HI,
using CPU to update the G2553 program success by BSL, but information memory maybe erased or changed. I haven't found the reason, can you give some advise.
I tried three ways:
1.mass erase->send right password->send bin file data
2.send right password->Erase segment->send bin file data
2. send wrong password->send right password->send bin file data
thank!
#include <sys/stat.h> #include <unistd.h> #include <sys/mman.h> #include <time.h> #include <stdio.h> #include <stdlib.h> #include <fcntl.h> #include <termios.h> #include <errno.h> #include <string.h> typedef unsigned char u8; typedef unsigned short u16; #define MCU_ACK 0xFA #define MCU_TEST 0xFB #define MCU_START 0xFD #define MCU_END 0xFE #define MCU_TIMEOUT (-1) #define MCU_DATA_IDX 3 #define DATA_CMD_LEN 1 #define DATA_PORT_LEN 1 #define DATA_VOLTAGE_LEN 2 #define DATA_CURRENT_LEN 2 #define DATA_VERSION_LEN 2 #define MSG_MAX_LEN 64 #define MSG_HEADER_LEN (1 + DATA_CMD_LEN + DATA_PORT_LEN) #define MSG_END_LEN (1) #define MSG_LEN_GET_VC (MSG_HEADER_LEN + DATA_VOLTAGE_LEN + DATA_CURRENT_LEN + MSG_END_LEN) #define MSG_LEN_GET_VERSION (MSG_HEADER_LEN + DATA_VERSION_LEN + MSG_END_LEN) #define MTK_GPIO_BASE 0x1E000600 #define MTK_GPIO_CTL_OFF 0 #define MTK_GPIO_WIDTH 0x100 #define MTK_GPIO_SET_OFF 0x30 #define MTK_GPIO_CLR_OFF 0x40 #define BSL_EN 16 #define BSL_RST 14 #define BSL_TEST 13 #define BSL_DEALY 60 #define MCU_MAX_BIN (64 * 1024) /* FLASH 16K */ #define UPGRADE_TRUNK 128 #define MCU_UPGRADE_FILE "/tmp/mcu-upgrade.tmp" #define DEV_MCU_PATH "/dev/ttyS0" #define CMD_RX_DATA_BLOCK 0x12 #define CMD_RX_PASSWORD 0x10 #define CMD_PASSWORD_LEN 0x20 #define CMD_ERASE_SEGMENT 0x16 #define CMD_ERASE_MAIN_INFO 0x16 #define CMD_MASS_ERASE 0x18 #define CMD_ERASE_CHECK 0x1C #define CMD_TX_BSL_VER 0x1E #define CMD_MAX_BYTES 0x104 /* �������ȣ�8+250+2 */ #define MCU_FLASH_START 0xC000 /* flash��д����ʼ��ַ */ #define BSL_SYNC 0x80 #define BSL_ACK 0x90 #define BSL_NAK 0xA0 #define BSL_RECEIVE_TIEMS 10 #define CMD_RETRY_TIME 3 enum { MCU_CMD_PORT_CONTROL = 1, //power on/off one port MCU_CMD_SET_SYS_POWER = 2, MCU_CMD_GET_PORT_STATUS = 3, MCU_CMD_GET_VC = 4, MCU_CMD_GET_PD_CLASS = 5, MCU_CMD_GET_ALL = 6, MCU_CMD_GET_VERSION = 7, MCU_CMD_ALLPORTS_CONTROL = 8, //power on/off all ports MCU_CMD_MAX, }; static int mcu_bsl_sync(void) { u8 cmd_buf[1]; int ret, retry_time = 0; int recvtimes, flag; retry_sync: recvtimes = 0; flag = 0; /* send 0x80 */ cmd_buf[0] = BSL_SYNC; mcu_send_msg(cmd_buf, 1); ft_udelay(10 * 1000); printf("%s: send BSL_SYNC\n", __func__); do { ret = mcu_recv_msg(cmd_buf, 1); flag = (recvtimes++ < BSL_RECEIVE_TIEMS) && (ret != 1 || (cmd_buf[0] != BSL_ACK && cmd_buf[0] != BSL_NAK)); if (flag) { ft_udelay(10*1000); } } while (flag); if (ret != 1 || cmd_buf[0] != BSL_ACK) { printf("%s: SYNC fail, ret:%d, cmd_buf[0]:0x%x\n", __func__, ret, cmd_buf[0]); if (retry_time++ < CMD_RETRY_TIME) { goto retry_sync; } return -EIO; } printf("%s: sync success\n", __func__); return 0; } static int mcu_bsl_command(u8 cmd, u8 l1, u8 l2, u8 al, u8 ah, u8 ll, u8 lh, u8 *data, int num, int udelay) { u8 cmd_buf[CMD_MAX_BYTES]; int ret, retry_time = 0; int recvtimes, flag; ret = mcu_bsl_sync(); if (ret) return ret; retry: recvtimes = 0; flag = 0; ret = bsl_cmd(cmd_buf, cmd, l1, l2, al, ah, ll, lh, data, num); mcu_send_msg(cmd_buf, ret); ft_udelay(udelay); do { ret = mcu_recv_msg(cmd_buf, 1); flag = (recvtimes++ < BSL_RECEIVE_TIEMS) && (ret != 1 || (cmd_buf[0] != BSL_ACK && cmd_buf[0] != BSL_NAK)); if (flag) { ft_udelay(10*1000); } } while (flag); if (ret != 1 || cmd_buf[0] != BSL_ACK) { printf("%s: %s fail, ret:%d, cmd_buf[0]:0x%x\n", __func__, bsl_cmd_name(cmd), ret, cmd_buf[0]); if (retry_time++ < CMD_RETRY_TIME) { ft_udelay(300*1000); goto retry; } return -EIO; } printf("%s: %s success\n", __func__, bsl_cmd_name(cmd)); return 0; } int mcu_low_upgrade(u8 *bin, int size) { u8 password[CMD_PASSWORD_LEN], tmp_buf[CMD_MAX_BYTES]; int ret, i; u16 start; printf("%s: size:%d\n", __func__, size); //send wrong password memset(password, 0xff, CMD_PASSWORD_LEN-2); memset(password+CMD_PASSWORD_LEN-2, 0x00, 2); ret = mcu_bsl_command(CMD_RX_PASSWORD, 0x24, 0x24, 0, 0, 0, 0, password, CMD_PASSWORD_LEN, 10*1000); if (ret) return ret; ret = mcu_bsl_command(CMD_MASS_ERASE, 0x04, 0x04, 0, 0, 0x06, 0xA5, NULL, 0, 300*1000); if (ret) return ret; //send right password memset(password, 0xff, CMD_PASSWORD_LEN); ret = mcu_bsl_command(CMD_RX_PASSWORD, 0x24, 0x24, 0, 0, 0, 0, password, CMD_PASSWORD_LEN, 10*1000); if (ret) return ret; printf("%s: start write bin\n", __func__); start = MCU_FLASH_START; /* start download bin */ for (i = 0; i < size; i += UPGRADE_TRUNK) { memcpy(tmp_buf, bin+i, UPGRADE_TRUNK); ret = mcu_bsl_command(CMD_RX_DATA_BLOCK, UPGRADE_TRUNK+4, UPGRADE_TRUNK+4, (start+i) & 0xff, ((start+i) >> 8) & 0xff, UPGRADE_TRUNK, 0, tmp_buf, UPGRADE_TRUNK, 500*1000); if (ret) return ret; printf("%s: write bin 0x%x success\n", __func__, start+i); } printf("%s: start write bin all success\n", __func__); /* download over */ return 0; } int mcu_check_upgrade(void) { unsigned char version, patchlevel; if (poe_get_version(&version, &patchlevel)) { printf("MCU Version: unknown\r\n"); return -1; } printf("MCU Version: %d.%d\r\n", version, patchlevel); return 0; } int mcu_upgrade_routine(void) { struct stat buf; int fd, size, ret; u8 *bin; fd = open(MCU_UPGRADE_FILE, O_RDONLY); if (fd < 0) { printf("No MCU upgrade file, return!\n"); return -ENOENT; } memset(&buf, 0, sizeof(stat)); stat(MCU_UPGRADE_FILE, &buf); size = buf.st_size; if (size > MCU_MAX_BIN) { printf("MCU upgrade bin size is %d, too big!\n", size); close(fd); return -EINVAL; } bin = malloc(size); if (bin == NULL) { printf("%s: malloc %d fail\n", __func__, size); close(fd); return -ENOMEM; } ret = read(fd, bin, size); if (ret != size) { printf("%s: read fail, size:%d, ret:%d\n", __func__, size, ret); close(fd); free(bin); return -EIO; } close(fd); /* first disable jtag��use gpio 13 14 15 */ ret = mcu_bsl_upgrade_start(); if (ret < 0) { printf("mcu_upgrade_prepare fail, ret=%d\n", ret); goto exit_upgrade; } ret = mcu_bsl_uart_init(); if (ret < 0) { printf("mcu_uart_init fail, ret=%d\n", ret); goto exit_upgrade; } mcu_clear(); ret = mcu_low_upgrade(bin, size); if (ret < 0) { printf("mcu_low_upgrade fail, ret=%d\n", ret); goto exit_upgrade; } exit_upgrade: /* MCU reset */ if (mcu_exit_bsl() < 0) { printf("exit BSL fail\n"); return -EIO; } mcu_reset(); ft_udelay(300*1000); mcu_normal_uart_init(); if (ret < 0) { printf("MCU upgrade fail\n"); return ret; } ret = mcu_check_upgrade(); if (ret < 0) { printf("mcu_check_upgrade fail, ret=%d\n", ret); return -EIO; } return 0; } int main(int argc, char *argv[]) { return mcu_upgrade_routine(); }
