• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Stellaris® ARM® Microcontrollers » Stellaris® ARM® LM3S Microcontrollers Forum » USB Host FTDI CDC
Share
  • Forum
Options
  • Subscribe via RSS
Helpful Stellaris® LM4F Series Links
  • LM4F Series
  • Stellaris PinMux Utility
  • Stellaris® LM4F120 LaunchPad
  • LM4F MCU Applications
  • LM4F MCU Video
  • ARM Cortex-M4F Whitepaper
  • Stellaris MCU Brochure
  • LM4F232 Eval Kit
  • USB Host FTDI CDC
    USB Host FTDI CDC
    This question is not answered
    Peter Šamperl
    Posted by Peter Šamperl
    on Jan 23 2012 03:00 AM
    Intellectual530 points
    I'm working on hosting cdc FTDI FT232R USB virtual comport.
    I have managed to modify usb cdc device example and making it a host.
    I have implemented usb host cdc driver and managed to send FTDI set baud rate request.
    I can now send data over virtual com port using USBHCDPipeWrite.
    I'm now facing a problem on receiving end.
    How is the receive logic implemented and how should it be used in my case?
    Device Descriptor:
    bcdUSB: 0x0200
    bDeviceClass: 0x00
    bDeviceSubClass: 0x00
    bDeviceProtocol: 0x00
    bMaxPacketSize0: 0x08 (8)
    idVendor: 0x0403 (Future Technology Devices International Limited)
    idProduct: 0x6001
    bcdDevice: 0x0600
    iManufacturer: 0x01
    0x0409: "FTDI"
    iProduct: 0x02
    0x0409: "MCTEST C"
    0x0409: "MCTEST C"
    iSerialNumber: 0x03
    0x0409: "FTPBG74H"
    bNumConfigurations: 0x01
    ConnectionStatus: DeviceConnected
    Current Config Value: 0x01
    Device Bus Speed: Full
    Device Address: 0x01
    Open Pipes: 2
    Endpoint Descriptor:
    bEndpointAddress: 0x81 IN
    Transfer Type: Bulk
    wMaxPacketSize: 0x0040 (64)
    bInterval: 0x00
    bEndpointAddress: 0x02 OUT
    Transfer Type: Bulk
    bInterval: 0x00
    Configuration Descriptor:
    wTotalLength: 0x0020
    bNumInterfaces: 0x01
    bConfigurationValue: 0x01
    iConfiguration: 0x00
    bmAttributes: 0xA0 (Bus Powered Remote Wakeup)
    MaxPower: 0x2D (90 Ma)
    Interface Descriptor:
    bInterfaceNumber: 0x00
    bAlternateSetting: 0x00
    bNumEndpoints: 0x02
    bInterfaceClass: 0xFF
    bInterfaceSubClass: 0xFF
    bInterfaceProtocol: 0xFF
    iInterface: 0x02
    0x0409: "MCTEST C"
    0x0409: "MCTEST C"
    Transfer Type: Bulk
    bInterval: 0x00
    Transfer Type: Bulk
    bInterval: 0x00
    USB FTDI CDC
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Charlie Ellis
      Posted by Charlie Ellis
      on Jan 23 2012 12:08 PM
      Prodigy10 points
      Peter,
      We are facing a similar situation and considering porting the Device CDC implementation over to the Host USB stack. we aren't using FTDI interface but the on-chip USB host controller instead but the effort to do the port should be the same as what you did. How challenging was the task and how long it take you? Is there any code you can share at all, or short of that, advice from your experinece?
      Regards & thanks,
      Charlie Ellis, Vanteon Corp.
      Report Abuse
      • Reply
    • Peter Šamperl
      on Jan 24 2012 01:47 AM
      Hello Charlie,
      "How challenging was the task and how long it take you?"
      It took me a week to communicate with FTDI chip and send out data. User guide for USB library was quite helpful.
      Examples on this sites were also very helpful:
      http://code.google.com/p/propilot/source/browse/trunk/Microchip/USB/CDC%20Host%20Driver/usb_host_cdc.c?r=75
      https://github.com/felis/USB_Host_Shield_2.0
      especially felis.
      "Is there any code you can share at all, or short of that, advice from your experience?"
      I will put usb_host_cdc example on this post today or tomorrow.
