I'm trying to register and enable timer interrupts using DriverLib. I was successfully able to do this for a GPIO interrupt, but I haven't been able to get it working for the timers. The timer registers and clock system registers seem to be being configured correctly. My code is included below. I would greatly appreciate any help or insight.
// Includes #include "driverlib.h" // Macros #define main_BUTTON_PORT (GPIO_PORT_P1) #define main_BUTTON_PIN (GPIO_PIN1) #define main_GREEN_PORT (GPIO_PORT_P2) #define main_GREEN_PIN (GPIO_PIN1) #define main_RED_PORT (GPIO_PORT_P1) #define main_RED_PIN (GPIO_PIN0) #define main_TIMER_ONEMIN_MODULE (TIMER_A0_MODULE) #define main_TIMER_ONEMIN_CLOCK (TIMER_A_CLOCKSOURCE_SMCLK) #define main_TIMER_ONEMIN_CLOCKDIVIDER (TIMER_A_CLOCKSOURCE_DIVIDER_64) #define main_TIMER_ONEMIN_PERIOD (58594) // Assumes 62.5kHz clock with divider of 64 #define main_TIMER_QUARTERSEC_MODULE (TIMER_A1_MODULE) #define main_TIMER_QUARTERSEC_CLOCK (TIMER_A_CLOCKSOURCE_SMCLK) #define main_TIMER_QUARTERSEC_CLOCKDIVIDER (TIMER_A_CLOCKSOURCE_DIVIDER_1) #define main_TIMER_QUARTERSEC_PERIOD (15625) // Assumes 62.5kHz clock with divider of 1 #define main_TIMER_ONESEC_MODULE (TIMER_A2_MODULE) #define main_TIMER_ONESEC_CLOCK (TIMER_A_CLOCKSOURCE_SMCLK) #define main_TIMER_ONESEC_CLOCKDIVIDER (TIMER_A_CLOCKSOURCE_DIVIDER_1) #define main_TIMER_ONESEC_PERIOD (62500) // Assumes 62.5kHz clock with divider of 1 // Local function definitions void main_buttonInterruptHandler(void); void main_oneMinuteInterruptHandler(void); void main_oneSecondInterruptHandler(void); void main_quarterSecondInterruptHandler(void); int main(void) { Timer_A_UpModeConfig TimerConfig; WDT_A_holdTimer(); // Configure SMCLK CS_setDCOFrequency(8000000); // Set DCO clock frequency to 8MHz CS_initClockSignal(CS_SMCLK, CS_DCOCLK_SELECT, CS_CLOCK_DIVIDER_128); // Set SMCLK to DCO/128 (62.5kHz) // Initialize timers and timer interrupts TimerConfig.captureCompareInterruptEnable_CCR0_CCIE = TIMER_A_CCIE_CCR0_INTERRUPT_DISABLE; TimerConfig.clockSource = main_TIMER_ONEMIN_CLOCK; TimerConfig.clockSourceDivider = main_TIMER_ONEMIN_CLOCKDIVIDER; TimerConfig.timerClear = TIMER_A_DO_CLEAR; TimerConfig.timerInterruptEnable_TAIE = TIMER_A_TAIE_INTERRUPT_DISABLE; TimerConfig.timerPeriod = main_TIMER_ONEMIN_PERIOD; Timer_A_configureUpMode(main_TIMER_ONEMIN_MODULE, &TimerConfig); TimerConfig.clockSourceDivider = main_TIMER_QUARTERSEC_CLOCKDIVIDER; TimerConfig.timerPeriod = main_TIMER_QUARTERSEC_PERIOD; Timer_A_configureUpMode(main_TIMER_QUARTERSEC_MODULE, &TimerConfig); TimerConfig.timerPeriod = main_TIMER_ONESEC_PERIOD; Timer_A_configureUpMode(main_TIMER_ONESEC_MODULE, &TimerConfig); Timer_A_registerInterrupt(main_TIMER_ONEMIN_MODULE, TIMER_A_CCR0_INTERRUPT, main_oneMinuteInterruptHandler); Timer_A_registerInterrupt(main_TIMER_ONESEC_MODULE, TIMER_A_CCR0_INTERRUPT, main_oneSecondInterruptHandler); Timer_A_registerInterrupt(main_TIMER_QUARTERSEC_MODULE, TIMER_A_CCR0_INTERRUPT, main_quarterSecondInterruptHandler); Timer_A_enableInterrupt(main_TIMER_ONEMIN_MODULE); Timer_A_enableInterrupt(main_TIMER_ONESEC_MODULE); Timer_A_enableInterrupt(main_TIMER_QUARTERSEC_MODULE); // Initialize LEDs GPIO_setAsOutputPin(main_GREEN_PORT, main_GREEN_PIN); GPIO_setAsOutputPin(main_RED_PORT, main_RED_PIN); GPIO_setOutputLowOnPin(main_GREEN_PORT, main_GREEN_PIN); GPIO_setOutputLowOnPin(main_RED_PORT, main_RED_PIN); // Initialize GPIO and interrupt for button GPIO_setAsInputPinWithPullUpResistor(main_BUTTON_PORT, main_BUTTON_PIN); GPIO_interruptEdgeSelect(main_BUTTON_PORT, main_BUTTON_PIN, GPIO_HIGH_TO_LOW_TRANSITION); GPIO_registerInterrupt(main_BUTTON_PORT, main_buttonInterruptHandler); GPIO_enableInterrupt(main_BUTTON_PORT, main_BUTTON_PIN); while(1); } void main_buttonInterruptHandler(void) { if( GPIO_getInterruptStatus(main_BUTTON_PORT, main_BUTTON_PIN) ) { GPIO_clearInterruptFlag(main_BUTTON_PORT, main_BUTTON_PIN); GPIO_toggleOutputOnPin(main_GREEN_PORT, main_GREEN_PIN); GPIO_toggleOutputOnPin(main_RED_PORT, main_RED_PIN); } } void main_oneMinuteInterruptHandler(void) { GPIO_toggleOutputOnPin(main_GREEN_PORT, main_GREEN_PIN); } void main_oneSecondInterruptHandler(void) { GPIO_toggleOutputOnPin(main_GREEN_PORT, main_GREEN_PIN); } void main_quarterSecondInterruptHandler(void) { GPIO_toggleOutputOnPin(main_GREEN_PORT, main_GREEN_PIN); }
