MSP430F2617: MSP430F2617 verification error while flashing
Part Number: MSP430F2617
Other Parts Discussed in Thread: MSP430F2618, MSP430-FLASHER, UNIFLASH, MSP-GANG, MSP-FET, MSP-TS430PM64
Hello!
One  of the clients has a problem, related to MSP430F2617  verification.  He says " While we flashing MSP430F2617  controllers using of MSP430 Flasher, they are defined as MSP430F2618.
When we using this program we get error 60 in 30% of devices. See attached log."   Can you help me?
log.txt
Fri Nov 10 10:22:26 2017:	* -----/|-------------------------------------------------------------------- *
Fri Nov 10 10:22:26 2017:	*     / |__        *
Fri Nov 10 10:22:26 2017:	*    /_   /   MSP430 Flasher v1.3.7                                           *
Fri Nov 10 10:22:26 2017:	*      | /        *
Fri Nov 10 10:22:26 2017:	* -----|/-------------------------------------------------------------------- *
Fri Nov 10 10:22:26 2017:	* Evaluating triggers...done
Fri Nov 10 10:22:26 2017:	* Checking for available FET debuggers:
Fri Nov 10 10:22:26 2017:	* Found USB FET @ COM3 <- Selected
Fri Nov 10 10:22:26 2017:	* Initializing interface @ COM3...done
Fri Nov 10 10:22:26 2017:	* Checking firmware compatibility:
Fri Nov 10 10:22:26 2017:	* FET firmware is up to date.
Fri Nov 10 10:22:26 2017:	* Reading FW version...done
Fri Nov 10 10:22:26 2017:	* Setting VCC to 3000 mV...done
Fri Nov 10 10:22:27 2017:	* Accessing device...done
Fri Nov 10 10:22:28 2017:	* Reading device information...done
Fri Nov 10 10:22:28 2017:	* ----------------------------------------------------------------------------
Fri Nov 10 10:22:28 2017:	* Arguments   :
Fri Nov 10 10:22:28 2017:	* Driver      : loaded
Fri Nov 10 10:22:28 2017:	* Dll Version : 30202000
Fri Nov 10 10:22:28 2017:	* FwVersion   : 30202000
Fri Nov 10 10:22:28 2017:	* Interface   : TIUSB
Fri Nov 10 10:22:28 2017:	* HwVersion   : U 1.64
Fri Nov 10 10:22:28 2017:	* JTAG Mode   : AUTO
Fri Nov 10 10:22:28 2017:	* Device      : MSP430F2618
Fri Nov 10 10:22:28 2017:	* EEM         : Level 3, ClockCntrl 2
Fri Nov 10 10:22:28 2017:	* VCC OFF
Fri Nov 10 10:22:28 2017:	* Powering down...done
Fri Nov 10 10:22:28 2017:	* Disconnecting from device...done
Fri Nov 10 10:22:28 2017:	* Driver      : closed (No error)
Fri Nov 10 10:22:28 2017:	*/
Fri Nov 10 10:22:32 2017:	* -----/|-------------------------------------------------------------------- *
Fri Nov 10 10:22:32 2017:	*     / |__        *
Fri Nov 10 10:22:32 2017:	*    /_   /   MSP430 Flasher v1.3.7                                           *
Fri Nov 10 10:22:32 2017:	*      | /        *
Fri Nov 10 10:22:32 2017:	* -----|/-------------------------------------------------------------------- *
Fri Nov 10 10:22:32 2017:	* Evaluating triggers...done
Fri Nov 10 10:22:32 2017:	* Checking for available FET debuggers:
Fri Nov 10 10:22:33 2017:	* Found USB FET @ COM3 <- Selected
Fri Nov 10 10:22:33 2017:	* Initializing interface @ COM3...done
Fri Nov 10 10:22:33 2017:	* Checking firmware compatibility:
Fri Nov 10 10:22:33 2017:	* FET firmware is up to date.
Fri Nov 10 10:22:33 2017:	* Reading FW version...done
Fri Nov 10 10:22:33 2017:	* Setting VCC to 3000 mV...done
Fri Nov 10 10:22:34 2017:	* Accessing device...done
Fri Nov 10 10:22:34 2017:	* Reading device information...done
Fri Nov 10 10:22:34 2017:	* Unlocking BSL memory...done
Fri Nov 10 10:22:34 2017:	* Unlocking Info Memory A...done
Fri Nov 10 10:22:34 2017:	* Loading file into device...done
Fri Nov 10 10:22:43 2017:	* Verifying memory (C:\Users\���1\AppData\Local\Temp\PULSAR_04_M3_V115.hex)...
Fri Nov 10 10:22:44 2017:	# Exit: 60
Fri Nov 10 10:22:44 2017:	# ERROR: Verification error
Fri Nov 10 10:22:44 2017:	* Resetting device (RST/NMI)...done
Fri Nov 10 10:22:44 2017:	* Starting target code execution...done
Fri Nov 10 10:22:44 2017:	* Disconnecting from device...done
Fri Nov 10 10:22:44 2017:	* ----------------------------------------------------------------------------
Fri Nov 10 10:22:44 2017:	* Driver      : closed (No error)
Fri Nov 10 10:22:44 2017:	*/