      I can now read from Bulk In Pipe by using USBHCDPipeRead and not USBHCDPipeReadNonBlocking. Somehow the second function is not returning data. Will investigate further and prepare source for share.
      Peter
      Report Abuse
      • Reply
    • slandrum
      Posted by slandrum
      on Jan 24 2012 11:04 AM
      Mastermind9510 points
      You do realize that the non-blocking versions of functions always return immediately regardless of whether they can perform the requested task.  You have to check the status return to see if the call was successful.  If the call was not successful (in this case because data hasn't been received yet), you need to loop back an try again.
      Report Abuse
      • Reply
    • Peter Šamperl
      on Jan 25 2012 05:30 AM
      Thanks for reply,
      I have used USBHCDPipeSchedule() functionality now, by setting callback when BulkInPipe is allocated.
      // Allocate the USB Pipe for this Bulk IN endpoint.
       g_USBHCDCDevice.ulBulkInPipe =
      USBHCDPipeAllocSize(0, USBHCD_PIPE_BULK_IN_DMA,
      pDevice->ulAddress,
      pEndpointDescriptor->wMaxPacketSize,
      USBHCDCINCallback);
      // Configure the USB pipe as a Bulk IN endpoint.
      USBHCDPipeConfig(g_USBHCDCDevice.ulBulkInPipe,
      64,
      (pEndpointDescriptor->bEndpointAddress &
      USB_EP_DESC_NUM_M));
      Callback looks like this:
      unsigned char SchedulePipeInBuffer[64];
      void USBHCDCINCallback(unsigned long ulPipe, unsigned long ulEvent)
      //unsigned long ulSize;
      // Handles a request to schedule a new request on the interrupt IN
      // pipe.
      if(ulEvent == USB_EVENT_SCHEDULER)
      USBHCDPipeSchedule(ulPipe, SchedulePipeInBuffer, 64);
      // Called when new data is available on the interrupt IN pipe.
      if(ulEvent == USB_EVENT_RX_AVAILABLE)
      // If the callback exists then call it.
      if(g_USBHCDCDevice.pfnCallback != 0)
       //Handle received data
       g_USBHCDCDevice.pfnCallback((unsigned long)&g_USBHCDCDevice,
      CDC_EVENT_RX_AVAILABLE, (void*)SchedulePipeInBuffer);
      memset(SchedulePipeInBuffer,0,64);
       //schedule another read
      I don't know if DMA is the best solution for receiving data, as I'm getting all 64 bytes after DMA finishes reading.
      So I don't know where my data ends in received buffer.
      DMA is probably the best solution for Mass Storage Device, but for my functionality where received size is not known.
      I will probably have to implement something else.
      Any suggestions?
      Report Abuse
      • Reply
    • Peter Šamperl
      on Jan 25 2012 06:41 AM
      I have now disabled DMA on Pipe In.
      USBHCDPipeAllocSize(0, USBHCD_PIPE_BULK_IN,/*USBHCD_PIPE_BULK_IN_DMA,*/
      pDevice->ulAddress,
      USBHCDCINCallback);
      And changed callback function when RX_AVAILABLE. When I receive
      USB_EVENT_RX_AVAILABLE I read out from pipe and schedule another read.
      // Read the Data out.
      ulSize = USBHCDPipeReadNonBlocking(g_USBHCDCDevice.ulBulkInPipe, SchedulePipeInBuffer,
      64);
      I get the correct size now when not using DMA.
      If anyone has a better approach please let me know.
      Peter
      Report Abuse
      • Reply
    • Peter Šamperl
      on Jan 26 2012 05:56 AM
      Charlie,
      I have prepared an example of CDC host driver for the use with FTDI chip.
      5488.Stellaris USB CDC Host Example.zip
      I hope I'm not violating any copyright law.
      This example application demonstrates using a
      USB Communications Device Class for hosting a FTDI FT232R device.
      I'm using FTDIs UB232R development module:
      http://apple.clickandbuild.com/cnb/shop/ftdichip?productID=66&search=UB232R&op=catalogue-product_info-null
      Which has this FTDI chip:
      http://www.ftdichip.com/Products/ICs/FT232R.htm
      It has USB_CLASS_VEND_SPECIFIC (0xff) Interface Class.
      Other CDC drivers could also be added to this example in the future (ACM, Prolific,...).
