• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Stellaris® ARM® Microcontrollers » Stellaris® ARM® LM3S Microcontrollers Forum » How to init touch screen
Share
  • Forum
Options
  • Subscribe via RSS
Helpful Stellaris® LM4F Series Links
  • LM4F Series
  • Stellaris PinMux Utility
  • Stellaris® LM4F120 LaunchPad
  • LM4F MCU Applications
  • LM4F MCU Video
  • ARM Cortex-M4F Whitepaper
  • Stellaris MCU Brochure
  • LM4F232 Eval Kit
  • How to init touch screen
    This question is not answered
    Kha Man Huynh
    Posted by Kha Man Huynh
    on Nov 25 2011 05:55 AM
    Prodigy130 points
    I have a DK-LM3S9b96 and creating a new project. In examples, in my opinion, init touchscreen by adding more file :
    - touch.c
    - Main():     TouchScreenInit();   TouchScreenCallbackSet(WidgetPointerMessage);   (I'm using Widget Icon)
    - startup_rvmdk.S  (I sure it's correct)
    And my init is the same but it didn't work.  Can anyone help me ? I'm new.
    Thank you
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Andy Neil
      Posted by Andy Neil
      on Nov 26 2011 05:50 AM
      Guru31775 points
      Kha Man Huynh
      my init is the same
      The same as what?
      Kha Man Huynh
      but it didn't work
      Then it cannot be the same!
      Kha Man Huynh
      Not based on the information you've provided - or, rather, the lack of it!
      I suggest that you start with one of the provided examples, and work from there...
      Kha Man Huynh
      I'm new
      New to what, exactly?
      • New to any form of programming?
      • New to microcontrollers?
      • or what?
      Report Abuse
      • Reply
    • cb1-
      Posted by cb1-
      on Nov 27 2011 00:30 AM
      Mastermind9080 points
      Many share your difficulty in, "creating a new project."  So many things have to go right - even one "missed" setting will yield errors - derail your progress.  So - do you really "need" a "new project?"  You can build your understanding/experience with your IDE by staying with a "provided" project.  You can add a numeral suffix (test.c becomes test1.c) - which maintains the original file.  You must read, understand & comply with the IDE's instructions to "remove" this single, original file - and then "add" the renamed/copied file.  This should work.
      Before you attempt your "new project" you must carefully note - and log - "ALL" of your project's settings - especially those which involve "finding" files, and other file or tool linkages.  Even with years of use - we find it easiest/less frustrating to simply "copy" an existing project - then rename it - and then add it to our workspace.  This is NOT fully automatic - several key IDE files then must be renamed or otherwise "tweaked" - but it is much simpler than starting a project completely from scratch...
      I'd bet that several hundred such "new project then Boom!" posts lurk in this (and other) ARM forums.  IDE tool providers care/skill at clearly detailing, "new project creation" seems "not" to match the otherwise neat capabilities of their IDE...  (IDE creators are likely "too close" to their creation - cannot imagine the multiple pitfalls we mortal users face...)
      BTW - should not your post's subject be, "Creating a New Project," - rather than "init a Touch-Screen?"  Future searchers will "not" be pleased...
      Report Abuse
      • Reply
    • Dave Wilson
      Posted by Dave Wilson
      on Nov 28 2011 09:36 AM
      Mastermind22830 points
      As Andy said, you really don't provide enough information here to help someone else have an idea of what may be wrong. If you can provide more useful on the problem (for example, I presume you've run your code in the debugger? Is the touchscreen ADC interrupt service routine getting called? Is the system faulting? If so, where?) we will have a better chance of pointing you in the right direction.
      In the meantime, if the code is not faulting due to a peripheral that you are accessing without calling SysCtlPeripheralEnable first, I'm willing to guess that your problem relates to not having hooked the touchscreen driver's interrupt handler in your startup_rvmdk.S file. Did you copy this from another project that uses the touchscreen? If not, take a look at one of the examples that does use the touchscreen and make sure you have TouchScreenIntHandler hooked to the ADC3 vector.
