I have 64 integer number and I need its square root as 32 bit integer only. Fractionals are not required. The library provided by TI for energy metering consumes 25000 cycles, I didnt understant what is the benefit of it. If I use double float and standart libraries instead of provided one, it is only 6000 cycles. This process should be maximum 1000 cycles. Is there any application note or ready code for this?
10x.
