I am trying to upgrade the firmware using MSP430F5247.
I have seached and through many e2e.ti forums and posts and have developed the custom bootloader and a test application.
Initially for this I am blinking different LED to verify the jumping from bootloader to test application.
I have followed this approach, I am attaching my linker files for bootloader and test application
/* ============================================================================ */ /* Copyright (c) 2014, Texas Instruments Incorporated */ /* All rights reserved. */ /* */ /* Redistribution and use in source and binary forms, with or without */ /* modification, are permitted provided that the following conditions */ /* are met: */ /* */ /* * Redistributions of source code must retain the above copyright */ /* notice, this list of conditions and the following disclaimer. */ /* */ /* * Redistributions in binary form must reproduce the above copyright */ /* notice, this list of conditions and the following disclaimer in the */ /* documentation and/or other materials provided with the distribution. */ /* */ /* * Neither the name of Texas Instruments Incorporated nor the names of */ /* its contributors may be used to endorse or promote products derived */ /* from this software without specific prior written permission. */ /* */ /* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" */ /* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, */ /* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR */ /* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR */ /* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, */ /* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, */ /* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; */ /* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, */ /* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR */ /* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */ /* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* ============================================================================ */ /******************************************************************************/ /* lnk_msp430f5247.cmd - LINKER COMMAND FILE FOR LINKING MSP430F5247 PROGRAMS */ /* */ /* Usage: lnk430 <obj files...> -o <out file> -m <map file> lnk.cmd */ /* cl430 <src files...> -z -o <out file> -m <map file> lnk.cmd */ /* */ /*----------------------------------------------------------------------------*/ /* These linker options are for command line linking only. For IDE linking, */ /* you should set your linker options in Project Properties */ /* -c LINK USING C CONVENTIONS */ /* -stack 0x0100 SOFTWARE STACK SIZE */ /* -heap 0x0100 HEAP AREA SIZE */ /* */ /*----------------------------------------------------------------------------*/ /* Version: 1.159 */ /*----------------------------------------------------------------------------*/ /****************************************************************************/ /* Specify the system memory map */ /****************************************************************************/ __Flash_Start = 0x4400; /* Start of Flash */ __Flash_End = 0x143FF; /* End of Flash */ __Boot_Start = 0xDF80; /* Boot flash */ __Boot_Reset = 0xFFFE; /* Boot reset vector */ _App_Proxy_Vector_Start = 0xDDFE; __Boot_VectorTable = 0xFF80; /* Boot vector table */ // _App_Start = (__Flash_Start+3); /* Application