      We will use it for connecting GSM modem (over FTDI) to our custom Stellaris board with OTG support.
      Copy files to StellarisWare folder
      Add usb_host_cdc project to workspace
      Add usbhcdc.c and usbhcdcftdi.c to usblib project.
      Recompile usblib.
      Upload to target.
      After device is enumerated it sends FTDI baudrate control transfer.
      Baudrate is set to 115200.
      When FTDI is connected to USB OTG it will send out "usb_host_cdc echo example" string.
      When device is ready everything FTDI receives on RX is send to TX (echo).
      Peter
      Report Abuse
      • Reply
    • Luciano Cordelli Coan Luciano Coan
      Posted by Luciano Cordelli Coan Luciano Coan
      on Jul 19 2012 08:49 AM
      Prodigy60 points
      Hi Peter! Great job you have done! I´m a newbie with USB, and I was able to almost make your software work.
      Almost because I´m trying to connect a Prolific device in my LM3S9B96. I can see the following:
      USB reset.
      Connection 0 - getting device descriptor
      Connection 0 - setting address 1
      Connection 0 - getting config descriptor
      Connection 0 - setting configuration.
      I know that I have to include the Prolific driver, but I couldn´t find where... Debugging the software, I see the status HCD_DEV_CONFIGURED in g_sUSBHCD.eDeviceState[0], but the g_eState is always STATE_UNKNOWN_DEVICE.
      Where is the FTDI device info in your software? I have read a lot of times the files and I didn´t find it. I´m sure that if I find it I will be able to make it work.
      Thank you!
      USB HOST CDC
      Report Abuse
      • Reply
    • Peter Šamperl
      on Jul 20 2012 01:06 AM
      Hello Luciano,
      I had the same problem when debugging and learning how USB library works.
      In this example I'm using USB_CLASS_VEND_SPECIFIC interface class, maybe your device has different class interface.
      And when usb library is searching for driver (USBHCDOpenDriver()) for your device, it cannot match ulInterfaceClass.
      I have used USBlyzer demo (2.0 build 25, which can be used as demo all the time if you change system clock) on my PC to lookup my device info:
      USBView is also great and is free:
      http://www.ftdichip.com/Support/Utilities.htm
      BTW: In the meantime, I have implemented ACM driver for Stellaris using this example code:
      And as I can see, it has prolific example also. Maybe it helps.
      Best regards
      Report Abuse
      • Reply
    • Peter Šamperl
      on Jul 20 2012 01:09 AM
      Looks like image is not displayed, So I'm attaching a smaller one and txt:
      Connection Status Device connected
      Current Configuration 1
      Speed Full (12 Mbit/s)
      Device Address 1
      Number Of Open Pipes 2
      Device Descriptor MCTEST C
      Offset Field Size Value Description
      0 bLength 1 12h
      1 bDescriptorType 1 01h Device
      2 bcdUSB 2 0200h USB Spec 2.0
      4 bDeviceClass 1 00h Class info in Ifc Descriptors
      5 bDeviceSubClass 1 00h
      6 bDeviceProtocol 1 00h
      7 bMaxPacketSize0 1 08h 8 bytes
      8 idVendor 2 0403h Future Technology Devices International, Ltd
      10 idProduct 2 6001h
      12 bcdDevice 2 0600h 6.00
      14 iManufacturer 1 01h "FTDI"
      15 iProduct 1 02h "MCTEST C"
      16 iSerialNumber 1 03h "FTPBG74H"
      17 bNumConfigurations 1 01h
      Configuration Descriptor 1 Bus Powered, 90 mA
      0 bLength 1 09h
      1 bDescriptorType 1 02h Configuration
      2 wTotalLength 2 0020h
      4 bNumInterfaces 1 01h
      5 bConfigurationValue 1 01h
      6 iConfiguration 1 00h
      7 bmAttributes 1 A0h Bus Powered, Remote Wakeup
      4..0: Reserved ...00000
      5: Remote Wakeup ..1..... Yes
      6: Self Powered .0...... No, Bus Powered
      7: Reserved (set to one)
      (bus-powered for 1.0) 1.......
