• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Stellaris® ARM® Microcontrollers » Stellaris® ARM® LM3S Microcontrollers Forum » Stellaris Watchdog
Share
  • Forum
Options
  • Subscribe via RSS
Helpful Stellaris® LM4F Series Links
  • LM4F Series
  • Stellaris PinMux Utility
  • Stellaris® LM4F120 LaunchPad
  • LM4F MCU Applications
  • LM4F MCU Video
  • ARM Cortex-M4F Whitepaper
  • Stellaris MCU Brochure
  • LM4F232 Eval Kit
  • Stellaris Watchdog
    Stellaris Watchdog
    This question is not answered
    Kevin Schell
    Posted by Kevin Schell
    on Nov 14 2011 11:00 AM
    Prodigy170 points
    In all of my past experiences with a watchdog timer, the behavioral model has been the following:
    * Configure the watchdog to certain timeout period.
    * Call a function to reset the watchdog more frequently than the timeout periond.
    * If the watchdog is not reset before the timeout period, the processor is reset.
    I would like to use the watchdog on my LM3S8962. But when I look at the Stellarisware watchdog example, I see that the "resetting" of the watchdog timer is done in an ISR. This does not seem like a good design to me. Among others, one of the failure modes that a watchdog protects against is a run-away loop, or some other dynamic stimuli that upsets the high-level timing of the code. If I have a nice, high-priority interrupt that resets the watchdog even though I am hopelessly stuck in a loop, what protection is the watchdog actually providing?
    Utlimately, the main question, is the following:
    Using the Stellarisware watchdog.c as a basis for my question, can I modify that code such that the watchdog is reset outside of the watchdog ISR? I don't care if I still have to register and install an ISR for the watchdog interrupt, I will just leave it empty.
    Kevin
    stellaris watchdog
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Stellaris Mitch
      Posted by Stellaris Mitch
      on Nov 14 2011 16:12 PM
      Intellectual2170 points
      Hello Kevin,
      Yes, you can clear the Watchdog interrupt status bit  outside of an ISR (in your main application loop for example). However, I would recommend continuing to use the WatchdogIntClear() method to perform this clear. You might also want to use the WatchdogLock() after your initialization is complete to avoid any stray accesses disabling the Watchdog function.
      RE: watchdog ISR in the example
      You can optionally leave the Watchdog interrupt disabled (don't call IntEnable(INT_WATCHDOG)) and thus not bother setting up an ISR.  It won't impact the functionality if you are clearing the status elsewhere.
      Report Abuse
      • Reply
    • Rob Maris
      Posted by Rob Maris
      on Jan 10 2012 17:24 PM
      Intellectual985 points
      Mitch, Kevin,
      I think it makes anyway sense to really use the interrupt routine associated with the watchdog. However, because of its unusual concept,  I'd expect a more complete demo code resp. hints in the processor's datasheet.
      Using an interrupt routine catches too long interrupt inhibit times or other related problems. That's okay. As Kevin points out, an additional mechanism is required to catch main program hang-up issues.
      My solution: in a main application loop (top level), a variable wdtick is set regularly. Within the watchdog interrupt routine, handling is as follows:
      if (wdtick) {
          wdtick = 0;
          WatchdogIntClear(WATCHDOG0_BASE);
      (however, it must be ensured that the interrupt is not blocking when the flag is not reset - any comments?)
      Report Abuse
      • Reply
    • Todd Zielinski
      Posted by Todd Zielinski
      on Jul 16 2012 17:25 PM
      Intellectual445 points
      I'm rather confused by this 'interrupt' implementation of watchdog. What does this prevent from happening or reset in a useful way?
      - If the processor is stuck in an interrupt routine - then it will never reset.
      - If the processor is stuck in a subloop of the main loop but still services the interrupt - then it will never reset.
      - etc., etc. etc.
      The idea behind a watchdog is supposed to be simple: Start watchdog. If no one resets the timer within the timeout period, reset the processor. Include a mechanism to pause the countdown for things like firmware updates, or high priority services.
      The given watchdog example is useless - might as well have a button on the screen that just pulls reset low thru GPIO. Functionally it's the same. How does using the interrupt routine make sense here..  Can someone explain?
      watchdog
      Report Abuse
      • Reply
    • Rob Maris
      Posted by Rob Maris
      on Jul 18 2012 00:51 AM
      Todd, it looks like you've read the former postings a bit too much on the fly. To your complaints:
      - if the processor is stuck in an interrupt routine, it will reset, because the watchdog is no longer triggered with watchdog refreshes
      - if the mainloop is stuck in a subloop, my suggested variable wdtick is not set. Since the interrupt clears this variable, it will no longer trigger watchdog refreshes...
      Report Abuse
      • Reply
    • Todd Zielinski
      on Jul 18 2012 01:34 AM
      No I didn't read them on the fly. I read the documentation. - and your previous post wasn't clear : "..I think it makes anyway sense to really use the .."  ..?
      Nested interrupts and blocking could create a situation that the watchdog interrupt could continue to be serviced but we never return to other lower priority tasks, or ..a watchdog that is reset while interrupts are being serviced correctly..
      This doesn't solve problems. It creates potential new ones.
      Report Abuse
      • Reply
    • Rob Maris
      Posted by Rob Maris
      on Jul 18 2012 01:55 AM
      Todd, thanks for your reply. I guess that there is some misunderstanding, either on my side or on yours. I'd appreciate it when the case becomes clear. Anybody will benefit from this.
