• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Microcontrollers » Stellaris® ARM® Microcontrollers » Stellaris® ARM® LM3S Microcontrollers Forum » Bootloader setup on LM3S9B96
Share
  • Forum
Options
  • Subscribe via RSS
Helpful Stellaris® LM4F Series Links
  • LM4F Series
  • Stellaris PinMux Utility
  • Stellaris® LM4F120 LaunchPad
  • LM4F MCU Applications
  • LM4F MCU Video
  • ARM Cortex-M4F Whitepaper
  • Stellaris MCU Brochure
  • LM4F232 Eval Kit
  • Bootloader setup on LM3S9B96
    This question is not answered
    Mike Purvis
    Posted by Mike Purvis
    on Apr 30 2012 11:44 AM
    Prodigy60 points
    I'm having difficulties with the bootloader on LM3S9B96.
    When I do a soft reset from my application (or using the reset button), the ethernet bootloader works correctly, and I see TCP traffic in Wireshark. However, when I power the device on and trigger the loader, it seems to have a different setup--- my LED test pattern blinks at a different speed (much slower), and I see no Wireshark traffic.
    My application is based on the safertos example, and runs at 80MHz, using a 2.5 divider, whereas the bootloader runs at 12.5MHz.
    Thanks for any pointers,
    Mike
    lm3s lm3s9b96 bootloader
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Christian Jolivet
      Posted by Christian Jolivet
      on May 01 2012 14:33 PM
      Expert5220 points
      Hi Mike,
      Can you clarify a couple of details about your system? Are you using a DK-LM3S9B96 development kit, or are you working with a custom board design? Also, exactly how are you triggering the bootloader? For instance, are you calling a function such as UpdateBOOTP? Did you set up a GPIO to force updates on startup? Also, it sounds like you are using the flash-based bootloader rather than the ROM version. Is this correct?
      These details will help me understand what code is executing as the chip comes out of reset and the bootloader is called.
      Christian
      Report Abuse
      • Reply
    • adam adam1
      Posted by adam adam1
      on Jan 23 2013 02:26 AM
      Prodigy145 points
      Hi Christian,
      I have some problems about bootloader via ethernet, too. I program with your sample code (C:\StellarisWare_more\boards\dk-lm3s9d96\boot_eth) on LM3S9B92 robotic kit but it not working.
      I don't understand about this, TI have no documents and no guide about this.
      can you write some guides about this (ethernet bootloader) for every body.
      Thanks and BR,
      Vui Nguyen
      Report Abuse
      • Reply
    • Christian Jolivet
      on Jan 25 2013 09:53 AM
      Expert5220 points
      Hi Vui Nguyen,
      Actually, we do have a User's Guide for all of our boot loaders, including the Ethernet boot loader: http://www.ti.com/lit/ug/spmu134o/spmu134o.pdf
      The default Ethernet boot loader should work if you go through the following process:
      1. Program the boot_eth example to address 0x00000000 over JTAG using LM Flash Programmer.
      2. Switch LM Flash Programmer to Ethernet mode, type in your chip's MAC address and an available IP address on the same subnet as your PC. (If you don't have the MAC, you can find it by connecting of JTAG and using the Utilities tab of LM Flash Programmer)
      3. Connect your board to your local network over Ethernet.
      4. Click the "program" button in LM Flash programmer.
      Please note that the ethernet boot loader polls the local network less frequently as it continues to run. If it doesn't start updating immediately, you can try resetting the board to restart the polling sequence.
      If this is not working, or you are trying to do something different, please let me know.
      Christian
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
