I am trying to use an EXP432P401R Launchpad to measure the current consumption of a custom MSP430F5528 board. I do not necessarily need to be debugging the MSP430 while measuring current, so I believe using the EXP432 launchpad in standalone EnergyTrace mode should be OK.
However, when I press the EnergyTrace button in the CCS Edit view the button remains pressed for ~10 seconds but nothing happens. Looking at the CCS log file I see the following exception:
!ENTRY org.eclipse.ui 4 0 2016-06-29 20:07:18.604 !MESSAGE Unhandled event loop exception !STACK 0 java.lang.IllegalArgumentException: No enum constant com.ti.dvt.energytrace.core.RuntimeParameter.EnumTargetDevice.RF432 at java.lang.Enum.valueOf(Enum.java:236) at com.ti.dvt.energytrace.core.RuntimeParameter$EnumTargetDevice.valueOf(RuntimeParameter.java:1) at com.ti.dvt.energytrace.af.PowerActivity$DebuggerTargetInfo.fromCCXML(PowerActivity.java:1198) at com.ti.dvt.energytrace.af.PowerActivity$DebuggerTargetInfo.<init>(PowerActivity.java:1166) at com.ti.dvt.energytrace.af.PowerActivity.launchHiddenDS(PowerActivity.java:1317) at com.ti.dvt.energytrace.IDEHandler.detectCfg(IDEHandler.java:290) at com.ti.dvt.energytrace.IDEHandler.launchHiddenDS(IDEHandler.java:376) at com.ti.dvt.energytrace.IDEHandler.preNonDebugStartup(IDEHandler.java:220) at com.ti.dvt.energytrace.IDEHandler.startupDashboard(IDEHandler.java:438) at com.ti.dvt.energytrace.actions.DashboardAction.runET(DashboardAction.java:102) at com.ti.dvt.energytrace.actions.DashboardAction.run(DashboardAction.java:55) at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:247) at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:228) at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:595) at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:511) at org.eclipse.jface.action.ActionContributionItem$6.handleEvent(ActionContributionItem.java:462) at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84) at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113) at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018) at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156) at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608) at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
Also when I go to the EnergyTrace settings in CCS Preferences and press Apply/OK I get the following:
!ENTRY org.eclipse.jface 4 0 2016-06-29 19:59:07.603 !MESSAGE java.lang.NumberFormatException: empty String !STACK 0 java.lang.NumberFormatException: empty String at sun.misc.FloatingDecimal.readJavaFormatString(FloatingDecimal.java:1020) at java.lang.Double.valueOf(Double.java:504) at java.lang.Double.<init>(Double.java:597) at com.ti.dvt.energytrace.PreferencePage$DoubleFieldEditor.doStore(PreferencePage.java:223) at org.eclipse.jface.preference.FieldEditor.store(FieldEditor.java:683) at org.eclipse.jface.preference.FieldEditorPreferencePage.performOk(FieldEditorPreferencePage.java:344) at org.eclipse.jface.preference.PreferenceDialog$12.run(PreferenceDialog.java:925) at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42) at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50) at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:173) at org.eclipse.jface.preference.PreferenceDialog.okPressed(PreferenceDialog.java:909) at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.okPressed(FilteredPreferenceDialog.java:409) at org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDialog.okPressed(WorkbenchPreferenceDialog.java:168) at org.eclipse.jface.preference.PreferenceDialog.buttonPressed(PreferenceDialog.java:233) at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:619) at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248) at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84) at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113) at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769) at org.eclipse.jface.window.Window.runEventLoop(Window.java:827) at org.eclipse.jface.window.Window.open(Window.java:803) at org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDialog.open(WorkbenchPreferenceDialog.java:211) at org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPreferencesAction.java:63) at org.eclipse.jface.action.Action.runWithEvent(Action.java:473) at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:595) at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:511) at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:420) at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84) at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362) at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113) at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018) at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156) at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:606) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608) at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
The only way to get the EnergyTrace window to even appear is to press the EnergyTrace button in while debugging a project, but even then pressing the start button has no effect, i.e. the button flashes to red for a sec then returns to green, time remains at 0sec and no data are plotted in the Energy or Power graphs.
I am using CCS 6.1.3 and have tested with the EXP432 both connected and not connected to USB and the target connection in EnergyTrace settings set to XDS110 and USB.
Shouldn't I be able to use the EXP432 in standalone EnergyTrace mode? Is there some other setting that I am missing?
