  • TI Thinks Resolved
MSP430F5438A: Clock sources stop in debug mode (IAR extended clock control)
Part Number: MSP430F5438A
Hi!
I am using the latest IAR workbench 7.10.5 for the MSP430 along with the new MSP-FETFlash Emulator (the black one). IAR WB offers the possibility for an extended clock control (Emulator -> Advanced -> Extended Clock Control), i.e. which clocks shall stop when hitting a breakpoint.
It happens quite often that all clocks stop even though they are not checked. Currently the only change to override this is to check the boxes (then the MSP430 is reset) and the uncheck them again (which again resets the MSP430).
Whose butt has to be kicked to get rid of that bullshit? Is this a problem of the debugger FW or one of IAR? Notably, that did not happen with the old OLIMEX and old IAR versions.
[Unlocked - 3/23/2018]
  • Hi Jürgen Wissenwasser,
    I will check your question and reply you soon.
    If my post helped solve your issue, please click on the  VERIFY ANSWER    button.
    Wei,
    Search E2E! Your questions may already be answered!
    TI Cloud Tools             MSP Product Page
  • Hi Jurgen,
    I am seeing similar behavior with the MSP-FET and CCS v7.3 that does not occur if I use a MSP-FET430UIF, I will contact the Tools team and see if they can provide any insight into the issue.  Please note that responses will be delayed due to the holiday season.  What is your MSP-FET serial number?
    Ryan
    To better aid the community, please click on the "This Resolved my issue" button whenever a post answers your question!
    I'm sorry I haven't got reply from Tools team for your question. I will continually to contact with team and feedback you then.
    BTW, I would suggest you to go to IAR support forum to get some idea from IAR.
    Wei,
  • [Unlocked - 3/23/2018] ~ _Nic
  • In reply to _Nic:
    Hi Jürgen ,
    Do you have code you can share that reproduces this issue, and a description on how you are observing the clocks? We are having trouble reproducing this.
    Cameron P. LaFollette
  • In reply to Cameron LaFollette:
    Hi!
    That's not that complicated to be reproduced: Run e.g. a timer from XT1 or DCO via SMCLK and generate a PWM on some output pin. Then take a look if the PWM stops when a breakpoint is hit.
    It happens occasionally; I mainly program with assembler.
    My IDE: IAR Workbench for MSP430 Version 7.11.2,
    Debugger: MSP-FETFlash Emulation Tool
  • In reply to Jürgen Wissenwasser:
    I ran PWM code as you said (TA1, in C), and am still not able to replicate this issue after numerous attempts.
    It DOES stop all clocks if I do not press the GO button after adjusting the Advanced Clock Control settings.
    How occaisionally does this happen?
    Nevermind above. I just got it to happen.