      8 bMaxPower 1 2Dh 90 mA
      Interface Descriptor 0/0 Vendor-Specific, 2 Endpoints
      0 bLength 1 09h
      1 bDescriptorType 1 04h Interface
      2 bInterfaceNumber 1 00h
      3 bAlternateSetting 1 00h
      4 bNumEndpoints 1 02h
      5 bInterfaceClass 1 FFh Vendor-Specific
      6 bInterfaceSubClass 1 FFh
      7 bInterfaceProtocol 1 FFh
      8 iInterface 1 02h "MCTEST C"
      Endpoint Descriptor 81 1 In, Bulk, 64 bytes
      0 bLength 1 07h
      1 bDescriptorType 1 05h Endpoint
      2 bEndpointAddress 1 81h 1 In
      3 bmAttributes 1 02h Bulk
      1..0: Transfer Type ......10 Bulk
      7..2: Reserved 000000..
      4 wMaxPacketSize 2 0040h 64 bytes
      6 bInterval 1 00h
      Endpoint Descriptor 02 2 Out, Bulk, 64 bytes
      0 bLength 1 07h
      2 bEndpointAddress 1 02h 2 Out
      6 bInterval 1 00h
      Report Abuse
      • Reply
    • Tsuneo Chinzei
      Posted by Tsuneo Chinzei
      on Jul 20 2012 02:01 AM
      Expert2630 points
      Peter,
      First of all, FTDI chip isn't a CDC device. It's a vendor-specific.
      Just those devices, which expose 0x02 at interfaceClass field of its interface descriptor, is called as CDC.
      Your implementation seems almost fine, but a couple of refinement is required.
      1) In USBHCDCOpen() (usbhcdc.c), check VID/PID on the device descriptor, first, so that this routine succeeds just for the target FTDI chip.
      2) The first two bytes of every bulk IN packet hold status bytes from the chip. The rest of the packet, if any, is the RX data.
      As of the contents of the status bytes, refer to the source code of libFTDI
      http://www.intra2net.com/en/developer/libftdi/
      ftdi.c
          Poll modem status information
          This function allows the retrieve the two status bytes of the device.
          The device sends these bytes also as a header for each read access
          where they are discarded by ftdi_read_data(). The chip generates
          the two stripped status bytes in the absence of data every 40 ms.
          Layout of the first byte:
          - B0..B3 - must be 0
          - B4       Clear to send (CTS)
                       0 = inactive
                       1 = active
          - B5       Data set ready (DTS)
                       0 = inactive
                       1 = active
          - B6       Ring indicator (RI)
                       0 = inactive
                       1 = active
          - B7       Receive line signal detect (RLSD)
                       0 = inactive
                       1 = active
          Layout of the second byte:
          - B0       Data ready (DR)
          - B1       Overrun error (OE)
          - B2       Parity error (PE)
          - B3       Framing error (FE)
          - B4       Break interrupt (BI)
          - B5       Transmitter holding register (THRE)
          - B6       Transmitter empty (TEMT)
          - B7       Error in RCVR FIFO
      Tsuneo
      USB
      Report Abuse
      • Reply
    • Tsuneo Chinzei
      on Jul 20 2012 02:30 AM
      Expert2630 points
      Hi Peter and Charlie,
      Prolific PL2303 is also a vendor-specific.
      The differences from FTDI are,
      1) PL2303 has an extra interrupt IN endpoint, which returns status bytes. FTDI returns the status bytes over the first two bytes of every bulk IN packet.
      2) The command over vendor requests (control transfer) are different from those FTDI's at all.
      As of the baud rate setting, refer to pl2303_set_termios() on this Linux driver source.
      Linux/drivers/usb/serial/pl2303.c
      http://lxr.free-electrons.com/source/drivers/usb/serial/pl2303.c#L250
      I believe it isn't so much work, to apply Peter's FTDI implementation to Prolific.
      Tsuneo
      USB
      Report Abuse
      • Reply
    • Peter Šamperl
      on Jul 20 2012 07:26 AM
      Tsuneo,
      Most thanks for all the comments.
      I will implement those changes and also add ACM code to the example project maybe it would be useful to someone.
      Now we have a ACM GPRS Benq M23 modem for our research project like this one:
      http://www.circuitsathome.com/mcu/interfacing-arduino-to-usb-gprs-modem/comment-page-1#comments
      I can now communicate with Benq M23.
      I’m having problem detecting when socket is closed.