       Well, what's going on, when a watchdog interrupt is serviced continually, but lower priority tasks, or the mainloop are blocking? In the latter case, 'my' interrupt routine will never call
       Which will result in a watchdog reset. Indeed, when I have a blocking of my main loop, a processor reset occurs.
      Report Abuse
      • Reply
    • Kevin Schell
      on Jul 18 2012 10:37 AM
      Prodigy170 points
      Rob, you say that you know that 'your' watchdog interrupt won't get called at the wrong time. What are you doing to 'your' interrupt such that you can ensure that it doesn't call at the wrong time?
      You suggest that if you get stuck in a loop in your main routine that the watchdog will correctly recover your program (by NOT calling the watchdog interrupt). Wouldn't this only work if you had the foresight to turn interrupts off?
      Kevin
      Report Abuse
      • Reply
    • Rob Maris
      Posted by Rob Maris
      on Jul 18 2012 11:21 AM
      Kevin, please read the code snippet above. I'd suggest that this is self-explaining.
      Report Abuse
      • Reply
    • Kevin Schell
      on Jul 18 2012 11:34 AM
      Prodigy170 points
      Rob,
      I don't believe that your code will work as you describe. You say that your special interrupt will not be called. I was asking a follow up question of how you actually accomplish this special behavior. What characteristics and/or properties are you applying to your watchdog interrupt to ensure that it is not called when it should not be called. It sounds like your are saying the following:
      "I will know ahead of time when my code will hit an unrecoverable error, from which only the watchdog timer can save me. So when I know that the unrecoverable error is about to occur, I first disable interrupts so that the watchdog timer will not reset once I hit the error."
      If I have misunderstood your description of your design, could you please correct me?
      Kevin
      Report Abuse
      • Reply
    • slandrum
      Posted by slandrum
      on Jul 18 2012 11:49 AM
      Mastermind9510 points
      In his code above, two things must happen to reset the watchdog timer.
      The interrupt must occur, and the the flag must be set (by main line code).
      So - if his code block disables the interrupt, the watchdog will time out and his device will reset.  If his code goes stray, the main line code will stop executing, won't set the flag, and the interrupt code will see that the flag isn't set so will never reset the watchdog timer - so his device will reset.
      Report Abuse
      • Reply
    • Rob Maris
      Posted by Rob Maris
      on Jul 18 2012 12:08 PM
      Well, masterminds provide a more qualified insight then others?
      As a corollary to slandrums contribution, I'd state that it is generally a good idea to refresh the watchdog timer as a result of logical ANDs of several important places where program code is going through cyclically. E.g. the variable wdtick as given in the example may have assigned individual bits which are set by program code, and in interrupt code, watchdog refresh is allowed only, when all assigned bits are set.
      Report Abuse
      • Reply
    • Kevin Schell
      on Jul 18 2012 12:37 PM
      Prodigy170 points
      Ah, okay, I didn't see the code above that shows your algorithm. My appologies. So the interrupt will actually execute, but the contents of the ISR won't execute unless the code is working properly. I wouldn't choose that approach, but it does look like it will work.
      "I'd state that it is generally a good idea to refresh the watchdog timer as a result of logical ANDs of several important places where program code is going through cyclically."
      I agree very much.
      Report Abuse
      • Reply
    • cb1_mobile
      Posted by cb1_mobile
      on Jul 18 2012 14:00 PM
      Guru21760 points
      Suspect that WD management further benefits - not just from logical And'ing of program flow events - but also from check/verify of key MCU frequencies, voltages, even pwm duties.  32 bit wide register(s) provide adequate room for added content - of course test & set must be quick/efficient. (or refreshed/tested only every n cycles)
      Within reason - the greater the number of "key MCU areas" being properly monitored - the more robust your MCU system...  Thanks to all early-on participants & slandrum for some keen insights.   Believe that a better "mouse watch-trap" has emerged...
      Report Abuse
      • Reply
    • Pat Harris
      Posted by Pat Harris
      on Aug 28 2012 10:17 AM
      Expert2105 points
      I am using the Concerto, vs the Stellaris, but I understand that the operation and behavior is consistent. I am trying to get WDT0 implemented to provide a work-around to another problem and have been testing both the watchdog example in V110 and V130 examples for the Master. The example do show that the system will reset. The problem is, the reset never quits! I have tried it with the interrupt as well as without (just putting WatchdogIntClear(WATCHDOG0_BASE); in my main task), but neither seems to stop the reset every 2 seconds. Even removing the return from the interrupt service routine had no effect.
      Does anyone have any idea why this would occur?
      Pat
      Report Abuse
      • Reply
    • Pat Harris
      on Aug 28 2012 17:00 PM
      Expert2105 points
      An update. By eliminating the ISR, I can now get the watchdog example to work properly. However, when I try to apply the concept to my application, I have no success. Placing the WatchdogIntClear in my main task, stops the app from running. I also found that the NVIC statement (HWREG(NVIC_VTABLE) = 0x20005000;) seems to prevent operation as well. When everything else is enabled and the NVIC and  Clear is removed, the app runs forever, never reseting, so apparently, the WDT is not actually running. I am using the f28m35h52c1 chip. Any help here would be greatly appreciated.
      Pat
      Report Abuse
      • Reply
    12
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