Area */ // _App_End = (__Boot_Start-1); /* End of application area (before boot) */ _App_Reset_Vector = 0xFF7E; MEMORY { SFR : origin = 0x0000, length = 0x0010 PERIPHERALS_8BIT : origin = 0x0010, length = 0x00F0 PERIPHERALS_16BIT : origin = 0x0100, length = 0x0100 RAM : origin = 0x2400, length = 0x2000 INFOA : origin = 0x1980, length = 0x0080 INFOB : origin = 0x1900, length = 0x0080 INFOC : origin = 0x1880, length = 0x0080 INFOD : origin = 0x1800, length = 0x0080 //FLASH : origin = 0x4400, length = 0xBB80 FLASH : origin = 0x4400, length = 0x99FE FLASH2 : origin = 0x10000,length = 0x4400 APP_PROXY_VECTORS : origin = 0xDDFE, length = 0x17E /*INT00 : origin = 0xFF80, length = 0x0002 INT01 : origin = 0xFF82, length = 0x0002 INT02 : origin = 0xFF84, length = 0x0002 INT03 : origin = 0xFF86, length = 0x0002 INT04 : origin = 0xFF88, length = 0x0002 INT05 : origin = 0xFF8A, length = 0x0002 INT06 : origin = 0xFF8C, length = 0x0002 INT07 : origin = 0xFF8E, length = 0x0002 INT08 : origin = 0xFF90, length = 0x0002 INT09 : origin = 0xFF92, length = 0x0002 INT10 : origin = 0xFF94, length = 0x0002 INT11 : origin = 0xFF96, length = 0x0002 INT12 : origin = 0xFF98, length = 0x0002 INT13 : origin = 0xFF9A, length = 0x0002 INT14 : origin = 0xFF9C, length = 0x0002 INT15 : origin = 0xFF9E, length = 0x0002 INT16 : origin = 0xFFA0, length = 0x0002 INT17 : origin = 0xFFA2, length = 0x0002 INT18 : origin = 0xFFA4, length = 0x0002 INT19 : origin = 0xFFA6, length = 0x0002 INT20 : origin = 0xFFA8, length = 0x0002 INT21 : origin = 0xFFAA, length = 0x0002 INT22 : origin = 0xFFAC, length = 0x0002 INT23 : origin = 0xFFAE, length = 0x0002 INT24 : origin = 0xFFB0, length = 0x0002 INT25 : origin = 0xFFB2, length = 0x0002 INT26 : origin = 0xFFB4, length = 0x0002 INT27 : origin = 0xFFB6, length = 0x0002 INT28 : origin = 0xFFB8, length = 0x0002 INT29 : origin = 0xFFBA, length = 0x0002 INT30 : origin = 0xFFBC, length = 0x0002 INT31 : origin = 0xFFBE, length = 0x0002 INT32 : origin = 0xFFC0, length = 0x0002 INT33 : origin = 0xFFC2, length = 0x0002 INT34 : origin = 0xFFC4, length = 0x0002 INT35 : origin = 0xFFC6, length = 0x0002 INT36 : origin = 0xFFC8, length = 0x0002 INT37 : origin = 0xFFCA, length = 0x0002 INT38 : origin = 0xFFCC, length = 0x0002 INT39 : origin = 0xFFCE, length = 0x0002 INT40 : origin = 0xFFD0, length = 0x0002 INT41 : origin = 0xFFD2, length = 0x0002 INT42 : origin = 0xFFD4, length = 0x0002 INT43 : origin = 0xFFD6, length = 0x0002 INT44 : origin = 0xFFD8, length = 0x0002 INT45 : origin = 0xFFDA, length = 0x0002 INT46 : origin = 0xFFDC, length = 0x0002 INT47 : origin = 0xFFDE, length = 0x0002 INT48 : origin = 0xFFE0, length = 0x0002 INT49 : origin = 0xFFE2, length = 0x0002 INT50 : origin = 0xFFE4, length = 0x0002 INT51 : origin = 0xFFE6, length = 0x0002 INT52 : origin = 0xFFE8, length = 0x0002 INT53 : origin = 0xFFEA, length = 0x0002 INT54 : origin = 0xFFEC, length = 0x0002 INT55 : origin = 0xFFEE, length = 0x0002 INT56 : origin = 0xFFF0, length = 0x0002 INT57 : origin = 0xFFF2, length = 0x0002 INT58 : origin = 0xFFF4, length = 0x0002 INT59 : origin = 0xFFF6, length = 0x0002 INT60 : origin = 0xFFF8, length = 0x0002 INT61 : origin = 0xFFFA, length = 0x0002 INT62 : origin = 0xFFFC, length = 0x0002*/ RESET : origin = 0xDF7C, length = 0x0004 } /****************************************************************************/ /* Specify the sections allocation into memory */ /****************************************************************************/ SECTIONS { .bss : {} > RAM /* Global & static vars */ .data : {} > RAM /* Global & static vars */ .TI.noinit : {} > RAM /* For #pragma noinit */ .sysmem : {} > RAM /* Dynamic memory allocation area */ .stack : {} > RAM (HIGH) /* Software system stack */ #ifndef __LARGE_DATA_MODEL__ .text : {}>> FLASH /* Code */ #else .text : {}>> FLASH2 | FLASH /* Code */ #endif .text:_isr : {} > FLASH /* ISR Code space */ .cinit : {} > FLASH /* Initialization tables */ #ifndef __LARGE_DATA_MODEL__ .const : {} > FLASH /* Constant data */ #else .const : {} > FLASH | FLASH2 /* Constant data */ #endif .cio : {} > RAM /* C I/O Buffer */ .pinit : {} > FLASH /* C++ Constructor tables */ .init_array : {} > FLASH /* C++ Constructor tables */ .mspabi.exidx : {} > FLASH /* C++ Constructor tables */ .mspabi.extab : {} > FLASH /* C++ Constructor tables */ .infoA : {} > INFOA /* MSP430 INFO FLASH Memory segments */ .infoB : {} > INFOB .infoC : {} > INFOC .infoD : {} > INFOD .APP_PROXY_VECTORS : {} > APP_PROXY_VECTORS /* INTERRUPT PROXY TABLE */ /* MSP430 Interrupt vectors .int00 : {} > INT00 .int01 : {} > INT01 .int02 : {} > INT02 .int03 : {} > INT03 .int04 : {} > INT04 .int05 : {} > INT05 .int06 : {} > INT06 .int07 : {} > INT07 .int08 : {} > INT08 .int09 : {} > INT09 .int10 : {} > INT10 .int11 : {} > INT11 .int12 : {} > INT12 .int13 : {} > INT13 .int14 : {} > INT14 .int15 : {} > INT15 .int16 : {} > INT16 .int17 : {} > INT17 .int18 : {} > INT18 .int19 : {} > INT19 .int20 : {} > INT20 .int21 : {} > INT21 .int22 : {} > INT22 .int23 : {} > INT23 .int24 : {} > INT24 .int25 : {} > INT25 .int26 : {} > INT26 .int27 : {} > INT27 .int28 : {} > INT28 .int29 : {} > INT29 .int30 : {} > INT30 .int31 : {} > INT31 .int32 : {} > INT32 .int33 : {} > INT33 .int34 : {} > INT34 .int35 : {} > INT35 .int36 : {} > INT36 .int37 : {} > INT37 .int38 : {} > INT38 .int39 : {} > INT39 .int40 : {} > INT40 RTC : { * ( .int41 ) } > INT41 type = VECT_INIT PORT2 : { * ( .int42 ) } > INT42 type = VECT_INIT TIMER2_A1 : { * ( .int43 ) } > INT43 type = VECT_INIT TIMER2_A0 : { * ( .int44 ) } > INT44 type = VECT_INIT USCI_B1 : { * ( .int45 ) } > INT45 type = VECT_INIT USCI_A1 : { * ( .int46 ) } > INT46 type = VECT_INIT PORT1 : { * ( .int47 ) } > INT47 type = VECT_INIT TIMER1_A1 : { * ( .int48 ) } > INT48 type = VECT_INIT TIMER1_A0 : { * ( .int49 ) } > INT49 type = VECT_INIT DMA : { * ( .int50 ) } > INT50 type = VECT_INIT .int51 : {} > INT51 TIMER0_A1 : { * ( .int52 ) } > INT52 type = VECT_INIT TIMER0_A0 : { * ( .int53 ) } > INT53 type = VECT_INIT ADC10 : { * ( .int54 ) } > INT54 type = VECT_INIT USCI_B0 : { * ( .int55 ) } > INT55 type = VECT_INIT USCI_A0 : { * ( .int56 ) } > INT56 type = VECT_INIT WDT : { * ( .int57 ) } > INT57 type = VECT_INIT TIMER0_B1 : { * ( .int58 ) } > INT58 type = VECT_INIT TIMER0_B0 : { * ( .int59 ) } > INT59 type = VECT_INIT COMP_B : { * ( .int60 ) } > INT60 type = VECT_INIT UNMI : { * ( .int61 ) } > INT61 type = VECT_INIT SYSNMI : { * ( .int62 ) } > INT62 type = VECT_INIT*/ .reset : {} > RESET /* MSP430 Reset vector */ } /****************************************************************************/ /* Include peripherals memory map */ /****************************************************************************/ -l msp430f5247.cmd
