I have programmed my device for UART functionality. When I run the device using CCS debug window, it is working fine and and I am able to see the correct characters on serial terminal. I am facing some problems when the device is removed from power and then again connected.
When again connected, some erroneous characters are being sent to the serial terminal. The device works fine when I reprogram it. What should I do to ensure that correct characters are sent even after a power reset?
Abhishek.