      Report Abuse
      • Reply
    • cb1-
      Posted by cb1-
      on Nov 28 2011 09:56 AM
      This reporter continues in the belief that poster's issue extends "far beyond" touch-screen init.  The "Create NEW Project" issue is the gorilla in this room - and has been (seemingly) "ducked."
      Specific "touch" advice appears "spot-on" - but avoids the growing, "NEW Project disenchantment."  BTW - poster clearly states that touch screen & related code all DID WORK - issue arose "only after" his, "NEW Project" attempt.
      Report Abuse
      • Reply
    • Dave Wilson
      on Nov 28 2011 10:22 AM
      I agree with you 100%. We're aware of the general confusion related to creating new StellarisWare projects on all the supported GUI toolchains and you can be assured that we're working on making it a lot cleaner and easier.
      Report Abuse
      • Reply
    • cb1-
      Posted by cb1-
      on Nov 28 2011 10:38 AM
      Thank you Sir - when the "event counter" over-flows - perhaps "time is right" to deal with the real issue.  (I know big firm has inertia - and you did respond timely and with great specifics - but "someone" had to point toward the obvious)
      Not content to "confine meddling" - much earlier raised this flag w/Blake.  I'm told he posted my suggestion "high on pile" from "unsolicited/crazies."   Ah - status at last...
      Report Abuse
      • Reply
    • Kha Man Huynh
      Prodigy130 points
      I found out my problem that SW-GRL-UG-7xxx.pdf is not in My Stellaware. I'm terribly sorry because of the little information but I think if anyone works with it a lot, so they will answer this problem quickly.Thanks you for replying this thread
      I has just finished my project with my LM3S9B92 & LM3S6618 design board that using Ethernet,sd card, graphic LCD , ... It's new for me, moreover, debugger such as ULINK, ICDI made me debug a lot . I can't find what my problem is , for ex, invalid rom, cannot access memory , especially at that time i didn't know about it & stellaris MCUs are not popular in my country
      JLINK is the best tool debugger Stellaris MCUs indeed.
      However, it didn't related to this subject. In SW-GRL-UG (that found in another Firmware package) give a lot information about graphic 3.5" :D. Specially I'm very interested in the programming way of TI, very very excellent although it's hard to understand.
      I don't know why most of Stellaris MCUs are so HOT ? Will they die in a unlucky day ?
      Well, however STM32 will be the best in ARM M3 branch because of its performance & price. Stellaris may be in 2nd or 3rd because their documents are so strange for learning to design & they are very expensive. For example, I'm newbie, when I see ICDI design & JTAG debugger with ICDI, their components are so strange. Why don't you make easy designs for students to learn ?
      I think Ethernet on chip is only thing for you to consider using Stellaris (>6000).
      Report Abuse
      • Reply
    • cb1-
      Posted by cb1-
      on Nov 28 2011 10:56 AM
      Uh oh - "time to run for the hills..."   Ai Carumba...  How "could" we have known?
      Report Abuse
      • Reply
    • Dave Wilson
      on Nov 28 2011 11:52 AM
      Interesting. If you did not include grlib in your project, you would have seen linker errors when you tried to build the project. From your initial post, I assumed you were seeing a runtime error after downloading so that prompted my original suggestions. I'm glad you got the problem fixed, though. You mentioned that you were using a dk-lm3s9b96 board and the StellarisWare release for this board includes the graphics library. The releases for boards which contain no displays (like the ek-lm3s9b92 and ek-lm3s9b90), however, do not include grlib since it would be rather confusing. As for any other component of StellarisWare, even if your board's release doesn't include a component, you can download it separately from the http://www.ti.com/stellarisware.
      Regarding usability of StellarisWare, we spend a great deal of time trying to make the software as easy to use as possible. All kits are tested by people unfamiliar with the boards and software to make sure that they can be brought up in 10 minutes or less using the provided instructions as we promise. If you are having problems, please send us suggestions for improvement or let us know the areas that you think are confusing and it's pretty likely that you'll see changes in the next release to address those concerns.
