Hi, sir
I have transplanted UCOS II systerm to MSP430F5659 for developing multiple application funtions. However, I found the program operate abnomally after I added some appilcation codes. I guessed that the reason is stack overflow. So, I check Enable stack usage analysis check box in the Options of IAR compiler to gernerate a map file about stack. The map file is following
**************************************** * * * STACK USAGE * * * **************************************** Call Graph Root Category Max Use Total Use ------------------------ ------- --------- interrupt 56 204 Program entry 528 528 Uncalled function 1 404 6 214 Program entry "__program_start": 0x00008000 Maximum call chain *?* 528 bytes (** call graph contains indirect calls (example: "_LocaleEncoding") functions with no stack usage info (example: "OS_CPU_SR_Save") **) "__program_start" 0 "main" 4 "Init_App" 6 "msgInit" 32 "logSysMsgWithTime" 52 "DBWriteSysInfoNoInfoType" 152 "DBWrite" 20 "writeSoe" 32 "DBCWriteData" 38 "ReadData" 32 "FlashRead" 30 "df_read" 28 "read_buffer" 24 "dataflash_wait_busy" 12 "dataflash_read_status" 6 "FlashSPIRead" 20 "F5659SpiSend8" 36 "F5659SpiWaiteIdle" 4 interrupt "ADC12_ISR": 0x00008044 Maximum call chain 32 bytes "ADC12_ISR" 20 "memcpy" 12 interrupt "Port3_ISR": 0x000081e8 Maximum call chain 8 bytes "Port3_ISR" 8 interrupt "USCI_B2_ISR": 0x00008226 Maximum call chain 8 bytes "USCI_B2_ISR" 8 interrupt "USCI_B1_ISR": 0x00008206 Maximum call chain 8 bytes "USCI_B1_ISR" 8 interrupt "PORT1_ISR": 0x00008296 Maximum call chain 56 bytes "PORT1_ISR" 20 "RF_Frame_Receive" 4 "SetRFMode" 8 "SpiWriteCfg" 20 "SPI_Send_Byte" 4 interrupt "TIMER2_A1_ISR": 0x00008360 Maximum call chain 8 bytes "TIMER2_A1_ISR" 8 interrupt "TIMER1_A1_ISR": 0x00008344 Maximum call chain 8 bytes "TIMER1_A1_ISR" 8 interrupt "TIMER0_A1_ISR": 0x00008328 Maximum call chain 8 bytes "TIMER0_A1_ISR" 8 interrupt "TIMER2_A0_ISR": 0x000082ce Maximum call chain 4 bytes "TIMER2_A0_ISR" 4 interrupt "TIMER1_A0_ISR": 0x000082c2 Maximum call chain 24 bytes "TIMER1_A0_ISR" 20 "RunSoftTime" 4 interrupt "TIMER0_A0_ISR": 0x000082c0 Maximum call chain 4 bytes "TIMER0_A0_ISR" 4 interrupt "USCI_A2_ISR": 0x0000845c Maximum call chain 12 bytes "USCI_A2_ISR" 12 interrupt "USCI_A1_ISR": 0x000083ec Maximum call chain 12 bytes "USCI_A1_ISR" 12 interrupt "USCI_A0_ISR": 0x0000837c Maximum call chain 12 bytes "USCI_A0_ISR" 12 Uncalled function "StartupTask": 0x000265bc Maximum call chain *?* 180 bytes (** call graph contains functions with no stack usage info (example: "OS_CPU_SR_Save") **) "StartupTask" 72 "OSTaskCreateExt" 58 "OS_TCBInit" 46 "?OneBitMask32" 4 Uncalled function "OS_TaskStat": 0x0002510a Maximum call chain *?* 94 bytes (** call graph contains functions with no stack usage info (example: "OS_CPU_SR_Save") **) "OS_TaskStat" 20 "OS_TaskStatStkChk" 36 "OSTaskStkChk" 38 "OS_CPU_SR_Save" - no info - Uncalled function "OS_TaskIdle": 0x0002ff74 Maximum call chain *?* 16 bytes (** call graph contains functions with no stack usage info (example: "OS_CPU_SR_Save") **) "OS_TaskIdle" 12 "OSTaskIdleHook" 4 Uncalled function "OSTimeTick": 0x00026c02 Maximum call chain *?* 108 bytes (** call graph contains functions with no stack usage info (example: "OS_CPU_SR_Save") **) "OSTimeTick" 20 "OSTimeTickHook" 4 "OSTmrSignal" 8 "OSSemPost" 20 "OS_EventTaskRdy" 36 "OS_EventTaskRemoveMulti" 20 Uncalled function "OSIntExit": 0x0002cb20 Maximum call chain *?