 00000707 ADC10LO_H 00000708 ADC10HI 00000708 ADC10HI_L 00000709 ADC10HI_H 0000070a ADC10MCTL0 0000070a ADC10MCTL0_L 0000070b ADC10MCTL0_H 00000712 ADC10MEM0 00000712 ADC10MEM0_L 00000713 ADC10MEM0_H 0000071a ADC10IE 0000071a ADC10IE_L 0000071b ADC10IE_H 0000071c ADC10IFG 0000071c ADC10IFG_L 0000071d ADC10IFG_H 0000071e ADC10IV 0000071e ADC10IV_L 0000071f ADC10IV_H 000008c0 CDCTL0 000008c0 CDCTL0_L 000008c1 CDCTL0_H 000008c2 CDCTL1 000008c2 CDCTL1_L 000008c3 CDCTL1_H 000008c4 CDCTL2 000008c4 CDCTL2_L 000008c5 CDCTL2_H 000008c6 CDCTL3 000008c6 CDCTL3_L 000008c7 CDCTL3_H 000008cc CDINT 000008cc CDINT_L 000008cd CDINT_H 000008ce CDIV 000008ce CDIV_L 000008cf CDIV_H 00001c00 temp 00001c02 ADC_Temp_Slope 00001c04 ADC_Temp_Offset 00001c08 ADC_VCC_Offset 00001c2c UnLatched_TxFlags 00001c3b UnLatched_RxFlags 00001c4a Unlatched_RxAVGLIM 00001c4c gI2CWriteRdy 00001c4e gI2CWriteCnt 00001c50 gHostPasswdChk 00001c51 gModPasswdChk 00001c52 gModLPagePWChk 00001c53 BlockIntI2C 00001c54 TX_CDR_Quick_Mod 00001c56 RX_CDR_Quick_Mod 00001c58 sI2CMemAdrBuf_A0 00001c5a sI2CMemAdrBuf_A8 00001c5c sI2C_Start_Detected 00001c5d TX_ADDR 00001c5e RX_ADDR 00001c60 UCB0ADDRX_BACKUP 00001c62 Rx_Thr_Coarse_status 00001c64 STATE 00001c66 ADC_Result 00001c86 DMA_Source 00001ca6 gI2CWriteBuf 00001cac g_odd 00001f60 _stack 00002000 __STACK_END 0000c200 Tx_LowMem 0000c280 Rx_LowMem 0000c300 TxRx_UppMem00 0000c380 Tx_UppMem01 0000c400 Rx_UppMem01 0000c480 TxRx_UppMem02 0000c500 Tx_UppMem03 0000c580 Rx_UppMem03 0000c600 Tx_UppMem05 0000c680 Rx_UppMem05 0000c700 Tx_UppMem03_ROM 0000c780 Rx_UppMem03_ROM 0000c800 fram_ro_start 0000c800 fram_rw_start 0000c812 __TI_Handler_Table_Base 0000c81e __TI_Handler_Table_Limit 0000c824 __TI_CINIT_Base 0000c834 __TI_CINIT_Limit 0000ca00 I2CWrite 0000ca00 fram_rx_start 0000d69a USCIB0_ISR 0000da0a main 0000dd72 CheckMonitors 0000df12 update_Intl 0000e04e obt_copy_TxUppMem03_to_TxLowMem 0000e17e MSP430_TxSetModeSel 0000e2aa UpdatePswdMatchFlags 0000e3c4 TRX_INIT_STATE 0000e4da obt_copy_RxUppMem03_to_RxLowMem 0000e5e0 CheckRxIRQ 0000e6d8 MSP430_RxCoarseEval 0000e7d0 MSP430_Rx_init 0000e8c4 MSP430_Tx_init 0000e9a4 MSP430_DMA_init 0000eb58 MSP430_TxCDREna 0000ec1e MSP430_TxSingleInputOffsetCali 0000ece2 MSP430_Tx_setEqLvl 0000ed9a MSP430_RxChConfDis 0000ee44 MSP430_RxPolFlip 0000eeea MSP430_I2CMST_getRxAddresses 0000ef8c MSP430_I2CMST_getTxAddresses 0000f02e MSP430_RxCDREna 0000f0d0 MSP430_Rx_setOutLvl 0000f16c MSP430_I2CMST_readMoreFromSlave 0000f1fe MSP430_TxChConfDis 0000f290 MSP430_TxSetDefault 0000f320 MSP430_TxCDR_Init 0000f3ae MSP430_TxPolFlip 0000f434 MSP430_RxCDR_Init 0000f4b8 _auto_init_hold_wdt 0000f538 MSP430_I2CMST_readFromSlave 0000f5b6 MSP430_ADC_VHI 0000f632 MSP430_ADC_VRX 0000f6ae obt_init_Rx_LowMem 0000f728 obt_init_Tx_LowMem 0000f7a2 MSP430_I2CMST_writeByte 0000f81a MSP430_ADC_VCC 0000f88a MSP430_I2CMST_writeMoreOnSlave 0000f8fa init_i2c_slave 0000f96a MSP430_I2CMST_readByte 0000f9d6 MSP430_I2CMST_writeOnSlave 0000fa3c MSP430_I2CMST_findSlaves 0000fa92 MSP430_ADC_Temp 0000fae6 __memcpy_far 0000fb26 __TI_zero_init 0000fb64 __mspabi_sral_15 0000fb68 __mspabi_sral_14 0000fb6c __mspabi_sral_13 0000fb70 __mspabi_sral_12 0000fb74 __mspabi_sral_11 0000fb78 __mspabi_sral_10 0000fb7c __mspabi_sral_9 0000fb80 __mspabi_sral_8 0000fb84 __mspabi_sral_7 0000fb88 __mspabi_sral_6 0000fb8c __mspabi_sral_5 0000fb90 __mspabi_sral_4 0000fb94 __mspabi_sral_3 0000fb98 __mspabi_sral_2 0000fb9c __mspabi_sral_1 0000fba2 __mspabi_slll_15 0000fba6 __mspabi_slll_14 0000fbaa __mspabi_slll_13 0000fbae __mspabi_slll_12 0000fbb2 __mspabi_slll_11 0000fbb6 __mspabi_slll_10 0000fbba __mspabi_slll_9 0000fbbe __mspabi_slll_8 0000fbc2 __mspabi_slll_7 0000fbc6 __mspabi_slll_6 0000fbca __mspabi_slll_5 0000fbce __mspabi_slll_4 0000fbd2 __mspabi_slll_3 0000fbd6 __mspabi_slll_2 0000fbda __mspabi_slll_1 0000fbe0 __mspabi_srll_15 0000fbe4 __mspabi_srll_14 0000fbe8 __mspabi_srll_13 0000fbec __mspabi_srll_12 0000fbf0 __mspabi_srll_11 0000fbf4 __mspabi_srll_10 0000fbf8 __mspabi_srll_9 0000fbfc __mspabi_srll_8 0000fc00 __mspabi_srll_7 0000fc04 __mspabi_srll_6 0000fc08 __mspabi_srll_5 0000fc0c __mspabi_srll_4 0000fc10 __mspabi_srll_3 0000fc14 __mspabi_srll_2 0000fc18 __mspabi_srll_1 0000fc1e __TI_decompress_none 0000fc5a INT_I2C_Analyze_NACK 0000fc8e ADC10_ISR 0000fcbc __mspabi_divi 0000fcbc __mspabi_remi 0000fce8 __mspabi_mpyl_f5hw 0000fd0a _c_int00_noargs_noexit 0000fd24 obt_init_Tx_UppMem05 0000fd3e obt_init_Rx_UppMem03 0000fd56 obt_init_Tx_UppMem03 0000fd6e __mspabi_divu 0000fd6e __mspabi_remu 0000fd84 __mspabi_mpyi_f5hw 0000fd9a write_to_fram 0000fdaa __TI_decompress_rle24 0000fdb8 __mspabi_srai 0000fdc2 __mspabi_slli 0000fdcc __mspabi_srli 0000fdd6 __TI_ISR_TRAP 0000fddc _system_pre_init 0000fde0 C$$EXIT 0000fde0 abort 0000ffce __TI_int31 0000ffd8 __TI_int36 0000ffde __TI_int39 0000ffe0 __TI_int40 0000ffe2 __TI_int41 0000ffe4 __TI_int42 0000ffe8 __TI_int44 0000ffea __TI_int45 0000ffec __TI_int46 0000ffee __TI_int47 0000fff0 __TI_int48 0000fff2 __TI_int49 0000fff4 __TI_int50 0000fff6 __TI_int51 0000fff8 __TI_int52 0000fffa __TI_int53 0000fffc __TI_int54 0000fffe _reset_vector ffffffff __binit__ ffffffff __c_args__ ffffffff binit UNDEFED __TI_INITARRAY_Base UNDEFED __TI_INITARRAY_Limit [659 symbols]
