I want the measure the brightness with a photodiode with the SD16_A and wanted to use the attached circuit. I want the possibility to turn the photodiode-circuit off to save power. I taught I set P1.7 as an output and low during the measurement, otherwise high. I want to measure the voltage drop on the resistor.
Will this work or is it impossible the measure the voltage of a pin configured as output?
Thank you