      Your choice of MCU will obviously depend upon the requirements of your project and there will definitely be cases where you can't use a Stellaris part for some reason or another. In cases where parts from a competitor and Stellaris parts both fit your requirements, however, take a look at our competitors' software offerings and play with their boards and I'm willing to bet you'll change your opinion about the usability of StellarisWare :-)
      Report Abuse
      • Reply
    • Blake Ethridge
      Posted by Blake Ethridge
      on Nov 28 2011 14:57 PM
      Mastermind18505 points
      Always glad to help!
      For the "Popular Post" widget in regards to E2E and current slate of development we are looking at fixes for this in 1H 2012. In the short term efforts like the Code Composer Forum have opted to remove it all together and gone with a manual based approach for curating most relevant forum threads.
      Blake
      Blake Ethridge, Social Media Community Engagement Manager, Texas Instruments
      E2E Blog - Stay up to date on all E2E news and updates | About E2E | Updating Your Avatar
      Report Abuse
      • Reply
    • cb1-
      Posted by cb1-
      on Nov 28 2011 15:45 PM
      First half 2012 is long time to "keep" never-functional "popularity gauge!"   Especially when (and previously noted) alternative use of such vital space is, "on the table."
      I know that (you/TI) are not "ready" to implement such change - as past suggested.  However sometimes even "imperfect" first-pass "safeguards" serve as a substantial improvement over, "lost/meaningless holders" of such priority space!  Cannot - should not - this errant popularity gauge be moved to a screen location of less prominence?  (thus providing "prime space" for (others/I believe) meaningful MCU safeguards...)
      Preventing issues is most always preferable to (forgive me) their harder, more expensive "after the fact" fix...
      Report Abuse
      • Reply
    • Andy Neil
      Posted by Andy Neil
      on Nov 28 2011 15:59 PM
      Guru31775 points
      Kha Man Huynh
      On what basis?
      Kha Man Huynh
      the programming way of TI ... it's hard to understand
      What, specifically, is hard to understand?
      Kha Man Huynh
      If you're using the same STM32 documentation that I've seen, I fail to see how the Stellaris documentation can in any way be called "strange"!!
      Kha Man Huynh
      ... for learning to design
      Neither the Stellaris nor the STM32 documentation is intended to teach you to design; ST and TI are manufacturers - if you need to learn how to design, then you should be seeking a training provider...
      (having said that, both TI and ST do provide seminars, etc)
      Kha Man Huynh
      I think Stellaris kits are ideal for students to learn on - but the student must have have the necessary background, and needs to put in the effort to study the supporting material
      Report Abuse
      • Reply
    • Blake Ethridge
      on Nov 28 2011 16:51 PM
      I certainly agree with your assessment and we push as hard as we can for improvement. Some items require longer given current projects and development schedules. Feedback like this is great for us being able to potentially escalate items quicker.
      For this the solution we have for Code Composer or similar could potentially work here in the interim if stakeholders in the Stellaris forum are willing to do so.
      Report Abuse
      • Reply
    • cb1-
      Posted by cb1-
      on Nov 28 2011 17:38 PM
      You Sir - truly/ever the diplomat.  (so expected you to tell me how you "really" felt - where I should go...)   (and you do realize that now - past 17:00 local - my "forum rescue rate" rises to 1.5x "normal")   As Army Lt we were taught less, "let's see" - more CAN DO...
      Report Abuse
      • Reply
    • Blake Ethridge
      on Nov 28 2011 22:48 PM
      Quick update cb1, we are in the process of reviewing this to see what we can do in the short term in regards to popular widget and trending/important threads. Content curation will take longer but will see on getting more traction there. For hours of operation, I try to be on here 24/7 save for when I sleep.
      Report Abuse
      • Reply
    12
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
