I am facing some problem with SD24 ADC configuration. I was expected intrrupt at 200uS but it is going in ISR at 220uS. Here is my code
#include <msp430.h> int main(void) { WDTCTL = WDTPW | WDTHOLD; // Stop watchdog timer P1DIR |= BIT0; /***** Unified Clock system ****/ UCS_config(); SD24_B_config(); __delay_cycles(0x3600); // Delay for 1.5V REF startup SD24BCTL1 |= SD24GRP0SC; // Set bit to start conversion __bis_SR_register( GIE); // Enter interrupt } void UCS_config(void) { PMMCTL0_H = 0xA5; PMMCTL0_L = 0x03; UCSCTL0 = UCSCTL0 | 0x1F00; UCSCTL1 = UCSCTL1 & 0x0000; UCSCTL1 = UCSCTL1 | 0x0040; UCSCTL2 = UCSCTL2 & 0x0000 ; // FLL Divider UCSCTL2 = UCSCTL2 | 0x304F ; // for 20 MHz MCLK and 2.6 MHz SMCLK UCSCTL3 = 0x0000; UCSCTL4 = UCSCTL4 & 0X0000; UCSCTL4 = UCSCTL4 | 0X0043; } void SD24_B_config(void) { SD24BCTL0 = SD24REFS | SD24SSEL_1; // Select internal REF // Select SMCLK as SD24_B clock source SD24BOSR0 = 0X0208; //C7 for 5K samplin; OSR = 520 SD24BOSR1 = 0X0208; //C7 for 5K samplin; OSR = 520 SD24BOSR2 = 0X0208; //C7 for 5K samplin; OSR = 520 SD24BOSR3 = 0X0208; //C7 for 5K samplin; OSR = 520 SD24BOSR4 = 0X0208; //C7 for 5K samplin; OSR = 520 SD24BOSR5 = 0X0208; //C7 for 5K samplin; OSR = 520 SD24BOSR6 = 0X0208; //C7 for 5K samplin; OSR = 520 SD24BCCTL0 = SD24ALGN | SD24SCS_4; // Left-aligned, group 0 SD24BCCTL1 = SD24ALGN | SD24SCS_4; // Left-aligned, group 0 SD24BCCTL2 = SD24ALGN | SD24SCS_4; // Left-aligned, group 0 SD24BCCTL3 = SD24ALGN | SD24SCS_4; // Left-aligned, group 0 SD24BCCTL4 = SD24ALGN | SD24SCS_4; // Left-aligned, group 0 SD24BCCTL5 = SD24ALGN | SD24SCS_4; // Left-aligned, group 0 SD24BCCTL6 = SD24ALGN | SD24SCS_4; // Left-aligned, group 0 SD24BIE = SD24IE5; } __interrupt void SD24BISR(void) { // Every 200 uSeconds P1OUT ^= 0x0001; if(SD24BIV == SD24BIV_SD24IFG5) { // P1OUT = 0x0001; Ch0results = SD24BMEMH0 - Ch0_Offset; // Save CH0 higher results (clears IFG) Ch4results = SD24BMEMH4 - Ch4_Offset; // Save CH4 higher results (clears IFG) Ch1results = SD24BMEMH1 - Ch1_Offset; // Save CH1 higher results (clears IFG) Ch5results = SD24BMEMH5 - Ch5_Offset; // Save CH5 higher results (clears IFG) Ch2results = SD24BMEMH2 - Ch2_Offset; // Save CH2 higher results (clears IFG) Ch6results = SD24BMEMH6 - Ch6_Offset; // Save CH6 higher results (clears IFG) Ch3results = SD24BMEMH3 - Ch3_Offset; // Save CH3 higher results (clears IFG) } }
I have given output P1.0 to Digital Oscilloscope but it is showing toggling of bit at every 440uS. Which means I am going in my ISR at 220uS. Please let me know where I am making mistake.
Thanks in Advance
Abhishek
