• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Stellaris® ARM® Microcontrollers » Stellaris® ARM® LM3S Microcontrollers Forum » CCS V4 Error while importing Stellarisware for ARM Cortex-M3
Share
  • Forum
Options
  • Subscribe via RSS
This question is not answered
bhushan kulkarni
Posted by bhushan kulkarni
on Oct 10 2011 00:55 AM
Intellectual270 points
Hello Sir,
I am working on Stellaris ARM Cortex-M3 form LuminaryMicro & i am new to ARM Cortex architechture.
I am using code Code Composer Studio Version: 4.2.3 as a IDE & Stellarisware which is given by LuminaryMicro.
while importing the Stellarisware folder in Code Composer Studio i am getting error & if i go proceed the project will not build & gives following error.
gmake: *** No rule to make target `C:/StellarisWare_firmware/boards/dk-lm3s9b96/blinky/blinky_ccs.cmd', needed by `blinky.out'.
gmake: *** No rule to make target `C:/StellarisWare_firmware/boards/dk-lm3s9b96/blinky/blinky.c', needed by `blinky.obj'.
gmake: *** No rule to make target `C:/StellarisWare_firmware/boards/dk-lm3s9b96/blinky/startup_ccs.c', needed by `startup_ccs.obj'.
I tried a lot,but i am not getting the exact solution.
I am attaching my error image,please kindly help me regarding this error.
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Stellaris Dexter
    Posted by Stellaris Dexter
    on Oct 10 2011 15:29 PM
    Genius14015 points
    The error image shows a macros.ini error.  The macros.ini file defines the path to the SW_ROOT (stellarisware root).  The image makes it appear you are attempting to bring in another project that has a different SW_ROOT definition.
    I think the best place to start would be to find the quick start quide located on the project CD.  Also here.  I suspect that you may have missed a step along the way in this document which would result in this type of error.  Start with a fresh workspace and follow these directions.  Let us know what you find.
    http://www.ti.com/tool/ek-lm4f120xl
    http://www.ti.com/stellarislaunchpadworkshop
    http://processors.wiki.ti.com/index.php/Stellaris_LaunchPad
    http://www.ti.com/tool/sw-ek-lm4f120xl
    Report Abuse
    • Reply
  • Ryan Lush67904
    Posted by Ryan Lush67904
    on May 05 2012 21:41 PM
    Intellectual460 points
    I am getting the same type of error and I am following the Quick Start as closely as possible. However, I see in the document it says if I install CCS from the DVD included with my LM3S9B96-EK the license should automatically be installed. This wasn't the case for me. I didn't have the document at the time and I was very confused which options to pick. It wasn't obvious what to do to ensure I had the full version of CCS to use with my EK. I had to log in to TI to have a license file emailed to me. I could really use a more definitive answer than "check the Quick Start" because the Quick Start has already failed me.
    Report Abuse
    • Reply
  • Ryan Lush67904
    on May 05 2012 22:23 PM
    I was able to fix this by copying the *.cmd for my specific device in C:\Program Files (x86)\Texas Instruments\ccsv4\arm\include and renaming it safertos_demo_ccs.cmd which is <project name>_ccs.cmd. Although I should mention that safeRTOS is currently crashing so that may have not been an entirely correct solution. I hope this is helpful to someone else.
    I could still use an answer to the other question I posed regarding the licensing.
    Report Abuse
    • Reply
  • Stellaris Dexter
    on May 07 2012 07:30 AM
    Genius14015 points
    CCS Installation from either the DVD or the TI website should recognize that you have one of our kits and unlock full features of CCS while connected to the kit.
    safertos_demo_ccs.cmd should be included in the example folder in the StellarisWare installation.  It is also usually imported into the CCS project when you originally import the project.  If this file was missing from your project this may be part of the original problem.
    Please explain "safeRTOS is currently crashing"?  How does it crash?  Is it in a fault handler?  What code is executing?
    Try using LMFlashProgrammer to install the binary from a clean and fresh StellarisWare installation.  Does the binary (as we ship it) behave the same as your build?
    Dexter
    Report Abuse
    • Reply
  • Ryan Lush67904
    on May 07 2012 13:03 PM
    It was going straight to the SafeRTOSErrorHook function as soon as I started running. The project (none of the projects in the C:\StellarisWare\boards\dk-lm3s9b96 directory for that matter) didn't include the safertos_demo_ccs.cmd file so I had to pull a generic one from C:\Program Files (x86)\Texas Instruments\ccsv4\arm\include but that one wasn't setting aside the first 0x20C bytes of RAM for the safeRTOS kernel. Once I changed the cmd file to set aside enough RAM everything started working as expected.
    I'm not sure about the license yet. I had to get one from the TI website to get things to work. So far I haven't experienced any limitations but it didn't really appear to "know" I was using a dev kit. If it did, why would it ask me to select a licensing option?
    Report Abuse
    • Reply
  • Stellaris Dexter
    on May 07 2012 14:31 PM
    Genius14015 points
    First, good to hear you got things up and running.
    The licensing question you got probably happened on install or first execution after install.  The kit detection does not occur until you start a debug session.
    Dexter
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
