Retrieve the stored code from the MSP430 launchpad KIt
Other Parts Discussed in Thread: MSP430F5529, MSP430WARE, MSP430FE425
Is it possible to Retrieve the stored/uploaded code from the MSP430 launchpad since I lost my source code.
Kindly mention the steps if any.
    So the MSP430Flasher.exe program can be used to retrieve the code with the draw back that the data will be in binary format.   If you download the MSP430Flasher software, it also contains documentation on how to use the tool.
    So for example if you want to capture the info in MAIN area of memory (refer  to the user guide to see what address range is designated as MAIN memory area) you can type in the following command to read the info to a .txt file:
    MSP430Flasher.exe -n MSP430F5529 -r [name_of_your_file_MAIN.txt, MAIN]
    You can also capture the data in RAM, BSL and INFO memory as well as a specified memory range using the same method above.  The documentation also lists the area of memory that is locked and will have to be unlocked before any operation can be performed.
    Arthi Bhat
  • yes, but it will not be the source code you are getting back in the way you think it will be, I'm guessing.
    You do understand that the compiler change everything to machinecode (compiled assembly) before it sends it to the flash memory.
    e.g C is not a runtime interpreted language.
  • And once you have binary, IDA can be used for reverse engineering.
    https://www.hex-rays.com/products/ida/index.shtml
  • zrno, have you tried it? Do you get something useful out of it?
  • One other option - I think that msp430ware has the software for all of the launchpad demos - you should be able to retreive the "lost" software for your particular demo.
    Greetings & Thanks for your support.
    I'm not able to recollect the exact name of the file which I uploaded in my launchpad. Is there any possibility to recover the whole memory.
    I also need to recover my code from MSP430FE425 which I had used in an energy meter application.
    Since I lost all my project work in an unavoidable situation.
    Thanks in advance.
    -Raja Raghavan.M
    Greetings,
    Thanks for your support, after your advice I decided to give a try by uploading a simple blink program in another launchpad and using MSP430Flasher.exe .
    I have attached the file which I extracted.
    output.txt
    @C000
    0A 12 09 12 3F 40 00 00 3F 90 01 00 19 28 3F 40
    00 00 3F 90 01 00 14 28 3A 40 00 00 3A 80 00 00
    3A 50 03 00 0A 11 0A 11 39 40 00 00 3C 49 7F 4C
    4F 4F 0F 5F 1F 4F 00 00 3D 49 8F 12 1A 83 F6 23
    3F 40 00 00 3F 90 00 00 08 24 3A 40 00 00 02 3C
    3F 4A 8F 12 3A 90 00 00 FB 23 30 40 A4 C0 21 83
    B2 40 80 5A 20 01 D2 D3 22 00 D2 E3 21 00 B1 40
    40 42 00 00 91 83 00 00 81 93 00 00 F6 27 FA 3F
    31 40 00 04 B0 12 AA C0 0C 93 02 24 B0 12 00 C0
    0C 43 B0 12 5E C0 B0 12 AE C0 34 41 35 41 36 41
    37 41 38 41 39 41 3A 41 30 41 1C 43 30 41 03 43
    FF 3F FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    FF FF FF FF FF FF FF FF FF FF FF FF FF FF 80 C0
    q
    Kindly advice me, how to convert it to programming file if its possible.
    Thanks in advance,
    -Raja Raghavan.M
  • Have you tried Arthi Bhat's earlier instructions?
    From what he stated, the .txt file that you have should be sufficient to use with MSP430Flasher to update your errant board.
  • Making a complete copy is easy, just read all of Main Flash and save as TI-hex files, then use that to write to a new mcu.
    Getting complete source code back is impossible, you can get assembler code back though without any proper labels and notations.
    Could be OK if you are good with assembler and need to change some values here and there.
    Do yourself a favor:
    Write the code from scratch again, plus it will always be better the second time around especially if new features was added and merged in to the code later.
