Refer to MSP430F6779A's data sheet (SLAS982A) as below figure.
What if LCD is charged up from 3.3 V to 3.6 V. Which values in this table will be changed?
How much is it changed?
And how to calculate changed values?
Hello Nattapol,
There is no data for that configuration.
What is the VCC you are using for this device?
Hi Dennis Lehman,
We use 3.3 Vcc power supply when AC power is normal and 3.3 V backup battery when power failed. Or do you have other suggestion for using 3.3 Vcc with LCD charge pump?
Thank you,
Nattapol
Hi Nattapol,
Probably the Icp (load) current. It has a min of 50uA but no typ or max so I assume it could be vary, depending on the LCDCPEN and VLCDx selections.
Hi Nattapol,
I was checking to see if you had any additional questions regarding the LCD module.
I'm assuming you have the answers you need, so I will mark this issue resolved.
If this isn’t the case, please click the "This did NOT resolve my issue" button and reply to this thread with more information, or if you have a new "un-related" question, please open a new posting.
If this thread locks, please click the "Ask a related question" button and in the new thread describe the current status of your issue and any additional details you may have to assist us in helping to solve your issues.