* 12 bytes (** call graph contains functions with no stack usage info (example: "OS_CPU_SR_Save") **) "OSIntExit" 8 "OS_SchedNew" 4 Uncalled function "OSTaskSwHook": 0x00030800 Maximum call chain 4 bytes "OSTaskSwHook" 4 Uncalled function "OSTmr_Task": 0x0002a2ac Maximum call chain *?* 74 bytes (** call graph contains indirect calls (example: "OSTmr_Task") functions with no stack usage info (example: "OS_CPU_SR_Save") **) "OSTmr_Task" 30 "OSTmr_Unlink" 28 "?DivMod32u" 16 Uncalled function "Time1sCall": 0x0002c5e6 Maximum call chain *?* 112 bytes (** call graph contains functions with no stack usage info (example: "OS_CPU_SR_Save") **) "Time1sCall" 30 "OSFlagPost" 46 "OS_FlagTaskRdy" 28 "OS_FlagUnlink" 8 Uncalled function "time100mscall": 0x0002c446 Maximum call chain *?* 112 bytes (** call graph contains functions with no stack usage info (example: "OS_CPU_SR_Save") **) "time100mscall" 30 "OSFlagPost" 46 "OS_FlagTaskRdy" 28 "OS_FlagUnlink" 8 Uncalled function "Time10msCall": 0x0002c516 Maximum call chain *?* 112 bytes (** call graph contains functions with no stack usage info (example: "OS_CPU_SR_Save") **) "Time10msCall" 30 "OSFlagPost" 46 "OS_FlagTaskRdy" 28 "OS_FlagUnlink" 8 Uncalled function "Com2task": 0x00030682 Maximum call chain *?* 1 404 bytes (** call graph contains recursive functions (example: "CSecAppSev::ProcControl()") indirect calls (example: "_LocaleEncoding") functions with no stack usage info (example: "OS_CPU_SR_Save") **) "Com2task" 8 "ComApp" 12 "DFE_WHTask" 22 "DFEWHPriOnRx" 12 "DFEWHSearchComFrame" 20 "DFEWHAppLayerPro" 12 "ProcCallAllData" 12 "ProcSystemInfo" 134 "ReadSysInfoFrmFlash" 36 "ProcSysInfoToFlash" 20 "WriteSysInfoToFlash" 780 "sprintf" 16 "_PrintfLarge" 148 "_PutstrLarge" 116 "__data20_malloc" 20 "__data20_findmem" 12 "__data20_free" 24 Uncalled function "Periodtask": 0x00028434 Maximum call chain *?* 1 178 bytes (** call graph contains indirect calls (example: "_LocaleEncoding") functions with no stack usage info (example: "OS_CPU_SR_Save") **) "Periodtask" 22 "WriteSysInfoToFlashPeriod" 20 "ProcSysInfoToFlash" 20 "WriteSysInfoToFlash" 780 "sprintf" 16 "_PrintfLarge" 148 "_PutstrLarge" 116 "__data20_malloc" 20 "__data20_findmem" 12 "__data20_free" 24 The following functions make up recursion nest 0, which has no maximum recursion depth specified: "CPriDLink::CallAppProc()": 0x00029794 "CPriDLink::DLSendProc(INT16U)": 0x0001c548 The following functions make up recursion nest 1, which has no maximum recursion depth specified: "CSecAppSev::ProcControl()": 0x0000d6f6 "CSecAppSev::SecAppProc(unsigned char *, INT16U, INT16U, unsigned char *, INT16U *, INT16U *)": 0x0000e622 "CSecDLink::CallUData()": 0x0002c308 The following functions appear to be called, but have no stack usage information: "OSCtxSw": 0x0002a48a "OSIntCtxSw": 0x0002a4ce "OSStartHighRdy": 0x0002a46e "OS_CPU_SR_Restore": 0x0002a466 "OS_CPU_SR_Save": 0x0002a45e The following functions perform unknown indirect calls: "OSTmr_Task": 0x0002a2ac "_LocaleEncoding": 0x000306de "localeconv": 0x000304d0 "operator new(unsigned long)": 0x0002fbf4
The question is how I could calculate the size of stack that I need to set by the map file ?
Another question is that the IAR compiler showed 3 warnings when I execute compilation(Enable stack usage analysis check box selected).
How could I eliminate the warnings?
Best regards
Jent