      We are used to detect this using DCD pin on other serial communication modems.
      I have noticed that CDC ACM has this capability with interrupt endpoint.
      When I first open a socket I receive data on interrupt endpoint:
      A1 20 00 00 00 00 02 00 83 00
      By USB Class Definition for Comminication Devices pdf, this is a Class-Specific Notification 0xA1 with “Serial State” notification 0×20, indicating that DCD signal is high.
      But if the socket is closed I stop receiving endpoint interrupts.
      I receive DCD high notification only once when socket is opened.The second time when socket is closed DCD low is not present, which would be useful for detecting if other side has disconnected. Now, I have implemented a NO CARRIER detection. But interrupt would be more elegant.
      Thanks for all the information.
      Best Regards
      Report Abuse
      • Reply
      on Jul 20 2012 09:24 AM
      Prodigy60 points
      Hi Peter and Tsuneo! Thank you all guys for the help!
      I will follow your recommendations.
      Luciano
      Report Abuse
      • Reply
    • Tsuneo Chinzei
      on Jul 20 2012 23:22 PM
      Expert2630 points
      Hi Luciano,
      Auu sorry,
      Prolific implementation request was yours.
      Prolific protocol likes CDC-ACM's more than FTDI's.
      (CDC-ACM: Communication Device Class - Abstract Control Model, class triad = (0x02, 0x02, 0x01))
      1) Descriptors
      Prolific descriptors are simplified one of CDC-ACM;
      - Single interface with three endpoints (interrupt IN, bulk IN/OUT)
      - No extra class-specific descriptor
      2) Bulk IN/OUT endpoints
      Prolific exchanges just data (without status) over bulk IN/OUT, like CDC-ACM
      3) Modem Status
      Prolific carries status byte over the interrupt IN pipe, like CDC-ACM
      The status byte locates on the ninth byte of "Notification" bytes, like CDC-ACM
      Its bitmap is same as those of CDC-ACM, just with CTS extension.
      Prolific status byte bitmap
      http://lxr.free-electrons.com/source/drivers/usb/serial/pl2303.c#L134
      134 #define UART_DCD                        0x01
      135 #define UART_DSR                        0x02
      136 #define UART_BREAK_ERROR                0x04
      137 #define UART_RING                       0x08
      138 #define UART_FRAME_ERROR                0x10
      139 #define UART_PARITY_ERROR               0x20
      140 #define UART_OVERRUN_ERROR              0x40
      141 #define UART_CTS                        0x80
      CDC-ACM: UART State Bitmap of SERIAL_STATE notification
      D0 bRxCarrier - DCD
      D1 bTxCarrier - DSR
      D2 bBreak     - break
      D3 bRingSignal - Ring
      D4 bFraming   - framing error
      D5 bParity    - parity error
      D6 bOverRun   - overrun error
      D15..D7       - reserved
      In these reasons, Peter's CDC-ACM implementation will give you better starting point for Prolific.
      Hi Peter,
      Maybe you've already touched to them, here is a little mods for your first code.
      usbhcdc.c
      static void *
      USBHCDCOpen(tUSBHostDevice *pDevice)
          // Loop through the endpoints of the device.
      //  for(iIdx = 0; iIdx < 3; iIdx++)
          for(iIdx = 0; iIdx < pInterface->bNumEndpoints; iIdx++)
              // See if this is a bulk endpoint.
      //      if((pEndpointDescriptor->bmAttributes & USB_EP_ATTR_BULK) ==
      //         USB_EP_ATTR_BULK)
              if((pEndpointDescriptor->bmAttributes & USB_EP_ATTR_TYPE_M) == USB_EP_ATTR_BULK
      Tsuneo
      USB
      Report Abuse
      • Reply
    • Tsuneo Chinzei
      on Jul 21 2012 01:58 AM
      Expert2630 points
      Peter Šamperl:
      CDC Class drivers of major OS, Windows, Linux and MacOSX keep interrupt/bulk pipes open, while a CDC device plugs in, regardless of open/close of (virtual) COM port. Incoming data to the bulk IN pipe is held on a RX buffer of the class driver. Modem status over the interrupt IN pipe refreshes status holding on the class driver. This behavior is also expected on embedded host, too.
      Tsuneo
      USB
      Report Abuse
      • Reply
    12
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
