• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Stellaris® ARM® Microcontrollers » Stellaris® ARM® LM3S Microcontrollers Forum » TFTP server causes UDP to stop working after a connection break?
Share
  • Forum
Options
  • Subscribe via RSS
This question is not answered
Stefano Bettega
Posted by Stefano Bettega
on Apr 02 2012 10:16 AM
Prodigy245 points
I'm transferring a file by TFTP from PC to our board, using a LM3S9B96. It works fine, except when I break the connection in the middle of a transfer (i.e. forcibly closing application on PC). After this event, no more UDP connection can be made to the board (i.e. also the Finder application couldn't locate the board).
As I don't have an evaluation board to test the original qs-checkout demo to see if this happens, I would like to know if there is anybody that could perform this test and post results here.
Many thanks in advance and best regards
Stefano
LM3S9B96 UDP StellarisWare TFTP
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Sean de la Haye
    Posted by Sean de la Haye
    on Apr 02 2012 14:56 PM
    Intellectual2035 points
    Stefano,
    We have seen this issue before, it is typically due to the network restrictions for UDP.  Check with your internal network to see if UDP (UPnP) is enabled.
    The finder application does not work on development or evaluation kits with an OLED. This is done within StellarisWare.  If you are using unmodified StellarisWare example qs-checkout, then the finder will not find it.
    Sean de la Haye
    Report Abuse
    • Reply
  • Stefano Bettega
    on Apr 03 2012 01:37 AM
    Prodigy245 points
    Hi Sean,
    I think UDP is correctly working, as Finder is locating all of our boards. The problem arise when a TFTP connection is closed by the client. I'm using TFTPD32 (64 bit version, you can find it here). When I start a PUT request and then, after some packets, click on the break button, the transfer stop. From this moment Finder is not working anymore and I have to reset my board to make it working again. I'm currently investigating this problem and will post here my results.
    Stefano
    LM3S9B96 lwIP UDP TFTP
    Report Abuse
    • Reply
  • Stefano Bettega
    on Apr 03 2012 04:04 AM
    Prodigy245 points
    Ok, after a little bit of investigation I found the problem being into UDP socket handling.
    Actually lwIP is configured with an UDP pcb pool size of 4 elements. Two pcb are in use:
    • one for device discovery protocol (Finder), on UDP/23
    • one for TFTP connection, on UDP/69
    When a TFTP connection is started, a new pcb is allocated from the pool; once upon a connection is correctly completed, pcb is removed and put back in the pool. If a connection is broken, the active pcb still remain in the active pcb list, and it's not released back in the pool. If you have two TFTP connection that suddenly blocks, you waste two pcb so that no more pcb are available into the pool.
    Now, when a new connection attempt is made on UDP/69, a new pcb should be allocated and put into the active pcb list. Allocation obviously fails, as there are no more pcb in the pool, and it seems that a NULL pcb pointer is put into the active pcb list, breaking up the list and all of the active pcb. Now I'm trying to search why this non-allocated pcb is put into the list, instead of discarding the incoming packet. Furthermore it would be great to have a timeout option on the TFTP server side to abort the TFTP connection so that all unused allocated pcb could be freed-up.
    Cheers,
    Stefano
      LM3S9B96 lwIP UDP StellarisWare TFTP
      Report Abuse
      • Reply
    • Stefano Bettega
      on Apr 03 2012 04:20 AM
      Prodigy245 points
      Ok, found the problem about the NULL pcb pointer.
      Actually I'm using tftp.c from Stellarisware revision 8555. You can easily find that on lines #613 and #696 there is no error checking for udp_new() function return.
      Line #613 is causing the overwriting problem: return code should be checked and eventually a TFTP error should be returned to the remote party if no more pcb are available.
      On line #696 udp_new() function return should be checked to eventually signal the main application about the service not being started.
      Now I'm looking for some way to handle a timeout on UDP connection.
      Bye,
      Stefano
      Report Abuse
      • Reply
    • Sean de la Haye
      on Apr 03 2012 15:07 PM
      Stefano,
      I can confirm that I've been able to replicate the problem on a DK-LM3S9B96 board.  I will talk with my co-workers and start investigating what it will take to fix this problem.
      Sean
      Report Abuse
      • Reply
    • Stefano Bettega
      on Apr 03 2012 16:06 PM
      Prodigy245 points
      Thanks Sean.
      In the meanwhile I modified tftp.c source code (see attached files). Basically I added two test on udp_new() result value: these test avoid overwriting UDP pcb list.
      About the timeout to be used for closing pending opened connection, I decided to work on a per-connection base. Assuming we transfer one file at a time, when a new connection request is coming from a client we should abort the previous connection. So:
      • first of all I exported TFTPClose function from tftp.c
      • in my tTFTPRequest callback I check incoming tTFTPConnection* against a value stored into a global variable (tTFTPConnection* pOldConn):
        • if no previous connection is present, maybe this is the first connection or previous connection has been closed correctly, so I start to handle the new connection
        • if previous connection is present, I call TFTPClose for pOldConn and then I start to handle the new connection
      • to clean up previous connection pointer, I use tTFTPClose callback. This callback simply puts pOldConn to NULL, as pcb and tTFTPConnection* cleanup is handled into TFTPClose .
      This way we have at most one pcb wasted in case of communication trouble, but this pcb is recollected when a new incoming connection is done.
      I'll wait for your comments.
      Thanks and greetings,
      Stefano
      8738.tftp_server_code.zip
      Report Abuse
      • Reply
    • Sean de la Haye
      on Apr 04 2012 13:05 PM
      Stefano,
      I am glad to hear you got it working.  I have created an internal bug report to get this problem fixed in the TFTP server.  I have attached your code as reference for the fix.
      It sounds like we may also need to record current connections and add a timer to the server to provide a method to check for timeouts.
      Sean
      Report Abuse
      • Reply
    • Stefano Bettega
      on Apr 04 2012 14:51 PM
      Prodigy245 points
      Thanks for your support Sean.
      See you.
      Bye,
      Stefano
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
