Hi everyone;
first of all, i'm new at MSP430. i use msp430f5529 exp board and i want to work on adc12 module. here, i have 4 analog input signal and their frequencies are 4000hz, 2000 hz, 1000hz, 500hz respectively. how can i saved digital output values at memory? i used demo code but i dont know how can i change frequency values? please help me..
//****************************************************************************** // MSP430F54x Demo - ADC12, Repeated Sequence of Conversions // // Description: This example shows how to perform a repeated sequence of // conversions using "repeat sequence-of-channels" mode. AVcc is used for the // reference and repeated sequence of conversions is performed on Channels A0, // A1, A2, and A3. Each conversion result is stored in ADC12MEM0, ADC12MEM1, // ADC12MEM2, and ADC12MEM3 respectively. After each sequence, the 4 conversion // results are moved to A0results[], A1results[], A2results[], and A3results[]. // Test by applying voltages to channels A0 - A3. Open a watch window in // debugger and view the results. Set Breakpoint1 in the index increment line // to see the array values change sequentially and Breakpoint2 to see the entire // array of conversion results in A0results[], A1results[], A2results[], and // A3results[]for the specified Num_of_Results. // // Note that a sequence has no restrictions on which channels are converted. // For example, a valid sequence could be A0, A3, A2, A4, A2, A1, A0, and A7. // See the MSP430x1xx User's Guide for instructions on using the ADC12. // // MSP430F5438 // ----------------- // /|\| | // | | | // --|RST | // | | // Vin0 -->|P6.0/A0 | // Vin1 -->|P6.1/A1 | // Vin2 -->|P6.2/A2 | // Vin3 -->|P6.3/A3 | // | | // // M Smertneck / W. Goh // Texas Instruments Inc. // September 2008 // Built with CCE Version: 3.2.2 and IAR Embedded Workbench Version: 4.11B //****************************************************************************** #include "msp430x54x.h" #define Num_of_Results 8 volatile unsigned int A0results[Num_of_Results]; volatile unsigned int A1results[Num_of_Results]; volatile unsigned int A2results[Num_of_Results]; volatile unsigned int A3results[Num_of_Results]; void main(void) { WDTCTL = WDTPW+WDTHOLD; // Stop watchdog timer P6SEL = 0x0F; // Enable A/D channel inputs ADC12CTL0 = ADC12ON+ADC12MSC+ADC12SHT0_8; // Turn on ADC12, extend sampling time // to avoid overflow of results ADC12CTL1 = ADC12SHP+ADC12CONSEQ_3; // Use sampling timer, repeated sequence ADC12MCTL0 = ADC12INCH_0; // ref+=AVcc, channel = A0 ADC12MCTL1 = ADC12INCH_1; // ref+=AVcc, channel = A1 ADC12MCTL2 = ADC12INCH_2; // ref+=AVcc, channel = A2 ADC12MCTL3 = ADC12INCH_3+ADC12EOS; // ref+=AVcc, channel = A3, end seq. ADC12IE = 0x08; // Enable ADC12IFG.3 ADC12CTL0 |= ADC12ENC; // Enable conversions ADC12CTL0 |= ADC12SC; // Start convn - software trigger __bis_SR_register(LPM0_bits + GIE); // Enter LPM0, Enable interrupts __no_operation(); // For debugger } #pragma vector=ADC12_VECTOR __interrupt void ADC12ISR (void) { static unsigned int index = 0; switch(__even_in_range(ADC12IV,34)) { case 0: break; // Vector 0: No interrupt case 2: break; // Vector 2: ADC overflow case 4: break; // Vector 4: ADC timing overflow case 6: break; // Vector 6: ADC12IFG0 case 8: break; // Vector 8: ADC12IFG1 case 10: break; // Vector 10: ADC12IFG2 case 12: // Vector 12: ADC12IFG3 A0results[index] = ADC12MEM0; // Move A0 results, IFG is cleared A1results[index] = ADC12MEM1; // Move A1 results, IFG is cleared A2results[index] = ADC12MEM2; // Move A2 results, IFG is cleared A3results[index] = ADC12MEM3; // Move A3 results, IFG is cleared index++; // Increment results index, modulo; Set Breakpoint1 here if (index == 8) { (index = 0); } case 14: break; // Vector 14: ADC12IFG4 case 16: break; // Vector 16: ADC12IFG5 case 18: break; // Vector 18: ADC12IFG6 case 20: break; // Vector 20: ADC12IFG7 case 22: break; // Vector 22: ADC12IFG8 case 24: break; // Vector 24: ADC12IFG9 case 26: break; // Vector 26: ADC12IFG10 case 28: break; // Vector 28: ADC12IFG11 case 30: break; // Vector 30: ADC12IFG12 case 32: break; // Vector 32: ADC12IFG13 case 34: break; // Vector 34: ADC12IFG14 default: break; } }
